Anyone trim down a drop bar?
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I’ve been running a set of Cowbells for a few years, and I notice that I never use last inch or so of the bar. I have also wished the bar end mirror was not so far back.
So as I am changing my bar tape, I decided to lop off the last inch off either end. I figure this will make the mirror easier to use, and also give a little more wiggle room when loading bikes on my 1UP trays which are a little close together.
Anyone else ever do this?
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
I'm building a bike now after a frame repaint and have mounted a Zipp 70 xplr bar. If you go to whatbars.com the overlay with the cowbell shows it to be about what you have now. So..no I haven't cut a set of bars, but there are bars available that are using a design much like you have now.
Randomhead
Liked 3,698 Times
There is nothing wrong with cutting off the ends of your handlebars.
Quoted: 576 Post(s)
Liked 1,002 Times
I've seen bars trimmed down right after the shifter; no drops at all.
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
I have several sets of barcons and planned my next build would have set mounted. Local framebuilder told me that they add an extra length (I think he said 2 inches) to the length of the bars and that the barcons would then catch my knees if left uncut and he recommended I trim my bars back to allow for that extra length.
Likes For WGB:
Quoted: 2333 Post(s)
Liked 2,097 Times
I trimmed an inch off a set of Cinelli 66-42 bars back in the day, I have no idea how my knees would hit the bars when jumping for a sprint. 40 years later, the bars haven't self destructed.
Quoted: 1088 Post(s)
Liked 1,025 Times
I've done it on my kid's bike, wanted a 36cm bar but they came in pretty far at the bottom for a small 24" wheeled frame. Just used a pipe cutter just like with a mtb, unless carbon, in which case I use a high speed, high tooth count bandsaw.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Yeah, spend a few $$$ and get a pipe cutter. I've done it with a hack saw, but its not a very clean cut. ;-)
Nothing wrong with cutting down aluminum handlebars
