Suntour FD cable housing stop missing -- workaround?
Quoted: 1088 Post(s)
Liked 1,205 Times
Newbie question:
I just bought a vintage Suntour Cyclone MII FD, but I failed to notice that the cable housing stop was missing (see pic). Will this be impossible to find? Can I work around its absence or craft a suitable/reliable fix?
Thanks...
Thanks...
You can hose clamp/zip tie the housing to the frame in the appropriate spot. It won't work as nicely, and will require fiddling, but will work.
Why not just look for another FD it's not like they are expensive.
using a Plastic under the BB guide you dont need the housing stop.
Quoted: 1438 Post(s)
Liked 1,092 Times
Perhaps the cable housing stop from a Weinmann-style caliper brake could be adapted for use. You would get a barrel adjuster as well.
Liked 1,205 Times
Thanks for these ideas, everyone! I'll let you know how it goes.
Try to find a downtube housing stop at a coop or a old LBS and mount that to the seat tube just below the derailleur . they the clamp style and was use on older bikes for a long time .
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
Some of those Cyclone Mk II derailleurs didn't have integrated cable stops. I have one of the band-on types (as opposed to clamp-on) w/o the stop.
I had this issue with a replacement derailleur I put on a Motobecane and used an Origin 8 single cable stop (around $7-8) as a work-around.
Or you could go old school and try to obtain a bottom bracket guide like this:
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
@ vintage cyclist: Wow. That cable guide is nice!
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Quoted: 4209 Post(s)
Liked 3,875 Times
This isn't a big deal but if that bike were ever to be shown at a concours show it would be a point or more off the bike's score. And if that were the way a race bike were set up and the cable ever slipped off the guide during a race the mechanic would be sorry, maybe out of a job. Andy.
Quoted: 18378 Post(s)
Liked 4,512 Times
Here is your stop.
The upper derailleur, "Sprint" has a non-removable stop, and is unique in that the cable is connected to a fixed bolt, and the hosing stop moves. The derailleur is normally on the big ring when cable is released (lever forward), and shifts into the small ring when the lever is pulled back. So, like the rear, harder with shift lever forward, and easier when shift lever back.
The stop scews out with the lower derailleur as you've shown.
I've thought about cutting a similar stop out of a bolt head, but the heads typically aren't deep enough to be large enough to do it. You could also braze a stop onto a bolt, but it would mess with your angles.
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
Yes, that would work. Thanks again to someone showing me what the manufacture intended for the job.
Here is your stop.
Steel rod, drilled and counter bored, and a Lathe
reducing the larger rod to 5mm then threading it on the lathe
Or a 5 x .8 threading die will make them ..
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For James1964:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
Another solution
Saw another FD cable stop thread going shortly after I was looking at this one. I found something in my parts stash to affect a change to the Cyclone Mkll and thought others might be interested. I have since decided to use a VX front on this build instead. The part is the cable stop end from this brake QR bracket. I think I had a loose one laying around. Threads matched.
Then, a couple washers to get a nice shoulder to tighten to and get a proper alignment, and then add a brake cable barrel adjuster.
Thought this could be helpful for future reference.
Likes For sd5782:
