swapping out wheels 26 to 700
Bikes: Mongoose Mtn Bike, Trek FS, schwinn mtn bike
We have a Raleigh SC we are wondering if we can swap out our 26" rims and go with 700 size,
LBS said no it wont work, but then he said it would then it was come look at this new tandem..
we are also looking into going with smooth tires on the 26"
Thanks all
tandem cycling bike forum rocks
Thanks all
Quoted: 77 Post(s)
Liked 19 Times
Take a 700c front wheel off a single bike; put it on your Raleigh.
Does the larger 700c wheel fit? Can you adjust the brakes to hit the 700c rim? Nope. End of story.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
try narrower, higher pressure tires with road tread (or no tread). 26", of course
Bikes: Pugsley, fixie commuter, track bike
If your bike has disc brakes and lots of clearance you maybe able to fit 700c wheels. If you have rim brakes it will take an expensive and difficult to find solution to adapt the brake pads to the new position of your rims. Faster 26" wheels are the way to go. There are quite a few choices from 120psi 1" Stelvios to 2.35" Big Apple or Super Moto slicks.
Craig
Craig
'possum killer
Bikes: mountain bike (Litespeed Pisgah), touring bike (Giant Frankenbike), tandem (Burley Samba), fixie (Raleigh Rush Hour)
Liked 8 Times
Here is a link to a Mavic brake adapter designed to allow you to reposition your cantilever brakes for a 700c wheel on a 26" bike. I have no experience with doing so...but if you are interested and the wheels will fit in the frame this might be helpful.
https://www.speedgoat.com/product.asp...t=30&brand=155
Now Wheaties are cheaper than gasoline!
