crankset cover for vintage bike
HI,
I would like to fit a crankset cover on my vintage racing bike to prevent the trousers from getting caught in the teeth of the sprocket (it happens every now and then) or from getting dirty with grease.
This is my crankset (42-52):
https://velobase.com/ViewComponent.a...m=115&AbsPos=6
All the crankset covers I've seen on sale have 4 or 5 holes and they can't fit on my crankset which has 6 holes.
Where can I find a suitable one?
Thank you.
Thank you.
Bikes: Bike Friday PRP, Bike Friday NWT, Bromton M6R, 1991 Miyata 914, 1991 Miyata 1000, 1986 Raleigh Portage, many more frames
Quoted: 215 Post(s)
Liked 348 Times
I can't imagine finding one will be easy, considering that Nervar has been out of business for quite some time. At the same time, making a chainset cover shouldn't be particularly hard if you are handy. You can cut a circular piece of wood and trace the mounting holes onto the piece of wood, then drill out those holes. A few spacers and nuts and bolts and you should have a pretty stylish chainset guard. Something like this should suffice:
Image taken from Pinterest.
Likes For philpeugeot:
Quoted: 1106 Post(s)
Liked 1,328 Times
Tuck your pant legs in your socks.
And if you have laces tuck the right-side ones in your show so they don't get caught by the teeth; at low speed this can be an error from which you cannot recover.
Likes For oneclick:
Quoted: 876 Post(s)
Liked 2,292 Times
Campagnolo made three bolt cranksets with chain guards. I took mine off and set it aside , I’m not sure of the BCD but I’ve seen them on eBay.
Campagnolo Grand Sport crankset with guard removed
Likes For Kabuki12:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Search eBay for Nervar chain guard. There are a few of them. I don't know if they fit your chain rings or not.
https://www.ebay.com/sch/i.html?_fro...guard&_sacat=0
Likes For Chuck M:
Bikes: '85 Schwinn Madison, '46 Higgins Ultralite, 1950s Wally Green, '85 Trek 660, '82 3Rensho Export, '90 Trek 970, '91 Schwinn Paramount, '78 Dawes, '78 Trek 730
Quoted: 77 Post(s)
Liked 263 Times
might have more luck just swapping crankset rather than chasing a 6 hole pant guard. Good luck on your search.
Likes For brewerkz:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
TA made them. 152 mm bolt to bolt straight across.
https://store.bicycleczar.com/product-p/11160008.htm
I used one on a single TA crank. I only had three long bolts but it does the job. The chainring has all six bolts.
Likes For clubman:
Quoted: 3513 Post(s)
Liked 2,927 Times
Don’t ride wearing pants.
Likes For smd4:
Bikes: Since new: 86 Rodriguez Tandem, wife's 87 Gitane Team Pro, 92 Burley Rock-n-Roll, 85 Fisher Comp, 88 Puch Pro, two 92 Bridgestone X0-1s; later: 66/67 Gitane Champion du Monde, 70 Gitane Super Corsa, 70 Carre, 87 Gitane Team Pro, 77/78 Ritchey Tandem
Quoted: 149 Post(s)
Liked 366 Times
Tucking your pants leg into sock as suggested above is so much easier…but if that trick doesn’t appeal to you, buy a “trouser clip” that keeps the leg of tour pants tight to your ankle…Brooks even makes a leather one.
Likes For Markeologist:
Likes For Piff:
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1084 Post(s)
Liked 1,820 Times
OK, go to your nearest co-op.
You have a size 52T?
Find the same BCD and get a 54T or 55T if they made one.
Now go home, cut the teeth off and grind the thing to a round toothless shape.
Boom
Robert
Boom
Robert
"Leave the gun. Take the Colnagos."
Likes For Robvolz:
Quoted: 1944 Post(s)
Liked 2,164 Times
In lieu of a lathe, I have mounted a ring on the crankset, covered the BB with a rag and filed the teeth off as I turned the crank. It is a bit time consuming, but not too bad with an aluminum ring.
It can also have a nicer appearance than a solid guard.
John
Quoted: 800 Post(s)
Liked 753 Times
$30 is pretty reasonable for a rare part. Probably would cost that must to purchase the right size chainring to make a homemade version. Unless you live near in a bike-culture city where the bike co-ops have deep parts bins.
Quoted: 3464 Post(s)
Liked 2,831 Times
Shimano and SR both made chainguards, the chances the BCD’s of those fit yours is marginal.
even then, they were not a panacea, pants still could catch.
Terry trouser clips. Or later versions, I have a pair that have LED’s buried in the strap, and are essentially spring loaded, gift from the worried wife for when riding home at night.
Also, many of those guards require the front mechanism to be raised above best performance to clear. No free lunch.
Honorary Bicycle Rider
We 3D printed a chain guard to convert this Shimano triple Crankset into a 'Mountain Double' for an SR bicycle.
