Nishiki Linear build diary
Quoted: 1562 Post(s)
Liked 1,734 Times
3/17/24 update: Some shocking developments to my first C&V build
This will be an ongoing build diary chronicling me (slowly) building up a Nishiki Linear 62cm.
The bike as advertised on CL:
I drove all the way from San Jose to Sacramento to buy this bike. I only bought the frame and the 24" front wheel though. Frame on my stand back home:
It's in very good condition. As far as I can tell nobody has ever clamped a front derailleur on this frame. And then I bought this Giant bike for $300 to scavenge the 105 5700 drivetrain from:
But after riding around on it, I kind of grew fond of it. This became my commute-to-work bike. And in any event the Hollowtech II crank and the wheels aren't exactly period-correct. So plan B:
Got an RSX partial groupset for $40, and also got a 126mm NOS RSX rear hub, both from Ebay:
This hub was laced to an Alex DA22 rim by our esteemed wheelsmith Mr. Rabbit.
Slapped a Conti 4000s 700X25c tire on there, and got a big surprise - the wheel would not fit into the frame- the chain stay bridge is stopping it. I had to deflate the tire, mount it on the frame and then re-inflate the tire. Is that common for these old frames? Anyways- once it's in the frame, there is actually loads of clearance for the 25cm tires:
Got these 42cm Nitto Promenade cruiser handlebars off of CL:
Neat, huh?
No? Just kidding!
Bike is taking shape! Unfortunately I found out that I needed a 110mm spindle for the RSX double crankset. More delays.
Anyways, keep in mind that up to this point in time I have not thrown a leg over this bike. I just did some measurements on my old bike and figured that 62cm c-t should fit me if I drop the seat post to the lowest position. So now is the moment of truth:
With the seatpost in the lowest position, it still feels a smidge taller than my regular bike. Maybe I'll swap the Selle San Marco seat with the Selle Italia seat from my other bike. That seats seems to be ~1/4-1/2" lower profile. Another screwball idea is to go down to 165mm crank, which would gain me 5mm over 170mm crank. According to the experts 165mm is probably right for my 172cm height anyways.
To be cont'd
Neat, huh?
No? Just kidding!
To be cont'd
Likes For icemilkcoffee:
Quoted: 1199 Post(s)
Liked 1,355 Times
Very nice progress build thread for your Nishiki Linear. One of these popped up near me in the past few months but unfortunately it was a disaster of a frame.
I hate test fitting bikes with jean shorts or even basketball shorts bcuz I think it still doesnt give the full range of leg motion. Therefore the needed saddle height, crank/stem length and handlebar position won't be accurate for optimum comfort.
I personally would tilt the bars up towards you a bit. The wrists look like they will be hurting in that position after a ride. I know you hopped on just for feels but nice build you got going on.
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Oh boy, I almost had a stroke. Or something. I was looking at this thread on my phone, and you hooked me right in with that first handlebar pic. Second photo got everything flowing properly again. A few years ago, these seemed to be plentiful. So I went and got other bikes... Oops. Nice job!
I seem to have lost what little mind I had left before this all started.
Likes For Last ride 76:
Likes For 2cam16:
Liked 1,734 Times
Yeah. Realistically I’ll have to tilt it up some. I just like the way it looks now because the transition part of the bars line up with the head tube, and the drop part of the bar lines up with the ground. Once I tilt it up, it will break up the lines. Oh well!
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
IC,
Looking forward to following the build....great looking project.
Best, Ben
Best, Ben
Likes For xiaoman1:
Barred @ Velocipedesalon
@icemilkcoffee, nice ride you have going. Mine is a 1987 model year, but built in '86. Not my newest build as my bike now sits, but this photo was between when I got it (complete bike @ <$190!), and some first alterations. Now it is nearly stock; except still needing DT 1st gen 105 shifters, and "Biopace" chainrings (available cheap at my LBS). This photo still has LOOK pedals and OFMEGA derailleurs still on it, with bar-end shifters. I was able to find a great set of 105/1050 pedals with the plastic cages still in great shape, but I ride LOOK so I left the "clipless" pedals in place .This frame rocks; just rode this past weekend on it. My frame is a 58cm, should seem large (I ride 52-54cm), but feels just fine. You should enjoy it once you get it fit to your body, but over 25 miles is not for me on it; my back!
Liked 1,734 Times
Anyways my project is stalled at the moment- I am transferring the whole RSX group and the RSX hub wheel over to a Bianchi I am putting together for my wife. The Linear will get a tri-color 600 group. I just need to get another rear wheel built for it.
Sweet looking bike! I saw a 54cm version of the Linear, and it didn't look as good. I think this frame looks best when it's either 58cm or 62cm- it looks the most dramatic!
Liked 1,734 Times
OK! Project Linear is back on track. When we last left off, I had just taken the groupset, wheel, stem, etc off of the Linear to put on my wife's bike. So now the Linear is back to square one. Stripped clean and back on the stand:
In the mean time I have completely changed my plans for this bike. I got a 600 tri-color groupset, and got a new handlebar/stem and shifter. The only thing carried over from the first iteration was the tire.
I got a Sun Ringle rim off Ebay for the grand sum of $10. I wanted a shallow rim with eyelets, to match the (BMX?) front rim. Here is the wheel freshly built by Mr Rabbit: Sun Ringle rim with 600 tri-color hub.:
When we last left off, the old seat post/seat combo was just a tad high for me, even at the lowest setting. After a lot of scrouging around, I found the Sakae seat post which is probably the lowest rise seatpost available:
Compared to the original Kalloy seatpost, the Sakae seatpost mounts the seat about 15mm lower.
I also decided to go with a Nitto RB009 bar instead of the original bar and tt brake levers.
Bike is taking shape:
After installing 105 brake levers, 600 brakes and 600 crankset, I got on the bike and did the KOPS routine and adjusted the bar/stem:
I ran out of daylight for today. Hopefully tomorrow I can finish putting the groupset on there!
Liked 2,182 Times
I was wondering what was going on with the build.....Looking quite nice!
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
I've been tempted by one of these for more than a decade. For some reason, I really like the townie-ization of a TT frame. Bluelug did a Low-Pro with a Promenade upright bar that I really liked a few years ago.
Liked 1,734 Times
Today I put the finishing touches on. 600 tri-color FD, RD, crankset; 12-28 7 sp cassette, and 42/52 rings up front.
NOS Bio-pace chain rings. I love Biopace rings. Alas the crankset is far from NOS though:
Cockpit: 105 1055 brake levers and BS50 7 speed barcon shifters- very hard to come by. Lovely Cinelli cork bar tape:
And now the piece-de-resistance! Selle Italia Iron Flow seat. This one:
This seat is probably no more than 10 year old, and is technically not period correct. But I just love the space age styling with the tail fairing. It fits in with the zoomy 80’s styling of the Nishiki:
‘tail-light’ detail
Also My understanding is that this seat has been banned by the UCI because there is too much of a backstop. So right there something else in common with our beloved funnybikes
here it is! The finished bike!
Oh hold on there. That wasn’t the piece -de-resistance. This one is:
you don’t see it? It’s the retro aero water bottle. They sell these on Ebay. It’s kind of crudely made with lots of flashing. But it does complete the look!
I hopped on the bike and took a spin around the block. Maybe it’s the little front wheel but this bike just feels fast no matter what speed you are going. It’s a hoot! The 50mm stem is probably too short. I guess my calculations were no good. The Iron Flow saddle unfortunately, is just weird. I’ve tried probably 10 or more saddles in the last year and this one is possibly the weirdest and most awkward. I might have to tilt it down a bit.
‘tail-light’ detail
Liked 2,182 Times
IMC,
I really like the build and the care/deliberateness that you have taken in selecting the components for the build.
Best, Ben
icemilkcoffee
Best, Ben
icemilkcoffee
Voltaire
Voltaire
Likes For xiaoman1:
Liked 1,734 Times
Revisiting my first C&V build! I was never too happy with the look of the tall stem. I got ahold of a 90deg Nitto stem and a light grey Nitto RB018 flat bullhorn bar.
I put it on the bike and then noticed the upturned tips are too short to take the barcon shifters. What to do? I can’t give up on this new bar because that would be admitting defeat. In an alarming departure from good taste and common sense and in flagrant violation of UCI rules, Generally Accepted Accounting Principles, and the tradition values that made this country great, I put these Altus CT15 shifters on there:
They were pretty much what you would find on a KMart or JCPenny bike . But I do like the little indicator dials!
The finished product:
No more tall stem sticking out like a sore thumb! The brake levers are Tektro interrupter levers. They work surprisingly well here. The Altus right shifter works very well. The left shifter works well but it does take some thumb effort (it was meant for longer-armed MTB FD’s).
Bikes: Old Carlton frame and fork. Old Nishiki frame and fork, single speed build? 2003 Scattante full carbon/Ultegra. 90’s trek steel with full 600(purchased for the components) Also vintage K2 full suspension
Quoted: 21 Post(s)
Liked 32 Times
An original, good on you! Well done! And after a ride get a neck massage
Likes For Velosophy:
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
Great serious thread about a "funny bike."
feros ferio
Liked 1,329 Times
Having just read the "farthing penny" (old high-wheeler "ordinary" or "penny farthing," but with the small non-drive wheel in front instead of back) thread, I reacted that the "funny bike" could be regarded as a cross between a farthing penny and a safety cycle, or maybe a higher-technology re-envisioning of the former.
Liked 1,734 Times
The main issue I am having now is that this Nitto RB018 handlebar is pretty small. There is only really one hand position possible. And the CT15 shifters pretty much took up all the room on the 'top part of the bar. I may have to rearrange the cockpit yet again this weekend.
