Smallest Cog Jammed Against Dropout?
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
This seems like the kind of question that's been asked before, but I could not find reference to it.
I have a SRAM 9-speed cassette on my mtb, and I've had this wheel on the bike before, but when I tried to install it, the smallest cog was up against the inside of the dropout, so the wheel wouldn't turn. I compared it to another, similar wheel, and I noticed that on the good wheel, the hub axle protruded past the smallest cog. This is probably what keeps the dropout away from the cog. On the wheel that is not working, the hub axle does not extend past, but resides within the cog. Any ideas on this?
Quoted: 6196 Post(s)
Liked 4,810 Times
Missing a spacer or someone changed the cones and the new cones don't have as long a body. Or the cones got swapped to the other side when someone removed it for servicing the bearings. (sometimes cones are different body length, but I only saw that on freewheels) Maybe some other things.
Any ideas on this?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Why was the wheel taken off the bike?
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
If the axle is inside the cog it can't go in any bike
Likes For dedhed:
Standard Member
Liked 940 Times
Licensed Bike Geek
Likes For Davet:
If your cassette has a 11t smallest cog, it must be lined up correctly when engaging the lockring. If it rotates out of alignment, the large tab will interfere with the freehub's spline and not 'nestle' down properly into the recess on the 2nd smallest cog.
Is it the cog that is interfering? or the lockring against the dropout?
Likes For KCT1986:
Bikes: lots
Liked 2,932 Times
OP took off a cassette that was not hitting the frame to clean it...I somehow doubt that he spotted a random spacer laying around and thought he should add that. Possible, but highly unlikely.
Likes For cxwrench:
Standard Member
Liked 940 Times
Standard Member
Liked 940 Times
Standard Member
Liked 940 Times
I got the wheel onto the bike, but the 11T is still jammed up against the dropout.
Here's a photo, and it look to me like the second-smallest cog is a larger distance
away from the third-smallest. Do I have it not seated right?
It's also possible to have the 11T cog in the wrong alignment and it will appear OK, but it will not seat into the recess of the next cog.
Standard Member
Liked 940 Times
I thought I had it, but I spoke too soon (I edited my above comment). I'll keep working on the alignment of the grooves on the splines. It's a Shimano Deore hub and SRAM cassette, if that helps.
Bikes: lots
Liked 2,932 Times
It's either lined up correctly or it isn't...what's so hard about lining up the splines and tightening the lockring? Hold the 11 cog in the right spot as you start to tighten the lockring by hand, then get the tool on it and crank it down. If you don't hold the cog in position it can move but that should be very obvious.
If the issue is with the 2nd & 3rd smallest cog, check that the screws holding the larger cogs is not interfering with the proper seating of the 2nd.
Likes For KCT1986:
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
The 11 is touching the droput even though the chain can shift on to the 11 ?
