Short or long cage for the RD?
Hello everyone,
I'm currently trying to figure out which groupset to get for my first road frame, and one of the things I'm dubious about is what type of rear deraileur to get, whether I should go with a long cage, or a short one.
Is it totally dependent on which cassette I pair it up with?
I'd like to eventually try both a 11-25 and 11-28 cassette, so I'm guessing getting a long RD is a safer bet? Or would the long cage perform poorly with a smaller, 11-25 cassette?
Thanks much for your opinions!
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
It's more about the cranks. Short with double, Long with triple. Most derailers will handle 28T no problemo, even the short cage Shimano 105 RD I have that's only rated to 27T.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
I have a 53 front and 27 back with a short rd.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Portland Fred
Short is fine for your casette but get the long if you have a triple up front. If you think you might someday get one of those 34 tooth pie plate cassettes, you'll want an MTB RD that works with your shifters
Long cage will work fine with a smaller cassette. Think of it this way, it wouldn't be too useful if it only worked with the big cogs...
I'm definitely going with a double standard crankset (172.5mm 53/39). Perhaps an 11-32 cassette since like this one would give me better range while on the big ring? (my intended use is flat terrain almost exclusively)
moth -----> flame
Bikes: 11 CAAD 10-4, 07 Specialized Roubaix Comp, 98 Peugeot Horizon
Short cage will work fine with a 53/39 and 11-28. You'll likely need a long or mid cage RD for a bigger cassette though. Long cage will work just fine with smaller cassettes - after all an 11-28 goes all the way to, well, 11. I'm not sure why you'd get a standard double though if you need a 32, why not get a compact double with closer spacing of an 11-28?
BF, in a nutshell
BF, in a nutshell
I'm guessing in time I'd favor closer spacing between shifts, but for now I still want to have the 53T option for the higher shifts.
* In fact, Im wondering if I can get an 11 speed-specific 55T or 56T outer ring, just to have as a spare that is, along with an appropriately cut spare chain..
...Just as I'm eager to try different things out, and I'm a fan of high gears -even though my knees disagree
moth -----> flame
Whatever floats your boat, but has been said many, many times around here, 50x11 is a plenty big gear for some darn fast/strong riders.
BF, in a nutshell
BF, in a nutshell
Well, over time I'd like to add some aerobar extensions as well, and pretend I'm on a TT while on my commute..
I'd like to try out different stuff more than anything else, really. I could even end up settling for a double compact crank, later on..
Bikes: "26" kona kula watt team carbon, "700c" colnago CLX, "700" colnago c59
My shimano 10 spd long cage with 30t rear and triple at front work smoothly, shimano short cage max is 28t with double at front should works fine.
Bikes: Giant
I have a 52T crank and 28T back with a long shimano RD.And,I haven't found any problem with it.The rear deraileur works well.
Ghost Ryding 24/7
Bikes: Giant Defy with Dura Ace group, & Ksyrium SL's,Specialized Allez Shimano mixed/mashed,2011 Opus Sentiero,2008 Kona Jake the Snake,Custom built track/fixed,Stumpy Hartail,Kuwahara/ET bike.
11-25 is perfect for flats, 32 is good if your have some epic climbs to bail you out of, but I don't really see a need on the flats.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
This is going to be very strange gearing.
Quoted: 6556 Post(s)
Liked 58 Times
OP, for a 32 tooth cassette with double crank, you don't want a long RD, you want a medium RD like the Wi-Fli stuff from SRAM. Long is for big rear and triple front. Short is for regular rear and double front. Medium is for big(ger) rear and double front. Keep the RD as small as possible to optimize shifting.
