Dropped ball bearing in frame
Bikes: 1980 Fuji America, 1982 Motobecane Super Mirage mixte
Quoted: 20 Post(s)
I made an extremely stupid move and accidentally dropped a ball bearing into the frame of my Motobecane mixte when I was changing headset bearings. It rolled down into the frame tubes. It seems to stubbornly refuse to roll out no matter how I rotate the frame around. Anyone have any advice, or should I just leave it there and live with occasional little clanging noises?
Bikes: 1972 Gitane Super Corsa Frankenbike, 1972 Motobecane Le Champion, Motobecane Grand Jubile, 1980 Bianchi Campione di Italia, 1984 Paramount, Trek 620, Trek 720, Cannondale 3.0, Kestrel 200sci, Kestrel 200EMS, Bob Jackson Tandem
Liked 5 Times
If you can't stand the rattle two ideas:
Expanding foam from hardware store or some glue. Shoot it into the the offending area and then rattle the ball until it gets imbedded in the goo.
Bikes: Trek Boone RSL (2017), Bruce Gordon Chinook, Trek 930 mid 1995ish.
Quoted: 10 Post(s)
I did have an issue with this on my bike at one point. I just used two decently strong rare earth magnets I had laying around to fish it out. Was super easy tbh. I'd try using some magnets if I were you. I actually have them just in case I drop a bearing on the ground or something.
If it went in, it will come out. Have you tried a magnet? I would use magnetic pick up tool.
Quoted: 1639 Post(s)
Liked 829 Times
Use avmagnetto coax the bearing down the tubes angle towards an opening.
A strong "rare earth" type magnet would be best, if you can find one......
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
They have various applications. If you have an old PC hard drive, that you're done with, they'll be two in there, about the size of a quarter.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
I used a few drops of glue squeezed into the hole and then moved the frame around until the bearing landed in it. Let it set up and now things are quiet.
You know, you've defied the odds by dropping the bearing like that. If you were being paid to make that happen you'd never be able to do it.
Quoted: 569 Post(s)
Liked 582 Times
A shot of large gap foam stopped a chain stay cable tube from rattling 7 or 8 years ago, still no rattle.
FBoD Member at Large
Quoted: 30 Post(s)
Liked 7 Times
This is timely for me. As I was working with the fork of my Crescent I found out I have one of those little balls of brazing material floating around in one of the blades. I bet there's a vent hole I could shoot a tad of the foam into.
Hmmmm.
Hmmmm.
Bikes: 1982 Trek 613, 1988 Panasonic MC 2500, 1981 Schwinn Super Sport, 1975 Raleigh Super Course MKII, 1985 Miyata 210
Quoted: 178 Post(s)
Liked 5 Times
I've got the same problem on the Libéria I've been working on. Seems to be brazing in one of the fork blades AND the top tube. No vents that I can see.
Quoted: 30 Post(s)
Liked 7 Times
I haven't ventured out to the garage to look at the fork close yet. I know I've had some forks that have a vent hole. Here to hoping!
Quoted: 20 Post(s)
Bikes: A few
Quoted: 289 Post(s)
Liked 196 Times
Having not used frame saver yet, I thought when this stuff was sprayed into the frame it eventually became very viscous. If so, you would probably eliminate the ball bearing rattle while also preserving the frame
Decrepit Member
Most framebuilders drill vent holes at tubing joints to allow gasses to escape during the brazing process.
Since the OP's bike is a mixte and the twin stays have a smaller diameter than a diamond frame with larger top tube and down tube, the vent holes in the head tube will be smaller. However, if the ball bearing got into stay it should also come out.
Try positioning the frame in a work stand so that the stay is vertical with the head tube at the bottom. Since the stays attach to the head tube off the head tube centerline, the frame should be positioned in the stand so the head tube vent hole for that off center stay is at the bottom. At that point, moving a magnet around inside the head tube in the vicinity of the stay joint may work to get the bearing out.
Luck plays a big part.
This illustration of a head tube vent hole is from a Peugeot catalog.
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
I'd be worried about the foam trapping moisture too.
I'd make every effort to get the bugger out. Failing that, I'd go with Framesaver or Linseed oil.
Yet another reason to switch to needle-bearing headsets.
This isn't at all helpful, but back in my bike shop days you always risked having your shop mates drop a bb down your seat tube if you made the stupid mistake of going to the bathroom while your bike was in a workstand. The trick was to gop 'em up with Phil grease first so they wouldn't necessarily rattle around right away. You tried to see how many you could get down there before the poor sap noticed. More than once the poor sap was me.
The other thing we did was peel the Made in Taiwan stickers off the cheap floor bikes and stick 'em on our buds' high-end Japanese or Italian frames. Back in the early '80s that wasn't a sign of quality...
Fuggedaboutit!
Fuggedaboutit!
Quoted: 1627 Post(s)
Liked 630 Times
Quoted: 20 Post(s)
Thanks for the tips and stories. :-) I even took a hard drive apart to get those magnets, but alas even with them, the ball bearing remained stubborn. It will remain in its hiding place in the frame for now, and travel with me and the Motobecane until such time as I have more patience and stronger magnets.
Quoted: 765 Post(s)
Liked 660 Times
Later edit: A Google search for the exact phrase "more patience and stronger magnets" turned up no hits. So nice work, newblue--you may be the first ever to combine those five words.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Quoted: 20 Post(s)
"More patience and stronger magnets" is a nice phrase, and one you don't see every day.
