To re-tape handlebar or to leave?
I’m not sure, I have a 1970 French tourer that has the original tape. Is re-taping going to drag the look down?
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
If the tape is still in decent shape I would consider cleaning it first, and see how I like it. That tape has a certain charm, IMHO.
Quoted: 874 Post(s)
Liked 2,287 Times
Certainly clean it best you can and see how you like it. Light colored tape is hard to keep clean but looks great. I have a bike that came with white cloth tape and it looked nice as it got some mild off color to it. When it got real dirty , I cleaned it with Dawn dish liquid and warm water and the set it out to dry. It looks great again but not like new tape.
Likes For Kabuki12:
elcraft
Gaps at brake hoods make me think this wasn’t a factory tape job. Or is my recollection clouded by Nostalgia? Cloth Velox Tressostar, etc. would look real nice. I am not sure 45 + year old plastic tape is a truly appreciated as an indicator of undisturbed vintage-ness.
Likes For elcraft:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
Tape, chains and tires are consumables. If you're into period correctness, consider cotton tape with shellac on top for a 70's french tourer.
Likes For gugie:
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
That tape looks like it's still good, but I don't know if it was that creme color from the factory, or is just blanched. I'd clean it up and ride with it and see how it feels. Otherwise, you should be able to find something similar from Benotto, Hunt-Wylde or OGK.
Quoted: 3464 Post(s)
Liked 2,829 Times
cloth tape might have had extra attention
with half hood Mafac levers - the only was to control things was to tape with the lever bodies off. Quite a bit of work as the 9mm retaining nut really wants the room, the cable has to be removed or really loose.
in a bike shop setting way too much time save for Herse or Singer.
as to leaving the tape, fresh tape will make the rest of the bike appear shabby. Depends on your clean and polish goal.
noting also that French bars of the era were really narrow. Like 36 cm ctc often.
Likes For repechage:
in the 70’s plastic tape was a one go, no sissy strips at the levers.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
Wipe, Clean and Now Refreshed....Good fo another 20.
Best, Ben
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times
Of course new tape and wet sand the frame with a very fine paper. Old tape is disgusting and can be completely unsafe if there's corrosion on the bars.
Likes For SurferRosa:
Clean the tape. As much as I disliked that plastic tape at the time, ( the tape that came stock on my 74 PX10 ended up wrapping the handle of our lawn mover and proved Impervious to gas , oil, sweat, etc) if yours is holding up, keep it. It speaks to the origins of the bike and its time. Even if you replace it with modern plastic, it won’t be the same. You might duplicate the texture but you can’t duplicate the wrapping technique, probably done by some long gone Frenchman with a Galoise hanging from his lips. It’s the one piece of the bike that you can touch and know that some other human ran it though his hands to make sure the job was done.
Likes For Mr. Spadoni:
Quoted: 1372 Post(s)
Liked 1,751 Times
Unless the bicycle's cosmetics are really challenged, new tape will not necessarily drag the look down. Also, I have little like or respect for smooth slippery handle bar tape, such as that presented on the OP's bike.
With both of those thoughts in mind, I would not hesitate to install new handle bar tape. I would go with cloth tape, just to retain the vintage look and appeal. I will also offer a bit of advice, should the OP choose to install cloth tape.
Remove the bars and steering stem, if possible. Remove the old tape. Position the brake levers exactly where he or she wants them to be and then secure the clamps in place with tape. Then remove the handles, leaving the clamps in place. Now, it will be easy to wrap the bars and avoid the unpleasant wrinkling of the tape around the levers. Have a look at the pictures and know that, in my opinion, there is no easier way to tape bars and get really good results...
Position the levers...
Secure clamps in place. I also use silicone seal to prevent the female portion of the clamp from moving...
Now, wrap the handlebar and then install the lever body/hood assembly...
The results usually turn out pretty good (I do NOT recommend using white cloth tape - it dirties up pretty fast)...
If you have or choose to use the Gaslo style of end plug, put one wrap of cloth tape underneath before slipping the end plug into place. Doing so will greatly ensure that the plug stays where it belongs during tape installation and afterwards, during use...
I have been wrapping bars like this for years and have yet to have the job turn out poorly...
Likes For randyjawa:
Quoted: 604 Post(s)
Liked 1,063 Times
Hey, at least it’s top down with no electrical tape to finish it off, I’d leave it.
Tim
Tim
Quoted: 1609 Post(s)
Liked 2,590 Times
Likes For curbtender:
Likes For miamijim:
Quoted: 225 Post(s)
Liked 1,101 Times
Montana, where men are men and sheep are lying little tramps.
Likes For majmt:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
+1. Just knowing that my sweat is enough to start corroding the bars after a few years, it's a good idea to take off the old tape so you can completely know the state of yours.
Likes For ThermionicScott:
Quoted: 1949 Post(s)
Liked 2,010 Times
Leave the tape until the paint looks too good for it. Right now, it doesn't.
Likes For Classtime:
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
Still in two minds about this myself .
do I or dont I
do I or dont I
Liked 2,590 Times
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
I'm putting in a vote for 'new' plastic tape.
My 82 Holdsworth originally had slightly silver plastic tape (I bought one new in 83 and I just about remember), I got a another one a few months back and the tape had gone a nasty yellow colour.
Found some NOS Schwinn "old school silver tinted" on Ebay and studied how the original tape was wrapped (do one side at a time).
1982 Wrapped from the top, figure of 8 round the hoods.
Cheated slightly: I did put some double sided tape at the top starting point, and I've now put one wrap of Sellotape Crystal Clear round the plug end.
Liked 1,751 Times
The red bar tape did not have internal plugs. Rather, the externa Gaslo plugs made it seem more appropriate to wrap from the end of the bar to the center. There was no practical way to insert the tabs into the bars, as can be seen "as found"...
Had I gone top down, the black electrical tape would have, in my mind, looked to be miserably out of place at the bar ends and would have telegraphed the tabs on the Gaslo caps...
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
I ran the black plastic Hunt Wilde bar tape (or, something equally "pro") that came on my late 70's Schwinn, aka "most ridden" hooptie bike" until I had to eventually replace it because it had numerous edge breaks in it, and it looked and felt like it might asplode at any moment, or on any outing. I had even rewrapped the bottom half, below the brake lever, with slightly newer, scavenged tape, tape, which meant I squeezed another year or two of riding out of the wrapping. "Is it great tape?"... "no". But there was a very satisfying self pride thing happening, knowing that I'd worn the tape "smooth" in most used hand positions. I'd say there was an equal amount of gross sloughed hand skin, dried sweat, leavings as experienced with what could be found under decade old cloth bar tape, so I think that consideration aspect is a coin toss. Whatever is found under old bar tape, no matter what the original composition of said bar tape, it's a given that it's going to be 113% grossness. So, take this as a contrarian view, based more on a personal stubbornness, wabi-sabi mindset to a fault, planet savior agenda sorta person, that is diametrically opposed to any aesthetics considerations other viewpoints have offered.
Likes For uncle uncle:
I am leaning heavily towards keeping the old tape. It seems in keeping with the general patina of the frame.
Thank you to everyone for all of your differing insights, your opinions were extremely helpful.
I used T-Cut to clean the paint and it got a lot of the grime and discolouration off but I didn’t want to push it through fear of reaching the primer. It looks good I think. All except for the foil decals. I think they are a terrible idea and very unsightly.
Likes For PBYO988:
