new here
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 455 Post(s)
Liked 405 Times
Do you have questions?
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
Bikes: Dahon eco & Dahon Espresso
Yes I do have a question. I have a Dahon Espresso with 26" x 1.50" Kenda Kwest tires and they show a lot of age. Cracking / checking on the sidewalls although plenty of tread left. I make a lot of practice grocery runs learning how much I can carry and how to pack the pannier bags and top backpack. I'll be using the Espresso and, or my Dahon Eco 7 speed for getting groceries, supplies etc. when I start sailing long distance between Maine and the Caribbean. I'm trying to find a new tire 1.75 - 1.95 width that I can air up for loads and air down for just me and a beach towel. I'm 170 -180 lbs. and a payload of 50 - 70 lbs. No not all beer ! Probably some rum too ! Not a lot of info on the web sites that sell tires about max and min. air pressures and even less about load capacity. I was thinking tires made for tandem bikes, heavy riders ? I like the Schwalbe Marathon but some say 40 - 60 psi. others up to 100 psi. I'm looking for 100 + psi tires for heavy loads........... I think ? Right ? Ha ha !
I sure would appreciate any and all advice / knowledge / personal experiences everyone here can share with me.
Thank you, John Hedlund
Schwinnasaur
Tire pressure is pretty much a personal choice within bounds. The max pressure rating of tires is printed on the side of the tire (and available online) is half the blow off pressure (I think, though this does not matter.) It represents a hard boundary. The minimum pressure is usually on the tire, but this represents a soft boundary, to me. If you have too little pressure, you will have snakebite looking flats on your tubes without actual punctures. I tend to ride toward the softer end of the spectrum. I don't like a harsh ride. Some say there is less resistance at higher pressures. While that may be true, the harsher ride, negates the advantage. I like wide tires that are supple, with supple side walls, that tend to absorb shock. In 26 inch size, I liked Schwalbe Big Apples and Panaracer Paselas, though I do not have a 26" bike anymore. The more supple tires generally are more efficient, faster, but flat more easily. For a lot of people, tire choice becomes a compromise with tolerance to getting flat tires.
Bikes: 1999 Bike friday NWT, 2009 Bike Friday Tikit, 2023 silverock Dewy, 2008 Dahon Smooth Hound, 2023 Litepro Trifold
Quoted: 191 Post(s)
Liked 230 Times
Hello, I’m using Michelin Protek tires size 1,85 x 26 since September. They are on my old commuter bike and filled to 55-60 psi. I weigh about 165 lbs. I carry 25 to 50 lbs in the rear milk crate. Up to now they have performed well. Hope this helps.
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
Thank you to everyone for the replies. After doing some searching I found the Schwalbe Marathon 26 x 1.75 I'm considering will handle loads up to 109 kg. = 240 lbs. and comes with 3mm or 5mm puncture protection. Does anyone have experience with puncture protection ? I'm still looking and I hear good reviews about Continental and Kenda tires too.
John
John
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
John
John
The puncture protection is a layer of additional material meant for reducing the likelihood that glass will get through to the inner tube. The tradeoff is that it makes the tire a little bit slower. The Marathons currently available also have a stiff sidewall, which additionally contributes to making the tire slower.
I have Marathon Greenguard tires on two 700c bicycles. If I rode those bicycles more often, I'd probably switch to a different tire on them. On the bicycles that I ride every day - 20" wheels - I use Big Apples due to them being a faster tire.
