Loud Rattling Help
Bikes: Mid 90's Trek 830, Early 90's Giant Innova, 60's Rollfast Starlight, '06 We The People
Loud Rattling Help
Hi all, I’m hoping you can help because I’m stumped.
I’ve been riding a 2011 Ellsworth Epiphany for the last few years and it’s been basically bulletproof until the last 2 weeks. Basically, when ever I’m in any gear but the lowest 3 or 4 gears (1x11) it rattles like a Walmart bike on even the smallest bumps and I can’t pin it down. Nothing is loose (not even the bottle cage). I’ve ridden it past friends to see if they can pinpoint it and no one can.
I tore down the rear hub yesterday and found a broken fitting (for lack of a better term) and was sure that was the issue. I swapped out the rear wheel and hit the trail only to find the rattling is still there.
I’m completely stumped. Any ideas?
Components:
Fox Float front and rear shock
Deore XT M8000 crank, derailleur & shifter, cassette, hydraulic brakes & levers,
standard seat post
Mavic Crossmax ST wheel set.
Components:
standard seat post
Quoted: 714 Post(s)
Liked 800 Times
On a full suspension bike of that age, I'm guessing some suspension bushings/bearings are worn out.
Otherwise, rattling is usually from the cassette when someone forgets to put on a spacer behind the cassette. You said you swapped wheels, so that is probably not the problem.
Likes For dsaul:
