Derailleur jockeys touch cassette on 3 largest rings
Hi, I've had my derailleur, shifter etc setup. And upon trying it, on the 3 lowest gears, the derailleur jockey touches the sprocket, how do I fix this?
Slx m7000 11spd derailleur
Isnt too many teeth, as 1x11 max is 46, mine is 44.
Likes For dsaul:
Quoted: 6193 Post(s)
Liked 4,809 Times
Turn the bicycle right side up!
Don't assess and adjust your DR's while the bike is not in the orientation and position you normally ride in. Gravity might be making you think there is a problem when there is none.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
^This^ Don't take photos w/ the bike upside down. This should be a very simple 'b' screw adjustment as posted previously.
Quoted: 184 Post(s)
Liked 67 Times
Yours looks like it's attached in a vertical position, it's supposed to be attached in more horizontal position.
Likes For cobba:
