Bottle Cage Mounts - need help
Warehouse Monkey
Quoted: 305 Post(s)
Liked 7 Times
I know those bottle cage mounts are everywhere, but I am looking for the clamp-on steel ones. I want to add a mount on my Tourist under the down-tube and I am coming up short. Suggestions?
'10 Specialized Hardrock
Quoted: 3461 Post(s)
Liked 1,467 Times
Not sure why you want steel.
VO makes the old style straps that used to be supplied with all bottle cages half a century ago. They do not work on all cages but work on some of them.
https://velo-orange.com/products/bottle-cage-clamp
Or you can use hose clamps if the aesthetics are not important to you.
I wanted to put a container under my downtube with my spare tube, a few tools, etc. Used a Blackburn cage and the VO straps in the photo. My bike is not a Windsor Tourist but that should not matter. But if you are concerned you could contact VO first and tell them your tubing diameter to see if they should fit.
But if you want steel I think you have to keep looking.
Warehouse Monkey
Quoted: 305 Post(s)
Liked 7 Times
Honestly, anything other than something cheap and plastic would work. Wrong choice of words.
Bikes: Trek 520 total custom build, Cannondale Mountain Tandem, Oryx Mountain Bike
Quoted: 61 Post(s)
Liked 6 Times
Hose Clamp
Hi why not use a stainless steel hose clamp? Unscrew it all the way, to get around down tube slip your bottle mount in, thread the strap back in the clamp and tighten. DONE!
Riv Nuts
Riv Nuts are not that difficult to install , in reality.
you expand them in the drilled hole with the bolt pulling against the flange of itself..
others use a seat post QR.. same 5mm thread . the lever pulls against some tubing against the riv nut flange..
Not steel, but glass filled nylon. Tough stuff!
https://www.adventurecycling.org/cyc...-cage-bracket/
Quoted: 2236 Post(s)
Liked 1,314 Times
I like those oldschool VO mounts. Simple but they work well.
I have also used hose clamps but wrap them with electrical tape afterward so the loose end won't catch on things. Ghetto but functional.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
I found some of the old steel ones today in my garage but would need to dig them out again, if I can find them again.
the velcro strap on two fish cages are very secure, they have 2 strap versions. doubling up
Zefal and Klick Fix also offer add on cage mounts.. too
Quoted: 18378 Post(s)
Liked 4,512 Times
Assuming standard size tubes, the vintage cage mounts are much nicer than at least some of the new reproduction cage mounts you find on E-Bay.
The reproduction cage mounts I've found fit poorly, stick out an excessive amount, and don't hold the cage well.
Keep in mind, you need cages where the clamps can go over the screw attachment points.
No newbie
Bikes: 2001 Specialized Expedition Sport | 1972 Raleigh Sprite 27 | 1973 Raleigh Super Course | 1984 Trek 720 | 2019 Cannondale SuperX
Quoted: 30 Post(s)
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
I have one of these, works just fine. The mount part can be rotated to either direction, to mount on tubes or handlebar: https://www.topeak.com/global/en/pro.../332-cagemount
Warehouse Monkey
Quoted: 305 Post(s)
Liked 7 Times
Thanks for the replies. I think I may use hose clamps to try it out first. Then buy something meant for the application.
tanguy frame
Bicycle Mechanics
16
04-22-11 10:34 PM
courtesi
Bicycle Mechanics
22
10-29-10 12:43 AM
