Fork Rake - will increasing rake by 2mm give a noticable difference?
Hey all,
Wasn't sure what thread to ask this in but I have a Ti road bike that I am needing to change the fork on due to delamination and cracking of the carbon and figured I'd change to a fork that will allow 28c tires.
My current fork has a offset of 43mm with a Axle to Crown Length of 368mm.
The replacement fork I've found is a Columbus Futura with a offset of 45mm and a Axle to Crown Length of 367mm.
Is this enough to make a big difference or will the be essentially the same? I want to change the handling as little as possible as I currently like the way the bike fits and feels.
Any help is appreciated.
Hey all,
Quoted: 4505 Post(s)
Liked 4,991 Times
Hey all,
I found a alternative fork that I really like but it's got a slightly longer Axel to Crown. It's specs are 45mm offset and Axle to Crown of 370mm. Will I notice 3mm height or am I good?
I have found that frame geometry is not that sensitive to minor changes. 2-3mm rake is a minor change, 2-3mm is a minor change.
Quoted: 564 Post(s)
Liked 422 Times
You'll get the same 2-3mm change just from swapping tyres of different brands that all share the same nominal size.
I have some 26x1.50 Bontragers H5 and they are race thin as expected, then I have some 26x1.50 Vittorias that I swear look more like 2.00 and they made an error in the factory as they stamped their nominal size.
Likes For Steel Charlie:
Randomhead
Liked 3,725 Times
Quoted: 7073 Post(s)
Liked 11,153 Times
Likes For Koyote:
Hey all,
So I fittted a Columbus Futura with 45mm rake. The 28c fits with plenty of room to spare on a rim with 25 external width. I've ridden this bike for thousands of miles and I noticed immediately two changes.
1. Improved comfort from a 28c GP5000 vs the old 25c GP5000 and
2. Way better vibration damping on rough tarmac roads.
Any change in geometry (both in the increased rake and the increased axle to crown dimension) definitely had no negative impact and may even be responsible for the better road "feel" I've tried to describe. If anything it feels more stable on fast descents, which may be due to the better vibration damping or maybe due to a miniscule change in trail is the reason, who knows?
What I do know is that it was a good modification as it's measurably improved the ride feel of the bike!
