Rear axle disassembly
Bikes: 1986 Schwinn High Sierra, 1989 Supergo Access Comp, 1989 Nishiki Pinnacle,1990 Trek 750, 1990 Trek 970, 1991 Miyata Quickcross, 1992 Bridgestone RB-2, 2002 Stumpjumper M4 Pro
Quoted: 157 Post(s)
Liked 263 Times
I haven't had good success applying grease/bearings into the lower cluster and then fitting that onto the freewheel body, so what I do is grease that thin freewheel body race (currently threaded to your hub) and load half the bearings there. If you don't know how many bearings came off there, put two less than what will fit. then fit the cluster on top of that. Then place grease and the other half of the bearings onto the race atop the cluster where the lock ring sits. Go skimpy on grease, using only enough to keep the bearings in place. Be sure you haven't added grease to the two pawls.
Likes For SDHawk:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Likes For maddog34:
Quoted: 157 Post(s)
Liked 263 Times
Hi folks, just wanted to report that the operation was a success and the patient is looking good . I made a video cuz I'm too lazy to type:
https://photos.app.goo.gl/pjR6QUB5hcxWKPEv6
Thanks again for all the great advice, it saved the day more than once. Cheers!
ps go Aztecs!
ps go Aztecs!
Likes For SDHawk:
