Maillard Hub Question
1986-87 ish Maillard hubs on a Schwinn Tempo, seems that was a stock choice. Bearings are smooth. It says 'sealed' on the face and wondering if I can pull these and re-grease and not mess up the 'seal'
Quoted: 1311 Post(s)
Liked 1,919 Times
That seal is pressed on the cone and should come off with the cone as it unscrews from the axle. Smiles, MH
Likes For Mad Honk:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3906 Post(s)
Liked 6,517 Times
Yeah, doesn't that "sealed" dust cap spin with the axle?
Unlike removing a vintage Campy Record dust cap, this should be a breeze.
Mad bike riding scientist
Quoted: 6238 Post(s)
Liked 4,246 Times
But that said, the dust cap should be pressed in place and has to be pried out just like most dust caps of that era.
Stuart Black
Stuart Black
Quoted: 4222 Post(s)
Liked 3,910 Times
When working with these stamped steel dust caps/seals they can easily be deformed when prying them off/out. I have used sockets, and a hammer, of varying sizes to act as a form to reestablish the cap's flat/roundness. Sometimes a slight prying out of the cap's ring/edge is needed to stay put in the shell or over the cons. Needle nose pliers works well for this trick.
BTW if you do take these hubs apart carefully track/record the size and number of balls used. Some of these hubs had odd sizes or numbers. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1147 Post(s)
Liked 1,773 Times
For removing the sealed cap, I use a tire pry on the outer edge and tap from the back with the axel or such. Sometimes I need to rotate the pry when tapping. I can usually remove without distortion.
señor miembro
Liked 6,517 Times
Not helpful.
Not helpful. Read @Mad Honk's post before mine for more info.
@etherhuffer should weigh in with the quick detail. And to answer your question in the op, you don't need to do anything to the seal. Just leave it in place on the cone when you remove one cone (or both) from the axle as the first step in overhauling your hub.
btw, great pic! You can easily tell what's going on here. I wish more posters would include a pic like this. It saves dozens of questions.
The seal spins, so it must be connected to cone. More of a barrier than a seal. I will open this up really gently and clean then replace. Ah, the smell of mineral spirits in the morning. Smells like.....bearings
oh and no picking on cyccocommute! Fellow chemistry nerds stick together!
Likes For etherhuffer:
señor miembro
Liked 6,517 Times
Likes For SurferRosa:
That was meant in good humor, lost in translation to internet. No worries here. My attempt at humor fell flat so apologies here.
Liked 4,246 Times
And, to set you straight, axles don’t spin.
Stuart Black
Stuart Black
señor miembro
Liked 6,517 Times
Liked 4,246 Times
Nope cones don’t spin either. Thank you for pointing that out.
Stuart Black
Stuart Black
Likes For cyccommute:
señor miembro
Liked 6,517 Times
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 678 Post(s)
Liked 750 Times
On autos, spindles are stationary and axles rotate. On bikes, axles are stationary and spindles rotate. A little confusion is understandable.
señor miembro
Liked 6,517 Times
Liked 4,246 Times
Stuart Black
Stuart Black
señor miembro
Liked 6,517 Times
Liked 4,246 Times
Wow back at ya! You can spin the wheel or you can spin the axle. Since the ultimate goal is to spin the wheel while it is attached to the bicycle so as to propel the bike down the road, it doesn’t matter than it spins when dismounted from the wheel. In the end, the axle (and cones and dust cap if the cap is attached to the cones) is not the spinny bit.
Stuart Black
Stuart Black
señor miembro
Liked 6,517 Times
https://en.m.wikipedia.org/wiki/Pedant
"Pedantry can also be an indication of specific developmental disorders. In particular, people with Asperger syndrome."
Quoted: 1873 Post(s)
Liked 692 Times
It was good humor, it didn't fall flat. It's not you, this is par for the course.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Liked 4,246 Times
Stuart Black
Stuart Black
Liked 3,910 Times
AndrewRStewart
AndrewRStewart
señor miembro
Liked 6,517 Times
