USB Charger Recommendation
I am looking for USB charger that can take 6 volts input ( 1 positive and 1 negative wire ) from my 6 volt power bank, I looked online and found most are taking 12 volt input.
Quoted: 18378 Post(s)
Liked 4,512 Times
I'm seeing some DC-DC converters for 6-20 or 24v that are pretty cheap. It would be worth trying. You'd need to come up with some kind of enclosure.
https://www.amazon.com/KOOBOOK-DC-DC.../dp/B07SGWRQGX
https://www.ebay.com/itm/323558027885
There is a Busch + Müller USB-Werk AC designed for generators. Is that AC current? But, they're pretty expensive.
https://www.bike-discount.de/en/busc...er-usb-werk-ac
I will go with the 6v - 24v and come up with an enclosure then.
THank you for the links, I don't understand why the ready to plug in electronics for bicycles are very expensive.
Quoted: 3461 Post(s)
Liked 1,467 Times
That was when I learned why the ones for a bike are expensive. I gave up and bought off the shelf ones that were designed to handle the voltage you can get at a high speed descent if you have no load on the circuit.
I do not know if the USB chargers that you can put in a 12v lighter socket will work at only 6v from your battery, but if it does, those are only a few bucks at a dollar store.
I have a dynamo hub that will be wired to a charge controlled that will charge 6 volts battery bank, I am not worried about the increase voltage from the dynamo because the charge controller will regulate that. 6 volts batteries are very common so I am surprised there is plenty of 12v USB chargers but not for the 6v unless you pay arm and leg for it.
Quoted: 33 Post(s)
Liked 75 Times
We use some of the Voltaic power banks for solar driven Raspberry Pi stuff out in the yard. Nominal input is 5V/2A, but am pretty sure they'll handle more than that. Passthrough charging, always-on configurable, has over-charge protection built in. One of these has been in service in an enclosure out in the yard for 3+ years, through temps up to 116F and down to 10F. Pretty light. The Voltaic folks are quite responsive...if you present your use case, they can let you know if what they have woud work for you.
https://voltaicsystems.com/v25/
--Richard
--Richard
--Richard
--Richard
