105 goes Di2
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 925 Times
I have never ridden a Di2 equipped bike, but one is definitely in my future. I can't wait to see how it integrates with my Garmin. I also look forward to installing a power meter on the new bike. I'm really fascinated by all this new technology.
Likes For TakingMyTime:
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
It's quite unfortunate.
I hope Shimano comes out with a non-series 2x11sp mechanical drivetrain that has rim brakes and hydraulic brakes. Doubt it'll happen, but I can hope. The snob in me would rather ride non-series 2x11 than Tiagra 2x10.
Half a decade ago a 105 groupset cost under $400 shipped from across the pond. Ultegra was under $700 shipped.
This 105 di2 is $1890 retail. That is more than most 105 bikes cost just a couple years ago.
yes yes yes, I am aware that buying in bulk gives OEM better pricing compared to individual retail.
This is less than ideal for all those who like to keep frames running with newer tech. I geek on older steel frames with modern drivetrains, but between di2 and disc, thats quickly becoming difficult.
Likes For mstateglfr:
Quoted: 18883 Post(s)
Liked 10,646 Times
Likes For Seattle Forrest:
Liked 10,646 Times
Quoted: 3241 Post(s)
Liked 2,512 Times
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
I've always said that if they made 105 di2, I'd buy it, and I will (I'm 185lbs, so a few grams in the total system weight doesn't make a difference to me). Already have plans for a new gravel bike (swapping my GRX di2 to the new bike), and then a new road bike, which will be full aero, and 105 di2. Perfect timing.
For those saying there's no benefits to di2, I'll mention a few that make a big difference for me, no cables (I've broken several), shifting under load, shifting while braking. Those alone are enough to justify the cost for me, but different strokes for different folks, ride what works for you.
Likes For Rides4Beer:
Quoted: 9653 Post(s)
Liked 6,365 Times
The synchronized/semi-synchronized shifting is a lure for me.
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Likes For Polaris OBark:
I've been running wireless shifting for almost two years. What sram calls sequential and compensating modes have never appealed to me. I just put a 2-sprocket limit on multi-shifts and use that after a chain ring shift. I could be pedaling out of the saddle in the big ring and get an unexpected shift to the little ring and a double sprocket shift. No thank you. I want total control of my chain ring shifts. I'll take my two lever shifting system over any four lever system. Much easier to
use with winter gloves.
Likes For DaveSSS:
I'm down for it. I'll most likely never own a set unless I buy used in about a decade, but I think it's cool as hell.
I would guess, and it's totally a guess, that Tiagra and lower will remain mechanical but will eventually move to 11 or 12 spd in the rear.
People that get 105 and up group sets tend to ride more and will see the benefit, while often time Tiagra and lower aren't ridden as often and battery charging becomes a detriment.
Unfortunately, this may effectively signal the end of advancement for mechanical drivetrains from Shimano.
Bike parts do not wear out for the most part and so Shimano needs a new gimmick to increase sales (normally). My first electronic addition to a bike was a Cateye computer that provided speed and cadence information and the battery lasted more than a year before needing to be replaced. Now I have a Wahoo that needs weekly recharging and a smartphone that needs daily recharging and a road e-bike that needs to be recharged and a Varia radar that also needs to be repowered. The last thing I want to do is add yet another device that I need to monitor its charge state and deal with before I ride.
If the other devices need to be charged it is not going to preclude my going from a ride and I have a standard road bike if the e-bike charge is too low. That would not be true for Di2 components.
Likes For Calsun:
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
I always thought that the reduced complexity of the electronic gizmo should mean it's cheaper to make than the clockwork inside a normal shifter.
Tiagra here I come.
Tiagra here I come.
Likes For znomit:
Liked 2,512 Times
Edit: Is that a proprietary seatpost/seattube also?
Quoted: 20810 Post(s)
Liked 9,456 Times
No, that's not correct. It comes with 51mm deep, 23mm internal width carbon rims with DT Swiss hubs. They go for about $1500 separately.
Likes For WhyFi:
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
People will buy this and OEM demand will be high. Eventually electronic drivetrains will be incorporated with a pedal assist. How much more interesting will pro cycling be when everyone is on pedal assist? Doing 40-50 on the flats and 20 Mph up the Tourmalet.
Liked 6,365 Times
The new Madone is SLR line only. There will likely be a Madone SL with 105 Di2 that will be far less than $8k.
Liked 3,443 Times
BikeSnob loves it too,
Liked 2,512 Times
Seems like Di2 has some shifter buttons you can install to shift away from the brifters. Will the system work using those without the brifters installed?
Liked 10,646 Times
Sounds awesome! Let's allow doping too. Let's see how fast humans can really go on a bike. Maybe we can call it "racing." 👍
Quoted: 406 Post(s)
Liked 389 Times
No need to dope. But the viewers will line up. Imaging a crash with everybody going 40-50 mph. That is the sort of carnage that Hollywood loves. Maybe give them all guns and breasts. Call it American style.
Likes For bamboobike4:
Liked 3,443 Times
Liked 10,646 Times
No need to crash. Let's just have a race where the goal is to see how fast a person can go on a bike.
