*^*&% sidepull brakes!
I'm getting very frustrated with my C&V rides at the moment and much of it is related to the sidepull brakes.
All of my bikes have them and they will.not.stay.centred no matter what I do. What happens is they end up rubbing after I use them once. Grr. My Superbe is the worst offender - those brakes have to be the worst design ever. I tighten the nut a LOT, but I seems as though the system is rather imperfect (fitted metal washer-thing against head tube) as it allows for some degree of working. I am dreaming up solutions such as some sort of non-slip washer (shelf liner? ) between the frame and the brake. Is this hare-brained?
Right now, all I can do is have the cable adjusted very loose, which is pretty awful. I actually dreamed of canti brakes the other night and am seriously thinking that I should get some sort of everyday bike that has them.
Halp!
Halp!
Bikes: Colnago C40 HP, De Rosa-Primato, Titus Ti FCR, MOOTS YBB-SL, Pogliaghi Pista
Sounds like some adjustments are not correct. Especially if all of your sidepull brakes are jacked on all your bikes.
incazzare.
It's easier if you can get a 2nd person to help you. They can pinch the calipers tight against the rim, ensuring they're centered and tight, while you tighten down the nut. Then you can back off the calipers with the adjuster. That's how I do it, anyway.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
You need to install a star brake washer between the caliper and the frame, or adapter. Also need the park brake caliper tool to hold it in position while you tighten the nut. One trick I've used is after you center the brake, remove the wheel, accuate the brake just to see if both arms move together as they should. They both should squeeze and release the same, if not the brake cable housing could be too long or too short.
Star washer.
Park tool brake wrench, OBW-3
https://www.parktool.com/product/offs...e-wrench-obw-3
Star washer.
missing in action
Quoted: 42 Post(s)
Liked 49 Times
Star washer.
Star washer.
Bikes: 1985 Eddy Merckx Corsa Extra, 1978 Schwinn Super Letour 12.2, Schwinn Paramount PDG 50, 1992 Schwinn Paramount PDG 3, Sears ToteCycle in the works
I just got the OBW-3 from my LBS. Ten bucks well spent. Highly recommended.
Quoted: 17 Post(s)
Liked 42 Times
The PArk Tool brake wrench is a big help on some of them - but it will not fit some calipers due to tight clearances.
In those cases you can try budging the the pivot by whacking down on the spring with a drift - this often works if you can calibrate your arm well enough.
There are also a variety of third hand tools available (if a second person isn't) - This definitely makes centering a caliper much easier.
With the right method and tools, it is possible to center almost any side-pull caliper.
PS +1 to Michael Angelo's advice on the import of getting the brake housing to just kiss the adjuster w/o pushing or pulling.
Also I want to try his star washer idea for myself.
- Auchen
- Auchen
incazzare.
Ooo, that wrench would mean I wouldn't have to ask my girlfriend for help every time, eh? Cool.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Most better quality sidepulls should be easier to keep centered because they usually have much better pivot designs that have smoother action. and will return to center better than cheaper made sidepulls with crude pivot bearing designs. I never owned Superbe sidepulls, but I would be surprised if I cannot keep it centered on a bike. All my sidepulls since the 80's were no problem when it comes to keeping them centered. Also check your brake cable routing and make sure that the sterring action on the front end does ot pull on thern too much which could also pull your calipers off center.
Chombi
Chombi
Bikes: '93 Bridgestone RB-1, '91 Specialized Allez Epic, '85 Raleigh Team Pro, '78 Andre Bertin, early '90s F. Moser Leader AX , '85 Centurion Equipe, '98 Litespeed Tuscany, '89 Klein Quantum, '80 Nishiki Superbe, '83 Peckham, '84 Fuji Opus III
Liked 12 Times
The Campy star washer at a $1.00 each is the single best value item Campy makes. All my problems with centering brakes disappeared when I started using them between frame/fork and the caliper. They really lock and hold position without over tightening.
Worth every penny.
J
Worth every penny.
J
Quoted: 19 Post(s)
Liked 11 Times
Rebuild them if you haven't already, there are alot of sufaces contacting each other which can cause problems if they are not clean.
Quoted: 83 Post(s)
Liked 13 Times
After centering and tightening the pivot bolt correctly. A drop of light oil where the spring contacts the caliper arms, and as mentioned before a sharp whack to the top of the spring opposite the side that is rubbing with a brass drift and hammer.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12775 Post(s)
Liked 7,693 Times
rookgirl, if you're lucky some of your brakes will have wrench flats on that part that the bolt and the spring go through. If they do you can use cone wrenches to get on that while you tighten bolt. Usually 14 or 15mm.
I just got a bike that doesn't have wrench flats on that part - I gotta get one of those OBW-3s. Or maybe just some different brakes...
Quoted: 34 Post(s)
Liked 8 Times
When the brakes don't have wrench flats, another trick is to remove the wheel and over-correct as you are tightening the bolt. Pull and release a couple, times, put back the wheel and adjust.
Bikes: Casati, Look, Torelli, Ridley, and a bunch of steel bikes from the 80s and the 90s..
Quoted: 11 Post(s)
tap the spring with a screw driver and it will stay canter, but not always. I have never had issues with Superb. forget the third hand tool, unless you want it. Use an old toe strap. I think there is a nut you can hold while tightening the bolt to make it center. Its a very adjustment, you may be doing it wrong.
Quoted: 7348 Post(s)
Liked 2,471 Times
Centering it and tightening the nut won't work. That's because the brake and fork already have a preferred position that they've carved into each other. You can't see the notches because they so small.
Whack one spring, as described above. Most of the time, this doesn't weaken the spring; it rotates the whole caliper, allowing new tiny notches. And if it does weaken the spring, that's ok, too.
Do oil the spring where it meets the arms.
Sidepulls are really an excellent design. Once you get the hang of it, they're easy to maintain.
Most of the techniques above won't work. You can't loosen the nut and reposition and tighten the nut.
Quoted: 1858 Post(s)
Liked 664 Times
Liked 664 Times
Quoted: 78 Post(s)
Liked 30 Times
My LBS sells those star washers, If I only need a few. I usually get them for free.
