Recommend me a 2.0-2.2” 29er gravel tire?
Old 08-23-21, 09:08 PM
Toadmeister
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times in 170 Posts
I currently have 2,2” 29er Maxxis Icons on 25mm rims on my Salsa Fargo. Great tires for off road and cross country but too knobby for pavement which is still 50% of many gravel rides I do.
looking for a faster pavement roller with still good gravel grip in the 2.0-2.2” range. I like this size for the cushion over traditional 40mm range gravel tires. I’m a big Clydesdale so more cushion for the pushin!
Toadmeister is offline
Old 08-24-21, 02:54 AM
tangerineowl
Bikes: Curve Grovel v2 ti
Quoted: 257 Post(s)
Liked 91 Times in 75 Posts
Conti SpeedKing Racesport 2.2" front and rear perhaps. Dry riding. Supple. Up there with the ReneHerse filetreads for rolling speed.
You may want a bit more tread up front depending on your local surfaces and riding style.
I run that in 27.5 most of the time. But don't do any high speed corners across loose over hard, where you may slip out at the front.
Steeper hills over loose, you will lose climbing grip at some stage.
ThunderBurt 2.1"? has a low 1.5mm knob height. Maybe put that on front.
RaceKing Protection is 2mm+ height. Another front option. Protection casing is rather stiff though. There is a supple RaceKing Racesport.
ReneHerse may have a knobby around that size. 3mm.
tangerineowl is offline
Likes For tangerineowl:
Old 08-24-21, 03:48 AM
Fentuz
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 240 Times in 176 Posts
Continental Race king at the back in 50-622 and Continental Cross king at the front in 50-622 or if you require more off road front grip 55-622
This is a classic XC setup for fast rolling and good control
Fentuz is offline
Likes For Fentuz:
Old 08-24-21, 11:43 AM
Toadmeister
Quoted: 198 Post(s)
Thanks fellas.
Any comments on
Vittoria Terreno G2.0 TLR 29 Inch MTB/Gravel Tire
Or
Vittoria Mezcal III G2.0 Gravel Tire?
Old 08-25-21, 01:35 AM
Fentuz
Quoted: 264 Post(s)
Originally Posted by Toadmeister
Thanks fellas.
Any comments on
Or
Vittoria Mezcal III G2.0 Gravel Tire?[size=13px]
[/size]
Same as before, I d put the Terreno on the rear and the Mezcal on the front. I looked at doing for my 700c rims but I couldn't get the sizes.
Fentuz is offline
Likes For Fentuz:
Old 08-25-21, 09:08 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Thanks fellas.
Any comments on
Or
I have Vittoria Mezcal front and rear. I think you can get them 2.1, 2.25 and 2.35. Good center rib ... rides good on pavement..... cushy big tire with smaller blocks rides good on gravel, trails, mild single track. I choose them over Contis because the Vittoria tires (At least the Black/Anthracite sidewall) seals tubeless without sealant.
https://www.vittoria.com/us/en/tires/mtb-xc/mezcal
trailangel is offline
Likes For trailangel:
Old 08-25-21, 10:35 AM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
I use schwalbe Furious Fred 50mm (minimal tread - super, super fast - nothing like it), and 54mm Thunder Burt. Both have very low rolling resistance. The FF is super fast and super light - I'm thinking the TB is gonna be more durable.
chas58 is offline
Likes For chas58:
Old 08-25-21, 02:09 PM
tangerineowl
Quoted: 257 Post(s)
Forgot about the FF. Though it is worth pointing out they measure a few mm narrow. Mine were about 46mm on a 22mmInner rim.
On gravel/offroad that isn't too slippery they do roll very fast.
I felt when the tread was fairly new, their rolling on sealed roads wasn't anything to rave about. More-so with your weight over the rear tyre.
About 375gm, so pretty light for that size. Very supple.
The Gravel Cyclist did a short review a couple years back.
Old 08-25-21, 03:00 PM
chas58
chas58's Avatar
FF..
Yeah, he called them a cheater tire. Given that they are pretty much as fast as my 32mm slicks, but I can ride with 1/3 of the pressure - that makes them a lot faster on the rough stuff. I couldn't ask for more on a dry fast (20-30mph) gravel ride/race (or just a slow solo endurance ride). And they corner like a road tire on pavement (unlike the thunder burts, which corner like a monster truck in comparison).
chas58 is offline
Likes For chas58:
Old 08-26-21, 04:22 PM
DarKris
DarKris's Avatar
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times in 54 Posts
I actually recommend the Panaracer Gravelking SK 50 if you wanted a second opinion.
DarKris is offline
Likes For DarKris:
Old 08-26-21, 04:43 PM
Toadmeister
Quoted: 198 Post(s)
a good recommendation. I actually have a hardly used set of 38mm Gravelkings from my wife’s old bike. Wish I could swap someone for some 50mm ones! I might just try and sell them.
Old 08-26-21, 04:44 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
+1. Good 50/50 tire.
tyrion is offline
Old 08-26-21, 04:48 PM
Toadmeister
Quoted: 198 Post(s)
I checked them out and read the interview. Hadn’t heard of these before. Hard to believe by looking at them they’d be fast as a slick. Must be very light casing, as indicated by weight. I’d be sorta concerned about durability. A little hard to find online too.
Old 08-27-21, 10:25 AM
chas58
chas58's Avatar
I'd be concerned about FF durability too. I use it on the front, so it gets no wear and tear. It certainly spins up fast, allows me to run low pressure and keeps me on course.
I've loved the Maxis Rambler too in 40mm size, but they make a 45 and a 50mm too. Its similar in that it is a low height knob fast rolling tire that doesn't have the GK-SK issues (tight knob spacing causing it to throw rocks at your frame and load up with mud). I use the rambler for Gravel and CX races.
chas58 is offline
Old 08-29-21, 07:40 PM
Toadmeister
Quoted: 198 Post(s)
Rode those 2.2 MAXXIS ikon again today and was reminded how much I love them on Iowa Gravel. Now that I’ve got ~1000 miles on them, they’re rolling a little smoother on pavement with the center nubs a little worn, still a bit noisy.
I think I might finish this autumn gravel season on the Ikons and swap to Vittoria Mezcals in the spring after the snow is gone. Will watch for deals and buy them on sale.
I should add that I have another wheelset, 29x35mm rims with 2.8” Terevail Coronado’s. These are awesome for serious mud, dirt and Mt Bike trails. Like having two different wheel sets for different rides.
Old 08-31-21, 08:33 AM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times in 166 Posts
Hookworms
c_m_shooter is offline
Old 09-01-21, 10:08 AM
chas58
chas58's Avatar
Hookworms
LMAO. Where did that come from?
I did a century ride on them once with my wife. They are slow and heavy boat anchors. Exactly what I wanted for a long ride with my wife. I thought they would be usefull for an ebike, but IMHO, they are too slow and stiff and heavy even for that.
chas58 is offline
Old 09-02-21, 01:48 PM
tangerineowl
Quoted: 257 Post(s)
Came across the Kenda Sabre Pro today.
29x2.05" in TR version weighs 530gm.
29x2.2" in TR is 539gm.
Old 09-03-21, 10:00 AM
chas58
chas58's Avatar
Wow, those look identical to an old set of 26" MTB race tires I had from Bontrager. Great tires - maybe I'll get a set
chas58 is offline
