Low back pain and bike setup
Ellensburg, WA
Bikes: See my signature
Quoted: 313 Post(s)
Liked 458 Times
At 51, I never thought I'd be posting this question but here goes. I was recently diagnosed with "severe stenosis" in my lower back at L4/L5 including minor bulging of two disks and nerve impingement resulting in sciatica (pain into the legs). I have played hard, riden hard and lifted heavy for many years and I guess it's catching up to me much sooner than expected.
I am still lifting weights but have changed many of the exercises to ones that aren't stressing the back as much or are done seated. I still like/want to ride and most of my bikes have been set up with a little longer stem for more agressive position because, as mentioned above, I like to ride hard. The last time out was just a moderate ride but the low back muscles went into enough spasms that I was pretty uncomfortable for three days.
Obviously, my bike set up is going to need to change (more upright) as well as my riding style. Riding on the indoor trainer has not been a problem so far but I don't want to limit my riding to that.
For those dealing with similar low back issues, what have you done to work through a bike setup that works? Stems are one area to address, what else?
1984 Gitane Tour de France; 1968 Peugeot PL8; 1982 Nishiki Marina 12; 1984 Peugeot PSV; 1993 Trek 950 mtb; 1983 Vitus 979; Colnago Super, mid-80's Bianchi Veloce, 1984 or 85 Vitus 979
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
The Forward Lean on a road bike increased my core strength and worked fine for me.
Setting up straight Never worked for me.
Fred "The Real Fred"
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
I have a mild scoliosis and a young adulthood of likewise playing hard and long time working on my feet have given me a troublesome back. I get back spasms pretty regularly on longer rides, but that has really been an issue for me for years. I haven't altered my bike setup that much except maybe raise my stem some and on my bikes with threadless stems, flip it to get more rise. That being said I'm often just as comfortable riding in the drops as on the top. I have developed a preference for shallower drop bars however.
I manage the back issue by popping 600 or 800 mg Motrin before a longer ride, stopping every hour or so to stretch out the back. There's an old adage that low back pain means tired legs and that makes sense to me as the main hip flexors are anchored in your lumbar spine. So simply getting in better riding condition might help. A good back stretch and exercise regimen is helpful also i.e. crunches, leg extensions, yoga stretches.
Mike J
Bikes: 1975 Peugeot PX-50L, 1971 Peugeot PX-10, 1974 Peugeot PX-8
Quoted: 392 Post(s)
Liked 6 Times
I've gone through a couple periods with severe back pain, and the only relief I got was with laying on my back and raising my knees towards my chest. Thinking of how that relief position might apply to riding, it would mean allowing your knees to be brought further up (more bend in the knees at full stretch), so possibly lowering the seat a bit to get a little more bend in your knees might help. I know that if I stand straight up for long periods of time without bending my back, like walking around in a shopping center or at a flea market, my back tends to seize up. The same applies to my riding, so a more vertical position is much more painful for me. I almost never ride in the drops (by the way, I'm 62), and I've found that riding on the hoods is my comfort position.
Try lowering the saddle a tad, and riding less in the drops.
Ellensburg, WA
Quoted: 313 Post(s)
Liked 458 Times
Quoted: 1074 Post(s)
Liked 295 Times
I've got reduced flexibility in my lower back since ages(and I'm younger than you).
There really was no other cure for long rides and tolerably discomfort than going for a considerably shorter stem.
I've got good/excessive mobility higher up my back, so overall aero hasn't changed much.
Mike J
Quoted: 392 Post(s)
Liked 6 Times
- it's fine line there since I've had 3 knee surgeries too.
Quoted: 18378 Post(s)
Liked 4,512 Times
When I first built up the Litespeed with a little extra drop than I was used to, it took a few hundred miles to really get used to it. Now it is fine.
So, if you've been off of the bike for a while, or making changes, don't give up immediately. As mentioned above, the roadie posture may help strengthen the back, especially if you don't put too much weight on the hands.
I've had chronic low back pain for as long as I can remember (especially morning stiffness). What has really helped it, oddly enough, is sleeping in a lazy-boy chair.
Ellensburg, WA
Quoted: 313 Post(s)
Liked 458 Times
Funny you mention that, most days I wake up pretty stiff between 2 and 4 am and walk over to my shop, get situated in my old wing back recliner and go back to sleep for a few hours.
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
I had a bulging disk injury, L4 to L5, about 20 years ago. Since then, I periodically get related lower back pain and/or pain/tightness down through my right thigh. I've only had 3 or 4 really bad incidents with back spasms since. I also lift, with varying degrees of interest. Since the injury, I've gone to doing circuit training with lower weights and being especially cautious with my ergonomics. When I do re-injure my back, it's usually doing something minor like picking up a dropped pencil from the floor.
I've done nothing with changing my riding setup, without any issue. However, I've always been more accustomed to riding the top of the bar or hoods. I actually find riding to be therapeutic for my back and seem to have issues during the periods when I'm not riding (like over the winter).
To echo jj1091, stretching the hamstrings and glutes is very helpful to me. In particular I try to do these before bed and in the morning.
This one stretches the muscles straight back.
This one stretches the outside area of the muscles, out towards the hip, and helps me when I get sciatic pain radiating to the hip.
This one is like the reverse of standing and touching your toes, but it is great for isolating the glutes and hams. I usually use a 2" leather belt to pull on.
Same stretch with help is even more effective. Either way you do it, try to keep the knee locked straight.
Additionally, when I'm in the shower I'll stretch by trying to touch my toes, with my knees locked, and hold that position with the hot water hitting my lower back.
There are other stretches you can research online as well. Finally, when you're picking something up, or bending over for some reason, ALWAYS bend your knees so your lower back doesn't bear all the strain of that motion.
I've had back problems for about 15 years(L5-S1 disk). A neurologist even suggested surgery. When I told him "NO". His reply was: "You'll be back". Stretching, stretching, stretching. It works. I've had no surgery and can ride pretty much all day with no pain. I still get stiffness after the ride, but it's not bad.
Edit: And don't sleep on your stomach.
Quoted: 2588 Post(s)
Liked 4,824 Times
Subbed. I need help, too!
Nothing to suggest as I've not found any solutions for my similar issue. PT is on the horizon, tho (Monday), so fingers crossed
Hopefully you find something that works, too, Scott!
DD
DD
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
1. Rubbing the lower back area.
2. Heat therapy.
3. TENS stimulation.
4. The above stretches.
and...
drumroll...
5. Riding a stationary bicycle.
Quoted: 7350 Post(s)
Liked 2,475 Times
All the suggestions here are good. Another very helpful thing is to walk. Walking can loosen you up in a good way. Having a dog has improved my health, and we don't even walk that much. She's a greyhound, and greyhounds need less walking than any other breed.
I have L4/5 trouble as well, mainly manifest as sciatica. I feel it a lot in the right glute and hamstring. If I try to push too big a gear that can set it off. If I am riding and it gets bad, a couple minutes off the bike walking around generally takes care of it.
I have also gone to a shorter stem and shallow drop bar. Where I used to have a slammed 100mm stem and Cinelli 66 bars, I now have an 80mm stem at full extension and Nitto Randos. The difference is considerable.
You might also check around the >50 subforum. Probably lots of back discussion there.
Quoted: 913 Post(s)
Liked 515 Times
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,928 Times
Welcome to early Middle Age!!
Sugar "Kane" Kowalczyk
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times
I cracked 3 lower vertebrae sledding with my kids in 2008. I was misdiagnosed by a "country" hospital and did not get the correct diagnosis until 3 weeks later. Lots of pain. Everything started healing in that time and I was told by an orthopedic surgeon that surgery was a greater risk than letting it heal "as is" and working with it as best I could. I will be 50 this year.
It became apparent to me pretty quickly that I needed to start some kind of regular exercise program. It had to be one that would allow me to progress at a pace that would not re-injure the area. My mobility was diminishing and the pain was increasing.
I took a chance on a hot yoga class out of desperation. At first, it was really strange to me. That said, it was challenging enough that it kept my interest but I could progress at a pace that I did not re-injure myself.
Regular attendance allowed me to build flexibility, core strength and stamina. Now about 5 years in, I go once a week to yoga and do weight work outs with kettle bells, push ups, planking etc. to maintain core strength. Yoga got me back in the game.
I don't think the yoga was "magic". I just think it gave me something to work at on a regular basis and it was and still is challenging. You compete with yourself. Kind of like randonneuring.
Bars level with saddle for me:
[IMG][/IMG]
[IMG][/IMG]
Bikes: 2001 LeMond Nevada City, ‘92 Merlin Titanium, '84 Torpado Super Strada, ‘84 Schwinn Tempo, '81 Bianchi Limites, '73 Raleigh Supercourse
Quoted: 161 Post(s)
Liked 69 Times
I'm right there with you BG. Here is my most comfortable set up.
Sit ups. Lots of sit ups. Proper ones. Strengthen the back and stomach using machines , not free weights. No wallet in your rear pocket, ever. I herniated those discs long ago in life. You learn to sit right, proper shoes, proper standing positions. Some bikes just hurt. Road Vibration. I had an Aluminum Trek that just plain killed me. My Cannondale, with big tires seems fine.
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
Liked 4,512 Times
A few additional thoughts.
For "normal" body parts, a little stress isn't bad. Stress is what tells the body it needs to change to get stronger. If you have pathology, that may change the equation somewhat, but you still don't want to ignore strength.
I wear a backpack a lot for errands and commuting. It is handy. But, a pannier setup might be a bit more back friendly, especially with awkward loads.
Slow cadence (mashing) also puts strain on the back muscles, whether that is good or bad is up to the person.
Wiggling, and changing positions while riding (standing, sitting, bar tops, drops, hoods), flexing the back up and down, is all probably good for the back.
Quoted: 556 Post(s)
Liked 132 Times
I am hesitant to post this but.... My advice, for what it's worth? Don't accept advice on what therapies to do from folks on a forum. Saddle and bars set up? Yes. Lower back therapies? No.
In my opinion, the first step is finding out just which nerves are affected. Most insurance companies don't want to pay for it, and doctors knows this. But MRI's and/or CAT scans are probably called for , if you haven't had one yet.
And a visit(s) to a specialist. Insist on it.
Quoted: 472 Post(s)
Liked 1,028 Times
I do a workout routine through the winter. The rest of the year yard work is adequate. The winter routine starts with around 45 minutes on either the stationary or the rollers then a combination of stretching and dumb bells, though only 10lbs each and much care about how that is done. My skinny body gave up on strength building ages ago so I'm now just focused on flexibility, core strength and conditioning. My routine is a cycle of about 20 exercises, three sets. Real boring. Tunes help.
As to cycling, I'm convinced that it has been the greatest contributor to my minimal back pain and the elimination of my sciatica issue. As others have said, good core strength, flexible hamstrings and the basic pedaling benefit to the nerves tracking through the butt and down the legs. My bars are an inch or so lower than my saddles and I actually spend quite a bit of time in the drops. When I'm on my stationary trainer I'm always in the drops. I've said before - "I ride the drops so I can when I need to". This recent winter is an example: several rides straight into a 20mph headwind where I was able to stay in the drops for an hour.
One tip that has not been mentioned but has been helpful for me - I've developed the habit of ALWAYS standing up off the saddle when I approach an intersection, watching for traffic, even track standing the bike. I find that those few moments of straightening my back is very helpful and, I assume, any drivers that see me will see me better. I started this when I had much back trouble and have kept it up.
I'm now going on 66 yrs and am in the best shape I've been in in decades. Good luck finding your solution.
Edit: I agree with Rootboy, sound medical advice is best. I first went to my GP then a PT. I'm only passing on what has been beneficial to me and those things I eased carefully into, testing to see what helped vs hurt. We each need to find a unique solution.
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
Sco, sorry to hear of your back troubles. You are not alone.
Of course what works for one person may not be right for another because no two of us are exactly alike. So I always take advice with a grain or two of salt. Or a grain of Ibuprofen if necessary. Nevertheless I'll toss in my two cents.
I'm 68. I have moderate scoliosis, inherited. Decades ago I was told it might be a problem one day. Also apparently developing stenosis. My doctor says I'm 2" shorter than I used to be. (And my thick black hair turned silver and then transparent, but that's a different problem.) No bulging disks but x-rays show bone-bone contact in my lower back. So yeah, it bothers me sometimes, especially right after I wake up. I've never been an athlete but have always tried to stay active. Decades ago my sweetie and I used to run, have also done aerobics, yoga, and weight workouts. No super-heavy free weights though.
So what now? I've been through a few episodes of back and buttock muscle spasms, even developing knots that stayed around for a month or more. PT was a huge help in eliminating the knots and in teaching me how to treat them. Some stretching, some trigger-point pressure, some strengthening exercises. Mostly I make the effort to stay active as if nothing bothers me. One helpful but trivial exercise is getting down on all fours, raising one arm and the opposite leg to horizontal, hold it for 30sec. Do opposite side. Trivial to do but it makes those muscles fire instead of getting lazy. I still do other weight work too, mostly for upper body and abdomen, for example elbow plank held for at least 1 min or as long as 3 min.
As for the bike, riding seems to help my back (and my knees). I've never been able to stretch out on the drops for more than a few seconds. (With German and Italian ancestors I have a Mediterranean build and northern European flexibility, the best of both worlds!) But some forward bend helps the back as long as I don't overstretch the muscles. My handlebars are generally even with my saddles, or a bit lower if the reach is less. I mostly ride the hoods or bends.
As I've told my nephews, the day I stop doing something is the day I start not being able to. So unless there is a tangible medical issue, consider PT and keep doing what you like.
Real cyclists use toe clips.
jimmuller
jimmuller
