Visible Crack in Fork
Quoted: 97 Post(s)
Liked 7 Times
In this thread, I am presenting symptoms. I don't how to assess these symptoms. What say you?
Today, I discovered a cracks in both sides of the carbon fiber fork. The cracks are the same on both sides. The crack is straight, affected the outside face and front of the fork. I am sorry the images are blurry.
To confirm the crack is through the carbon fiber, I removed the paint over the crack. Removing the paint revealed the crack is directly over the seam between the metal slug that forms the drop-out and the carbon fiber.
Likes For nomadmax:
Expired Member
Quoted: 3674 Post(s)
Liked 5,433 Times
Not much more to say, time for a new fork.
Likes For shelbyfv:
Blamester
Is it a crack or where two parts meet?
How has it not fallen apart if both sides are actually cracked thru?
Now you have discovered the damage what will you do?
Have you tested it?
Have you tested it?
Quoted: 453 Post(s)
Liked 104 Times
Those forks do look well used, with a lot of chipping to the lowers, replacement for a safety critical part would have probably be a good idea, even it they weren't cracked. now with the work that the OP as done to them, defiantly a case of replacement needed.
Quoted: 645 Post(s)
Liked 797 Times
but the CF itself hasn’t failed - the crack in the paint is where the CF and the metal meet. It’s possible that the metal fitting has become lose in the CF sleeve and that this slight movement has cracked the paint (although the exact same thing happening to both fork legs suggests that this is unlikely). It’s also possible that this is simply the two distinct materials behaving differently - exhibiting different degrees of thermal expansion, for example, that caused the paint at the interface to crack. Regardless, though, if there’s even the possibility that the CF/fork end joint is compromised, the fork is toast. A failure here is a potentially life-changing event.
Quoted: 1104 Post(s)
Liked 1,825 Times
It's a carbon fiber fork.
It's has failed and could do catastrophically if the OP continues to ride it. (this we agree on)
It isn't falling from a plane without a parachute that kills you; it's the deceleration impact once you hit the ground. There is no functional difference except the terror on the way down.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
It's on both sides...the same? It's not structural, I've seen this hundreds of times. I used to have an @Trekbikes.com email address so I have a little experience with it. It's the paint getting brittle and cracking. This is why Trek (and others) only warranty their paint for a year while the frame and fork are lifetime. It happens where dropouts join frames and forks as well as where the OCLV tubes join the lugs. 99% chance this fork is fine and everyone here that has posted otherwise doesn't know what they're talking about. Have an experienced mechanic at a Trek dealer take a look at it.
Likes For cxwrench:
Quoted: 1438 Post(s)
Liked 1,092 Times
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
That was my first thought. That the "crack" is straight, and perpendicular to the axis of the fork blade makes me think it might be a joint where a metal fork end is bonded to the carbon fiber blade. We saw similar "cracks" in the early bonded carbon fiber frames at Trek, where the carbon fiber tubes were bonded to the aluminum frame fittings. Flex across this joint eventually caused the paint to crack, but the joint itself was uncompromised. Check with the manufacturer to learn what they may think.
Likes For JohnDThompson:
Quoted: 1248 Post(s)
Liked 1,323 Times
Classic carbon fear porn as always, by the usual suspects. Dissimilar materials with correspondingly different properties of expansion as well as different flex characteristics causing a crack in the paint. Paint is getting more brittle with age. Too bad you sanded the paint off, fork is fine, have seen this numerous of times.
Likes For Atlas Shrugged:
Expired Member
Liked 5,433 Times
This from the OP "To confirm the crack is through the carbon fiber, I removed the paint over the crack. Removing the paint revealed the crack is directly over the seam between the metal slug that forms the drop-out and the carbon fiber." So more than paint. Maybe he is using the term "crack" to describe a seam/joint but that's not what he said.
Likes For shelbyfv:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
So I think the fork is probably fine. But “probably not going to kill or maim me” would not cut it for me in this case.
Quoted: 1278 Post(s)
Liked 1,392 Times
it looks by all accounts, as many have said, to be a crack in the paint caused by thermal expansion, slight movements over time, etc, in the joint between dissimilar materials. what i see in the underlying fork is not a crack, but a seam.
nonetheless, now it seems to be new fork time.
Quoted: 4806 Post(s)
Liked 3,928 Times
I also think that crack is purely cosmetic. Aluminum and CF have very different reaction to temperature change. The paint has to try to bridge a moving target.
That said, I nearly lost my life to a fork failure and did lose my profession, a great deal of money, years of my life and a lot more. This forks costs what? $200?
Quoted: 714 Post(s)
Liked 800 Times
That is not a crack in the fork. It is just what normally happens when two materials that expand and contract at different rates are joined together. The paint cracks at the joining line.
Quoted: 581 Post(s)
Liked 921 Times
I would have said it looks fine to ride, but then I saw the picture of after OPgot scared and sanded it. I wouldn't ride it now. Further, even if it was covered by warranty before the sanding, it almost definitely isn't now.
Likes For ClydeClydeson:
Quoted: 837 Post(s)
Liked 1,061 Times
Agree that it could be perfectly fine. I say could be so I recommend taking it to 2 or more shops for their opinion. A bicycle CF specialist repair place would be best but you could also try other places that work with CF such as boating repair or golf club repair shops etc. I had an experience of my own with a Reynolds Ouzo fork. Took my aluminum bike to a shop to get my headtube faced for the bearings and the owner/mechanic who it turns out was not a fan of CF told me my fork was cracked near the crown. The shop was a little dim so I decided to take a look when I got home instead of buying a Titanium fork he wanted to sell me. Turns out it was just the seam where the CF met the fork crown. 10k miles and 20 years later it's still fine but my aluminum frame is not since developing cracks in the headtube. Lots of fear about CF that is often, but not always of course, unfounded.
Likes For Crankycrank:
Quoted: 569 Post(s)
Liked 582 Times
I did formal risk assessments when I was working and learned we all have varying degrees of risk tolerance. Risk is simply likelihood times consequence. I think we all can agree that a failure of a fork can be a very serious consequence. While I suspect this was a very low risk cosmetic condition the OP has taken action that has made it more difficult to evaluate the loss of structural integrity (load carrying and transferring capacity) by the manufacturer or other "expert" so at my risk tolerance I would stick a fork in this fork it is done.
Quoted: 97 Post(s)
Liked 7 Times
It is the seam where the two parts meet. I am not certain there is a crack.
When I discovered the crack in the paint is over the seam, I got the idea the fork might be ok. Then again, there must have been movement of the metal with respect to the carbon fiber for the paint to crack. I didn't mention in the OP, I found the same crack in the same spot on both sides of the fork. This had its share of crashes, twice running into curbs, most recently about a year ago. I am sure the cracks in the paint are much more recent, because I look for cracks regularly. I haven't had any crashes since the two I mentioned.
I don't know how to test the bond between the metal and carbon fiber.
Quoted: 97 Post(s)
Liked 7 Times
Good question, you could probably tell if this was the case by tapping either side, and seeing if there was a distinct difference in sound, and also doing the same to the other side. This appears to be the case, given how the OP as sanded the paint off the area
Removing paint does not weaken the part.
Blamester
See does anything move. Bounce up and down on it. Hold the brake on and push it back and forth. Be sensible. Think about what it goes thru when you ride it. Tap test is fine but you want to know will it break when you ride it.
No need to be gentle.
You can't ride a bike if you are not confidant that to fork is going to break.
If you can't be confidant get a new one. You are the one who is going to ride it.
Likes For blamester:
Quoted: 405 Post(s)
Liked 430 Times
If this were my fork, I'd replace it.
Not because it's cracked... it isn't. The line is where the aluminum dropout fitting was glued into the carbon fork blade.
Not even because there's been structural damage to the carbon fiber tubing... there probably hasn't been. (Although I have no confidence in my ability to sand carbon fiber without damaging it.)
I'd replace it because, while I often have conversations with the voices in my head while riding, I wouldn't enjoy it if one of them occasionally whispered, "Hey... what about that fork? You know, if it broke right now, you'd totally die..." just as I'm braking into a hard downhill right-hander. (Yeah, yeah, I know. Sometimes they lie, and they're often wrong. But they don't always lie, and sometimes they're right.)
--Shannon
--Shannon
Likes For ShannonM:
Likes to Ride Far
I would have thought that Step 1 should have been to take some photos of the crack that were IN FOCUS. Step 2 would have been to contact Trek. If Step 2 failed, maybe ask in an internet forum. Do all of this before deciding to sand away all the paint.
