1960s Duckett
1960s Duckett
Old 05-22-24, 06:20 AM
chrispope248
Bikes: 1957 Carpenter,1960s Duckett, Boardman carbon framed road. Bitzer mountain ( my fav)
Liked 3 Times in 2 Posts
1960s Duckett
I have a circa 1960ish Duckett bicycle inherited from my father. It has a serial number on it (2276) is it possible to find out the year of manufacture from this?
It had been standing in a damp shed for a long time, there is quite a bit of surface rust and the paint is flaking. I need advice please someone told me not to repaint the frame, if that is the case what would be preferred solution, coat it with oil or clear coat lacquer? I'm finding removing the chain wheel from its shaft rather difficult, the removal tool i have doesn't fit , any advise would be gratefully received.
Great site plenty of interesting items. Thanks
chrispope248 is offline
Old 05-22-24, 06:31 AM
markk900
markk900's Avatar
Liked 718 Times in 385 Posts
Welcome to the forum. Pictures would be most welcome but you will find you can’t post them until you have 10 posts on the forum; best is to upload the pictures to your personal album and someone can link them from there.
To get your 10 posts perhaps some more information about you (such as where in the world are you), the bike and its history as you know it, etc.
I haven’t heard of that brand before…. Looking forward to seeing it.
markk900 is offline
Likes For markk900:
Old 05-22-24, 06:39 AM
chrispope248
Thanks I will sort some info about this make and my profile ,
Old 05-22-24, 08:46 AM
juvela
juvela's Avatar
Liked 3,785 Times in 2,443 Posts
lug pattern NERVEX Professional
appears builder polished away the NERVEX markings on shell underside
pump peg NERVEX Ref. 845
shift lever mid-seventies Huret
single plateau chainset Stronglight and/or T.A.
red/yellow/blue stripe combination suggests national origin of nine lands:
Andorra
Chad
Columbia
Democratic Republic pf the Congo
Ecuador
Moldova
Mongolia
Romania
Venezuela
if the colour which appears to be blue is supposed to be black that would make it easy: Belgium
possible transfer's colours affected by weathering...
they could also be from family crest or city/province emblem...
juvela is online now
Likes For juvela:
Old 05-22-24, 09:32 AM
rustystrings61
Liked 2,315 Times in 834 Posts
Originally Posted by chrispope248
juvela noted the chainset, which from this angle is either a Stronglight model 49 with T.A. chainwheels OR a T.A. with T.A. chainwheels. The T.A. uses a 23.0 mm crank removal tool, which many years ago was included on older Park double-sided crank tools. Stronglight cranks (at least until some time in the '80s I think) used a proprietary, Stronglight ONLY 23.35 mm crank tool. I mean, hey, they WERE pretty much the first cotterless alloy crank makers. Unfortunately, the industry standard became the 22.0 mm fitting as used by Campagnolo, which will not (safely) engage the threads - maybe enough to strip it, alas, but not enough to safely pull the crank.
Stein tools produces modern tools to remove both types of cranks, or you can track down a vintage one - hopefully you are somewhere near an older bike shop that has been around for a while!
rustystrings61 is offline
Likes For rustystrings61:
Old 05-22-24, 10:17 AM
juvela
juvela's Avatar
information forwarded by member [MENTION=173992]non-fixie[/MENTION] and greatly appreciated
​​​​​​https://www.classiclightweights.co.u...s/duckett-a-g/
the enterprise staged a cessation of play in 'lxvii so that brackets date of frame in one direction...
Likes For juvela:
Old 05-22-24, 06:12 PM
PhilFo
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"; 1994 Concorde Aquila
Liked 425 Times in 271 Posts
And also from Classic Lightweights: "In the 1950s some felt that the Art Deco ‘Duckett Superlite’ head transfer was rather dated, so ordinary models were given the round pre-War ‘Elite’ transfer, complete with obsolete address." Which may narrow down the production date even more.
Phil
PhilFo is offline
Likes For PhilFo:
Old 05-25-24, 08:24 AM
chrispope248
Thank you everyone for the information. I've managed to remove pedal arms with a bit of wd40. the frame has had a good degrease, surface rust removed and a few coats of lacquer. Continuing to clean up components and will add straight bars for a position that suits me better. Plan to fit a 3 speed gear on the front . I am retaining all the original parts if needed.
Old 05-25-24, 09:13 AM
PhilFo
Tinker-er
While the photo of the back side of the crankset is helpful in one way, we can't see if it is cottered or cotterless. It could be a Williams, BSA, Magistroni, or other 5 pin cottered unit, on a Chater Lea bottom bracket, especially considering it's age.
Phil
PhilFo is offline
Old 05-25-24, 10:34 AM
juvela
juvela's Avatar
in this image it can be seen that the bottom bracket lockring is of the two-notch variety
this eliminates both Stronglight & T.A., at least for the lockring
in the image below of all the bits comprising a Williams AB77 set it can be seen that the bottom bracket lockring of the set is a six-notch type
Likes For juvela:
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
