Helmet Question
#51
Habitual User
Quoted: 4946 Post(s)
Liked 8,087 Times
I've been reading a ton of reviews of helmets, and then trying to figure out which ones I can actually buy in the size and color I want. The Sphere has my attention, but there's a couple of issues mentioned in reviews that have me hesitant. I would really like an Abus Airbreaker, but haven't been able to find one to buy. Same issue with the Scott Centric Plus.
#52
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times
what helmet would you guys recommend for kind of an oblong shaped head? Not extreme just not perfectly round. Like the front and back could fit snugly and the sides be a little too loose
thanks if any opinions. Have never worn a helmet
#53
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4390 Post(s)
Liked 3,016 Times
I think that's most helmets.
#54
Quoted: 966 Post(s)
Liked 1,629 Times
Thanks Dave, this site has a ton of information. If I was gonna go for a multi-sport helmet I might consider a Hockey helmet... Ha
Virginia Tech Helmet Ratings https://www.helmet.beam.vt.edu/
#55
Unless the hemet is damaged, I see no need to replace it. I have seen no scientific evidence--yes, I still believe in science--suggests the helmet is compromised with age. When I see it, I will change helmets.
#56
Habitual User
Liked 8,087 Times
I ended up with the Scott Centric Plus. I spent a while at my LBS, and tried on the upper-end offerings from Lazer, Kask, Spec, Bell, Giro, Smith, and Scott. The Scott was immediately "right" for size, fit, and comfort. First ride was 2 hours of MTB in warm temps, and it was everything I wanted - light, airy, and comfortable. My previous Abus Aventor was terrible for airflow at the forehead, but this Scott was excellent. For me, it's a winner, especially with a 5-star rating on the VA Tech test.
#57
Quoted: 4411 Post(s)
Liked 4,861 Times
Likes For PeteHski:
#58
Habitual User
Liked 8,087 Times
One of the things I learned this time around was what to look for at the forehead. Having air channels behind the forehead pad is critical for good flow. The Abus Aventor lacks them. Running around the store to check airflow wouldn't have gone over very well - LOL.
#59
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
Also, while you're trying them on wear your sunglasses and bend over into a tuck position to see if the fit is good there too. I had one helmet that caused me to crane my neck into an uncomfortable position while riding, but felt perfect while sitting up.
#60
i think keeping them out of the sun would keep them in better overall condition than leaving them i the sun
