Yellow or white tires for vintage motobecane nomade
Im looking for proper tire size and I preferably want a white or yellow tire.
Bike has stock wheels
Thanks
Thanks
Quoted: 6196 Post(s)
Liked 4,810 Times
What size are the stock wheels?
If they are 27" or 630 BSD wheels, you might have trouble finding the colors you want. If they are 700C or 622 BSD then Vittoria tire tends to make a lot of colorful tires. I'm sure some others do too, but don't know.
I usually start my search for tires on the websites of the manufacturers that make them.
Liked 4,810 Times
Well if your previous tires were 27 x 1-1/4, then they will be 630 BSD. And that should be the BSD for the rim too.
Continental does still make some tires in a 27" size which is the 630 BSD. And I think they make a Gatorskin in 27 x 1-1/4. But if the tire you are looking at says 27 x 1.25, then that might be something else. Decimals and fractional sizes usually matter on a tire.
Best to know and use the ISO/ETRTO sizing for tires. Then you'll be more likely to never mess up when buying a tire for your bikes. Most every tire made has that stamped or embossed on them. Sometimes in the extremely tiny and almost unreadable print.
https://www.sheldonbrown.com/tire-sizing.html
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,600 Times
Gatorskins are 27 x 1 1/4.
Likes For cb400bill:
A popular budget option 27 x 1 1/4 is the Kenda K35 with tan walls. They're pretty similar to the sorts of tires that would have come on a Nomade originally, and they look very appropriate on most bikes of that era, but they're fairly heavy and not especially supple.
Here they are on an early-mid 70s Nomade:
The best-riding 27" tanwalls that are widely available these days might be Panaracer Paselas. They come in a basic version with a yellow-and-red label, and a "PT" version with a blue-and-white label. The "PT" version has an added puncture-protection belt, but consequentially isn't quite as supple as the basic version.
Here they are (but in 27 x 1 1/8) on my Miyata 710:
Likes For HTupolev:
Expired Member
Quoted: 3674 Post(s)
Liked 5,435 Times
Either the Gatorskins or the Paselas would be fine. Tan wall Paselas look good on a vintage bike, IMO.
No I mean solid school bus yellow to match my yellow bike frame. Or solid white .
Not gum shoe or tan walls.
I might just buy paceras if I can't find anything else.
Here is an example of some cool yellow and black I would want.
From the looks of things online there is not much like that.
Continental UltraSport III
Expired Member
Liked 5,435 Times
No yellow or white tires available, consider yourself saved from an unfortunate choice. Unless maybe you were donning your clown wig and riding in a parade....
Hahahaha. Ouch. Those spirit III tires with the nice yellow lip would look great on 1979 canary yellow motobecane nomade imo
Matching the tire color to a frame's primary color like the OP is suggesting is always a risky proposition and usually goes poorly, but since the yellow Nomades tended to have black trim which would match the tire tread of something like an Ultra Sport III, I think that it could maybe work if the saddle and bar tape were also part of the scheme. It would be a very loud look, but not necessarily bad.
I'm not sure how the OP would intend to handle the color-matching with white tires, though.
Quoted: 874 Post(s)
Liked 2,289 Times
I like the Pasela Panaracer tires . They are available in 27” in 1”,1 1/8”, 1 1/4” . They have a classic look that goes well on vintage road bikes and much better quality than Kenda for just a little more money. I only ride vintage steel road bikes and I like gum wall tires on a lot of my bikes.
