Short cage RD with triple front?
Oldie
Bikes: Lance Exodus Europe, Univega Sportour, Motobecane Cafe Latte
My used group package has arrived this morning.
This is all the stuff: https://www.flickr.com/photos/klenger...7627712361128/
My question is whether I will be able to use the Dura-Ace short cage RD to go with that triple front and one of those two cassettes? Will the RD be able to pick up the chain slack?
Lula Mae = 15 lbs.
Bikes: 2011 Trek Madone 6.5 w/SRAM Red 22
IIRC, triple chainrings typically need a long cage rear derailleur.
Oldie
I was afraid of that! I was hoping to use that triple, but still enjoy the crisper shifting of the short cage RD. Well, so be it.
I may have to put that triple crank on Ebay, and look for a double to replace it. Can I then use the 12-27 10-Speed cassette?
One more question:
The BB turns, but does not spin. Is that just because the grease is old and stiff?
Can I recondition that or should I buy another one?
One more question:
Lula Mae = 15 lbs.
You'd have to get a "compact" double chainring/crank to somewhat equate to a triple. You will tend to shift back-and-forth between compact's chanrings though. I have a short cage RD, 12-27 cass, and 50/34 compact crank.
However, a long cage RD is a cheaper alternative than going compact.
Lula Mae = 15 lbs.
AFAIK, BB's I've held (DA, Ultegra internal ones) can be turned, but do really spin. My guess is once assembled with cranks in frame, the weight of the cranks and seating bb shell helps with the ability to make 'em spin.
Oldie
Oldie
I see. But would it not be a good opportunity to recondition it while it is out? Is that a tough job?
Shimano is designing to sell replacements, not serviceability.
External Bearing assemblies are fairly low cost.
you have time, bike shops don't, so then a replacement is installed.
can you even see where a seal would come out?
now Phil Wood , and Chris King have aftermarket External BB
they May have designed theirs for serviceability.
Wookie Jesus inspires me.
I've only reassembled FSA MegaExo BBs. you just pop the seals off to the cups/bearing cartridges and then clean them out with some solvent and a tooth brush. Squirt new grease in and it will be (kind of) good as new. Never done it with the Shimano ones though.
Oldie
OK then, if I do choose replacement, should I go with a cheapo like this: https://www.ebay.com/itm/200620958320...84.m1423.l2648
or with the Shimano: https://www.ebay.com/itm/2011-Shimano...item3369914e17
Quoted: 2026 Post(s)
Liked 1,096 Times
Yes, you can use a short cage rear derailleur with a triple crank set and a 12x27 cassette (total teeth = (53-30) + (27-12) = 38) BUT you will have to avoid the granny ring with several of the smallest cogs. Shimano claims the short cage RD-7800 will wrap 28 total teeth so you would have to limit the granny to the 21 tooth or larger cogs.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Oldie
Oldie
I think I'll get the Ultegra BB, it's only $30 and sure to be right for the crank I have.
Señor Member
I got a Chris King BB. I love how you don't have to remove or replace any seals to service the BB-- Just use their grease injector tool to flush out old contaminated grease while injecting fresh clean grease at the same time.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
SE Wis
Liked 3,401 Times
The instructions you'll need should be around here.
https://techdocs.shimano.com/techdocs...&bmUID=iS193Zw
Make sure the crank came with all the spacers like #10 and #16
https://techdocs.shimano.com/media/te...9830621036.pdf
Not to mention the spacer for the cassette
