Uh-oh, cracked rim
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 95 Post(s)
Liked 166 Times
Uh-oh, cracked rim
I'd say this one is dead...
I've not been able to ride this season due to a few factors, the biggest one being knee surgery which I am recovering from. Anyway, with the potential of being able to ride reasonably soon, I put my rear wheel in the truing stand today and found this - it's a drive side spoke.
This is a 32 hole Open Pro rim that's about 10 or so years old. Spokes are in good shape, so options are to just replace the rim with another, or take the opportunity to do a complete re-build with a more modern rim (depending on availability). This is on a 20-year old steel bike so will stick with a fairly traditional profile regardless. Glad I was bored today and decided to check it.
Likes For mprince:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Yeah, good thing you checked!
What's the spoke gauge? If they're double-butted, I'd definitely get another Open Pro and swap it on.
Likes For ThermionicScott:
Quoted: 95 Post(s)
Liked 166 Times
Likes For mprince:
The Open Pro is my favorite rim, and have used them on several bikes. Never cracked one out, but have put a big flat spot in one on a night ride. Didn't see the 30 foot deep pot hole!
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Quoted: 5224 Post(s)
Liked 3,581 Times
Quoted: 194 Post(s)
Liked 204 Times
If this were just a hacking around bike I would just reuse the spokes, but I would still leave the decision about their condition until I had them all off and could inspect the ends.
Likes For Geepig:
Quoted: 2432 Post(s)
Liked 638 Times
You might already know, but a rim replacement using the exact same rim is very easy. Just tape the new one against the old one and transfer the spokes over one by one. And I love Open Pro's, I've always had at least one wheelset with them since the 90's. I personally have never cracked one.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Not just the same rim. Any rim with the same effective rim diameter (ERD) will work (± a couple of mm). The problem is finding that a rim with the same ERD. They vary a whole lot.
Stuart Black
Stuart Black
Liked 2,568 Times
If the spokes haven't given any trouble until now, I would be perfectly comfortable taping the new rim to the wheel and transferring all of the spoke ends without unlacing the wheel.
Quoted: 194 Post(s)
Liked 204 Times
There may be corrosion or even cracking at either end. Your wheel has given good service - until now, so there is always a chance of another issue. Anyway, it should not stop you taping the wheels, and probably everything will be OK, but the engineer in me says 'Let's just check, while we have everything apart.'
Quoted: 95 Post(s)
Liked 166 Times
I can say definitively that the spokes and nipples are just fine, as are the hub flanges. I am also an engineer, which led me to inspect the wheel in the first place.
As soon as I can locate a rim, I'll swap it with the damaged one, I've done this several times in the past; twice on this specific wheel in it's 20 year life as I wore the brake track out on the original and dented it's replacement on an unseen rock in the road.
Quoted: 83 Post(s)
Liked 64 Times
If you ride near salt exposure & have alloy nips, replace them. They might look fine on the outside but tend to corrode internally. Not fun when they literally crumble on removal or even worse - on tightening to the new hoop. Replace with brass to minimize the issue. No problem with reusing spokes. The ones shown look like brass but hard to tell from the photo. Nipples are cheap and easy.
Quoted: 95 Post(s)
Liked 166 Times
These are brass nips - I had a bad experience with alloy nipples many years ago, had one break on a front wheel during a standing climb and upon inspection the inside looked like swiss cheese. I went to a bike shop that same day and replaced all 64 nipples with brass in my hotel room that night before the next day's ride. I will never build another wheel with alloy nipples again.
Liked 2,568 Times
I'd say that if a spoke is cracked, a round of exuberant stress-relief should find it. If you take a wheel apart, then you have to keep track of which spokes were elbows-in/elbows-out for relacing the wheel.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
Eyelets are one of the dumbest bike inventions ever. IMO.
My latest buy came with them ....Grrrrrrrr.
