Bibs vs shorts
old newbie
Bikes: Specialized Roubaix
Quoted: 541 Post(s)
Liked 359 Times
Bibs vs shorts
I have some Canaris cycling shorts that I bought at Academy. The chamois/pad slips forward when I ride. I do ride in a more upright position.
Would bibs keep the chamois in place better? My old butt bones want some padding. The Canaris slips enough that the padding isn’t where I need it.
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,899 Times
Quoted: 6963 Post(s)
Liked 10,964 Times
Canari is a relatively cheap brand. Better shorts will perform better. Buying them in the proper size (they should be tight) will help, too.
But, to your question: yes, bibs do stay in position better than shorts for many riders.
Likes For Koyote:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I don’t see how the chamois slips forward unless the shorts themselves are sliding down in the back. If that’s the case then yes, bib shorts might stay in place better. But it sounds to me like you just need better fitting shorts.
Likes For Rolla:
If the shorts are slipping it sounds like they're too big for you, but yes, bibs do a better job holding everything where it should be. I switched to bibs last year and I'd never want to go back to shorts.
old newbie
Quoted: 541 Post(s)
Liked 359 Times
The shorts are sliding down in back. The chamois/pad is sewn in. I don’t mind buying better shorts but if bibs are better I will get them. I am 64 and fat. I ride sorta upright on my 2012ish Specialized Roubaix. I rest my hands against the horns and don’t use the drops.
Liked 11,899 Times
If you're riding with your hands on the brake hoods, that's pretty much where most road cyclists will be most of the time. Also the ramps, right behind them, or the bar tops when climbing in the saddle. The drops are generally used a lot less. If you can reach them, you may be able to practice enough to ride comfortably in them.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2582 Post(s)
Liked 5,641 Times
If you live in a hot area, one word of caution about bibs. They are considerably hotter, at least for me, when the temps go way up. I use bibs in the winter for extra warmth and regular cycling shorts during the hotter months. But like the others have said, bibs don’t shift. I use medium quality shorts and don’t have any issue with shifting shorts. If you are changing positions on your saddle for comfort, raise your behind and then sit down rather than scooting on the saddle which can lead to bunching or shifting of the chamois. Bibs do make great spanx for overweight male guts.
I am sure someone will disagree about the heat aspect, but that is my experience.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
old newbie
Quoted: 541 Post(s)
Liked 359 Times
I may look into some better shorts.
Quoted: 426 Post(s)
Liked 274 Times
I find bib more comfortable. Don't have to be as tight to keep them up. I ride with shorts 99% of the time though. Bathroom connivence > less tight bibs. ha-ha
Grupetto Bob
Liked 5,641 Times
Did see a couple of port0potties but bibs would be more of a pain for them.
Quoted: 3241 Post(s)
Liked 2,512 Times
Didn't we have a bibs vs shorts thread recently?
Bibs vs. shorts is one of those debates that keeps going on and on. I don’t like bibs, but many, many road cyclists do. Give them a try. But whether you go with bibs or shorts they need to be snug. Also, no underpants. That will cause lots of issues. And there are many differing chamois pads in cycling attire. You’ll go through some trial and error before you find what you prefer.
Happy cycling!
Happy cycling!
Likes For Sapperc:
Canari has always been something of the entry-level clothing. If a person gets the urge to start cycling for fitness walks into a bike shop, buys a lower-end bike and then asks about cycling clothes, they’ll likely be sold something by Canari. If they stop riding after a couple weeks and hang up the bike in the garage until they give it to Goodwill, or sell it at a garage sale, they won’t care much about the clothes. But if they stick with riding, it won’t be long until they buy some better clothes.
My first cycling clothing was from Canari, and it got me by for the first few months. But I found that more expensive shorts were expensive because they were better. I eventually moved up to wearing Assos Sportsline and then Prosline shorts, both regular and bibs. I rode a lot in subtropical weather, very hot and humid, with an occasional torrential rain shower. I liked the fit of the bib shorts better, but they are a little hotter, so I usually worse sleeveless mesh jerseys which were much cooler.
Nowadays I wear regular Pearl Izumi shorts, which are common and relatively inexpensive here in Japan. A decent pair is about 12,000 yen, or about $90. They are comfortable, stay put, and last a long time.
Quoted: 18416 Post(s)
Liked 15,554 Times
Quoted: 3952 Post(s)
Liked 7,298 Times
I used to ride with several pro women riders, and they all wore bib sorts. They lost no time to the men during “nature” breaks.
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 171 Post(s)
Liked 395 Times
I just became the owner of a pair of bib shorts from a friend who ordered the wrong size and it was too much of a hassle and expense to send them back. Thus I got them for a very good price. Will be trying them out for the first time in the coming days.
I do like cycling in gel shorts. I know that there was recently a thread about gel vs chamois shorts. For me, gel shorts work whether riding in the cooler climate of the PNW or the hot and humid climate of Thailand and SE Asia. YMMV
I hate bibs for two reasons; the bathroom breaks and the straps over my shoulders. I’ve never had a problem with regular shorts not staying up, but the bibs are a pain in the neck to put on, take off, pull down in front for a quick pee, etc. I don’t notice anything fits better when I wear the bibs, but it takes longer to pee!
Likes For A350driver:
