Sora disc brake adjustment issue
Quoted: 1074 Post(s)
Liked 295 Times
Hi all,
A friend rolled by asking for help adjusting his Sora (mechanical) disc brakes. And to my embarrassment, I couldn’t get them decent.
The pads looked to have an OK amount of friction material left, but it was still as if they sank too deep into the caliper.
If I set the caliper to where the caliper body just cleared the rotor, it would take nearly the full travel of the brake before the pads contacted the rotor.
Are there different models pads that thicker/thinner?
Quoted: 6193 Post(s)
Liked 4,810 Times
BR-R317's? Probably written on the backside of the brake body.
https://si.shimano.com/api/publish/s...009-02-ENG.pdf
https://si.shimano.com/api/publish/s...001-26-ENG.pdf
https://si.shimano.com/#/en/search/Keyword?name=br-r317
If you can't get it adjusted, then either you are just missing something or the rotor is too worn or the wrong one. But I have a hard time imagining one too worn or too thin so probably that's unlikely.
Liked 295 Times
