For the love of English 3 speeds...
Quoted: 3811 Post(s)
Liked 6,707 Times
Bikes: '68 Raleigh Suberbe, '92 (German) Centurion Equipe, '85 Schwinn Peloton, 1983ish Zunow Road Racer project, '69 Squanch Super Tourer, 1980 Bianchi Super Corsa, '82 Austro-Daimler Vent Noir, '89 Miyata 914 project, 1982ish Bianchi Rallye
Quoted: 294 Post(s)
Liked 9 Times
You can go as big as a 26t rear cog if you purchase from BikeSmith Design. Any cog made for the Shimano Nexus rear hub should work, such as this 22t one from Niagara.
Count Orlok Member
I "adopted" "Miss Molly" a likely 1972 Raleigh Twenty in almost new all original condition. Woman bought it from her neighbor whose husband had passed away. He took it in their RV and rode it around while traveling. She replaced the brake pads, installed Schwalbe 20" x 1.5 tires (406 - smaller 20" wheels), repacked the lower headset and front wheel hub. She bought a cotter press but could not get the cotters out, so she wanted to sell it. There was a torn up sticker on it from "Dicks" bicycle shop in Vancouver, WA, which no longer exists, so it's a local bike.
Chainring chrome is spotless with no rust or wear on the teeth, and bottom bracket spindle & races are pristine, however there was a ball bearing "half" inside - the other half fell out when she was working on the bike. Never knew ball bearings could break in half. She had dripped Tri-flo down the seat tube to get some sort of lubrication into the bottom bracket.
It definitely needs new cables, but I really want to keep the housings because they are like new. Brakes will be alright, but with the shifter I'll either have to use JB Weld or use a clamp on end. I wish I could get some lube in there, but can't, so ...
"Miss Molly" R20 by velocivixen, on Flickr
@gna - Thanks. I trued the wheels today. The rear was out of dish by about 1/3" or so with low tensions. The wheel has 36 spokes and they're short so the tensionometer didn't have enough spoke to grab onto. So I focused on radial, lateral, dish then used sound to see if the spokes were generally similar to one another. They're better than they were.
I also replaced the shift cable - it was pretty gummed up. Kept the white housing - used whitewall tire cleaner on them to brighten them up.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
@thumpism - that's a nice bike. That shade of blue is one I've never seen before - it's quite luxurious looking color. Very nice.
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
What a fortuitous juxtaposition! These two posts speak volumes about the state of the hobby today:
So what, about $300 on top of whatever it cost you for the bike? Plus many hours of Quality Time out in the shop, recommissioning?
Or:
From the ad for the Raleigh Haskell: Classic City Styled High Tensile Frame and Fork, Rack & Fender Ready
Only $600 for for a bike to which you will still have to add at least $300 to "finish"? Notice that the ad doesn't say whether this is a Sturmey-Archer 5-speed or not. For that price, I would expect at least 4130 Crome-Moly (What is the correct spelling for that, anyway?)
At least they put the right shifter on it.
Seems like a clear choice to me...
Or:
Quoted: 1299 Post(s)
Liked 103 Times
Here's the '68 Superbe I bought a couple months back after a wiping it with an oily rag and lubing all bearings and hubs. Paid $50 for the bike and put another $75 in tires, tubes, saddle, fender bolts, and a sweet grip shift set and cables from from @YoKev.
Notice it has no dynohub, lights, or pump brackets. Sheldon said Superbes only "usually" come with that hub and lights, so I imagine this is how it came from the shop. Which is not to say said shop didn't swap everything to upgrade a return customer's Sport. I've seen other '68 Superbes without pump brackets. There's no sign they were broken off, so I assume the pump brazeon guy was sick in 1968.
Also notice it has a vinyl Raleigh mattress saddle instead of a B72 and no rack or saddlebag. This is solely because you forum members haven't kicked down.
Fun to tool around the hood in, but boy to I need a larger sprocket. What's recommended?
Inflate Hard
Inflate Hard
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 27 Times
I'm curious about the BSA/Sturmey Archer X-type 3-speed hub...how does it differ from the AW?
Quoted: 294 Post(s)
Liked 9 Times
Nice bike. Always liked the bronze green color. Other things are different here too. No fork lock, different graphics on the seat tube and chainguard. Hard to see in the photo, but in 68, Superbes and Sprites got the new short neck stem. This one looks to be the usual no neck stem. Under instead of over shifter cable routing. I guess you can never say with certainty exactly what features you'll find on a Raleigh. There always seem to be exceptions to the rules. With 46T chainwheels, I like using those chrome 22T sturmey archer coaster brake cogs.
The script on the frame matches other '68s but the chainguard script is smaller.
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 857 Times
I recommend a cog from 22 to 24 for all around use and upright riders.
Count Orlok Member
Quoted: 7348 Post(s)
Liked 2,473 Times
Chrome molybdenum, or chrome moly for short.
Or:
Or:
At least the Haskell is steel, not aluminum, which has become the default material for lower-priced hybrids. But yeah, it wouldn't have hurt them to put fenders on it. And that shifter looks S-A.
A good option for a kitted out modern steel three speed would be a Linus. I think they are about $600 or so, and have fenders and rear rack included.
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
To be fair, my 1968 Raleigh Superbe would be about $550 in today's dollars, and that was hi-ten. But yes, it had the fenders and all the other bits on it.
This is a challenge I have been thinking of taking on: Can I build a bicycle with quality equal or superior to the Linus Roadster Sport, for less than that asking price of $600. Early research indicates that it won't be possible if I'm paying retail for all the modern upgrade components. However, if I can find modern alloy components on Craigslist or eBay to replace all the steel components of a Raleigh Sport, for example, I just might be able to pull it off.
Sure would be fun to try... I feel a Winter Project coming on!
FWIW, my DL-1 was built for less than that. But it is a distinctly different animal from the lightweight Sports from Raleigh, or Linus. For one thing, there is nothing lightweight about it. I haven't checked yet, but I'm betting he will tip the scales right around fifty pounds, kitted out for Pepin.
P.S. Right after I posted this, I went to CL and found this for $50:
Ad says it needs a new tube for the rear, and it will be good-to-go. And the owner has the chainguard for it. This would make a good starting point, if I didn't already have a frame for the project.
@gna- gonna leave it as is. Just cables & different brake pads @ slightly wider 1.75 Schwalbe Marathons. I already have one that is modified and I want this one just the way it is.
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
I am not thinking that references to high tensile steel are the same as mild carbon steel in the bike world though some may use them interchangeably. Bikes that I have ridden made from high tensile steel throughout are lively and reasonably light constructions. Not bashing on these 3 speeds, they are what they are, but I do not think them to be constructed of high tensile steels as the frames feel relatively dead. Again, not really a bad thing for the intended purpose, as it produces a soft, compliant ride at a modicum of cost. Even at 62yo, I am still more than strong enough, too turn up the watts, and noodle-ize one of these, but why, it simply is not the intention of the bike or the market they were sold to. They are delightful as they were intended when used as intended. These stories of dropping pelotons, I mean, like, I love a tall tale . Frame aside, the SA hub could not take the power input now anymore than it could when I was 14yo and stood on it up the hill.
Quoted: 5790 Post(s)
Liked 2,581 Times
I am not thinking that references to high tensile steel are the same as mild carbon steel in the bike world though some may use them interchangeably. Bikes that I have ridden made from high tensile steel throughout are lively and reasonably light constructions. Not bashing on these 3 speeds, they are what they are, but I do not think them to be constructed of high tensile steels as the frames feel relatively dead. Again, not really a bad thing for the intended purpose, as it produces a soft, compliant ride at a modicum of cost. Even at 62yo, I am still more than strong enough, too turn up the watts, and noodle-ize one of these,......
Keeping tubing diameters the same, frame stiffness is mainly a function of the amount of steel (frame weight). The variation in the index of stiffness (Young's Modulus) is very small comparing various structural steel alloys, as seen in this graph.
The benefit of higher alloys, ie. higher carbon steels or chrome-moly, or similar isn't that they are inherently stiffer, because they're not. It's that they are stronger, allowing thinner, lighter tubes to be equally strong. However, with lower weight you get less stiffness.
Normally the fix would be larger tube diameters, but high end tube walls are already about as they can be without unreasonable risk of denting or buckling under compression.
So, when all is said and done, steel frames made of better steels can be lighter, but that means that frames made of crappy steels will be stiffer.
As far as subjective differences, besides the weight, it's that excess stiffness, not flex, that makes low alloy frames feel dead and ride like trucks.
Note, before folks start screaming, everything above is based on tube dimensions (not counting wall thickness) are the same. That's critical because while the three main tubes are the same diameters on various steel frames, forks and stays vary significantly and that can have a major effect on ride quality.
FB
Chain-L site
FB
Chain-L site
Ah, Linus... Yes, they do have the right idea with their Roadster Sport - and the frame is hi-ten steel with a "cro-mo" downtube. Interesting, that. But you see what they are emulating, right? The classic English 3-speed! But with a Nexus instead of Sturmey-Archer. They both weigh a bit over thirty pounds, although "The All-Steel Bicycle" is almost certainly heavier.
I wrote a blog post about the dearth of fully kitted utility bikes in North America. It was sparked by seeing a Novara Transfer in the wild. It was chro-moly, hub geared, racked, fendered, chainguarded AND had dynamo lighting. REI sold it for about $700 for a time, but they discontinued it and their newer options don't have all the features (or go overboard, like hydraulic disc brakes.) Sure, to many here the frame isn't that attractive, but at least it gets the job done.
https://urbanadventureleague.wordpre...actical-bikes/
https://sheldonbrown.com/retroraleigh...talog-1968.pdf
And I've seen a High Tensile or 20-30 High Carbon sticker on the seat tube of a few Raleigh three speeds:
Quoted: 278 Post(s)
Liked 71 Times
I hope folks here will forgive me for injecting a bit of reality and science into this thread.
That said, anybody ever want to make a Raleigh Sports out of SL tubing, what a sleeper, a 25 pound wolf in sheep clothing. It certainly would not hurt anything but what workman could afford such a thing? One thing, applying a 50 pound force to the BB of my Raleigh results in a noticeably greater deflection than on my Pinarello. Raleigh, heavier yes, stiffer, I cannot agree. But a bloke on his way to work would he care, I doubt it.
So then we are saying that at least later versions of the Sports had a high tensile steel frame or main frame? Hmmm? Well, indeed this is interesting:
I am not saying these are good tires or even slightly better than poor tires, only that they are black and appear to be made from some sort of rubbery like stuff:
https://www.sears.com/bell-sports-701...&blockType=G37
I thought Bell had quit making them. The versions I have are similar but not the same. Added Kevlar?
Well, there is this sad creature awaiting some long overdue attention:
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
I think that the North American bike market has been too focused on "sport" bikes for far too long, so when they make forays into "utility/city" bikes, they either get it wrong or miss details. Compare that to much of the rest of the world, esp Europe, where things like racks, fenders, even lights are all included and are not add-ons afterwards. At least Linus and Public are on to something, and sell well where they are sold.
However, since this is the English 3-speed thread, I'm afraid I have wandered off the path a bit. Sorry.
An Announcement:
I've decided that I am going to take up the challenge to build a superior Lightweight English 3-speed Roadster after all. Elsewhere in C&V there is a thread called "NAME THAT FRAME", in which I try to get some expert to identify a beautifully lugged, hand-built Reynolds 531 frameset that I have recently acquired. So far, the consensus is that it is from the early 1970s, probably British, (maybe American - but built in the British style), from a small, low-volume shop (serial number 352).
This frame is incredible, weighing in at 4.3 lbs, with the fork at 1.5. It is going to be the basis for something I am calling Project John Bull. I have received official recognition for this project from the Gentleman Cyclist's Shirt-Tail Organizer, so it will be eligible for both the ABCE and the Lake Pepin 3-speed Tour. I will keep a build thread here on the C&V forum, all starting as soon as they begin salting the roads again here next winter. This one is going to be fun!
Liked 103 Times
I don't know what alloy Raleigh's 20-30 tubing is, but I don't think it's fair to call it gas pipe or consider it to be a cheap and inferior product. Back before modern welding techniques, the whole point of brazing a frame in formed lugs was to allow for lighter tubing that couldn't stand up to the welding methods at the time. Raleigh went out of it's way to form and seam weld it's own tubing to get just the alloy and dimensions they wanted. True, Raleigh did continue using materials and production techniques long after they were outdated, but that is part of their charm. We can still find 1960s and 70s bikes that are essentially 1920s technology. Lugged 20-30 frames may not live up to the performance standards of modern or exotic alloy frames, but they are still high quality.
Inflate Hard
Inflate Hard
Liked 2,473 Times
@adventurepdx, I agree that Americans don't know a good utilitarian bike. Portland has a lot of bike commuters, no? Don't you see sensible bikes there? We're seeing a big influx here. I give a lot of credit to Linus and Biria. Their bikes make tons of sense. George Bliss owned a shop one block from me. He is out of business for now, but he was the biggest Linus dealer in the US for a while. He helped make them big. He said the Biria is basically the same but with better paint (and maybe he said better workmanship overall) and a higher price. The Biria bikes look good to me. I test rode a non-folding bike with 20" wheels. It was too weird for me to imagine what it's like to ride every day.
@DQRider, I look forward to seeing your new townie bike. I have a 1975 Viscount that I converted to fixed gear with flat handlebars. Unfortunately, the clearance between the chain stays is small. I can fit a 32mm tire in there but not with a fender. It's OK because I don't ride the bike much, but it's awfully fun. It's very lightweight, and it has sport-touring geometry, which is fun and versatile.
