Derailleur question
Derailleur question
Old 12-20-22, 09:32 PM
jdogg111
Quoted: 137 Post(s)
Liked 51 Times in 31 Posts
Derailleur question
Hi all, I'm just wondering, since I've heard conflicting stories, about the actual range of the rear derailleur. As a for instance, I currently have a 8 speed cassette on my folder, thinking of going to a 10 since I have one laying around,. I know I have to change the shifter and chain, but won't that same derailleur work, since shifting is indexed? Thanks in advance, I hope it can work, if not with a trigger shifter maybe friction?
jdogg111 is offline
Old 12-20-22, 09:41 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
What brands, era, road or mountain??
IF you had Shimano compatible components I'd say 8 to 9 speed is no problem. 10 adds a maybe a problem.
There are always exceptions such as some real old Shimao Dura Ace stuff.
Provide more details about what you have re brands & model numbers and one can give much better answers.
Bill Kapaun is offline
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 335 Post(s)
Liked 523 Times in 349 Posts
Disregard, sorry
SpedFast is offline
Old 12-20-22, 11:43 PM
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1950 Post(s)
Liked 1,475 Times in 1,022 Posts
Assuming (based on market share) that all components you have mentioned are made by Shimano, theoretically, yes, even with an indexed shifter.
What are the standard speeds? - Bike Forums
SoSmellyAir is offline
Old 12-21-22, 04:12 PM
Lombard
Sock Puppet
Lombard's Avatar
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times in 573 Posts
Need more info. Shimano, SRAM or Campy? Road or mountain group set?
If Shimano road, 8, 9 and 10 speed are interchangeable since the shift ratios are the same, so the 10-speed shifter will work fine with the 8-speed derailleur. If Shimano mountain, 10-speed is a different shift ratio and an 8-speed derailleur won't work with a 10-speed shifter.
Lombard is offline
Old 12-21-22, 05:06 PM
kommisar
Quoted: 69 Post(s)
Liked 66 Times in 33 Posts
I find this crib sheet to be particularly useful when dealing with drive trains:
https://sheldonbrown.com/cribsheet-spacing.html
kommisar is offline
Old 12-21-22, 05:40 PM
SJX426
SJX426's Avatar
Quoted: 1609 Post(s)
Liked 2,216 Times in 1,103 Posts
@jdogg111 - You said you have a folder. What size wheels? Shimano made a rear cassette with a 9 tooth sprocket. It is only compatible with itself. check it.
What size wheels do you have or what brand folder is it? Some have really unique components.
SJX426 is offline
Likes For SJX426:
Old 12-21-22, 05:57 PM
momoman
Bikes: 2013 Wilier Gran Turismo, 1983 Trek 760, 80's Colnago Super, 90's De Rosa SLX, 2009 Waterford 22 Series Singlespeed, 85 Medici Pro Strada, De Rosa Alumino frameset, Dave Molten Fuso frameset, 70's beater Peugeot PX10, Zizzo Liberte, 2022 Yoeleo R12
Quoted: 122 Post(s)
Liked 200 Times in 92 Posts
jdog111, I had the same question in mind! Like you, I was also thinking of upgrading the Zizzo Liberte’s stock drive chain from an 8-sp to either a 9 or 10-sp.
The stock components are:
Shimano Revo 8-Speed Grip Style Shifter with Gear Viewing Window
Shimano Altus 8 speed direct mount RD
Suntek Nickel Plated 11-32T 8-Speed cassette
20” 406 130mm OLD rear wheel.
momoman is offline
Old 12-21-22, 07:11 PM
jdogg111
Quoted: 137 Post(s)
yea. sorry for not mentioning the name of the bike. zizzo liberte, i'm thinking its sora on the rear.
jdogg111 is offline
Old 12-21-22, 07:18 PM
Lombard
Sock Puppet
Lombard's Avatar
8-speed derailleur will work fine with 10-speed Shimano road shifter and cassette. Keep in mind that 8, 9 and 10 speed cassettes are all the same total width, but the spacing between cogs became less as number of cogs increased. The range of the rear derailleur is the same.
Lombard is offline
Old 12-21-22, 11:58 PM
Camilo
Quoted: 1110 Post(s)
Liked 1,204 Times in 761 Posts
Originally Posted by SpedFast
Disregard, sorry
There's a delete function.
Camilo is offline
Old 12-22-22, 12:14 AM
Bill Kapaun
Actually, this poster shouldn't have deleted their post-
I beat them by a few seconds and we were pretty much saying the same thing.
However, this poster also mentioned a maximum cog size being a possible factor. I failed to do so.
2 people answering the same way within minutes of the OP simply reinforce each other.
Likes For Bill Kapaun:
Old 12-22-22, 12:23 AM
Camilo
I only mentioned it, not to scold (hope it didn't come off that way), but in case the poster didn't know there's a delete function. Machts nichts either way.
Camilo is offline
Old 12-22-22, 12:36 AM
HTupolev
Quoted: 1979 Post(s)
Liked 1,298 Times in 630 Posts
It'll only work with the shifter if it's pre-2015. Starting with Tiagra 4700, Shimano's road 10-speed groupsets have shared rear derailleur actuation with the 11-speed road stuff.
HTupolev is offline
Old 12-22-22, 06:31 AM
Lombard
Sock Puppet
Lombard's Avatar
True. I stand corrected. But so far, the newer Tiagra is the only 10-speed group with the 11-speed shift ratio.
The OP needs to look for a shifter that is 5600/6600/7800 or earlier generation.
Lombard is offline
Old 12-22-22, 10:05 AM
Iride01
Iride01's Avatar
Quoted: 6199 Post(s)
Liked 4,816 Times in 3,323 Posts
If you already have the stuff, then why not try it and see? However if you have indexed shifters, then you need to get 10 speed indexed shifters. Of course friction shifters might work. But I'll think that finding the right place to catch a particular gear will be a little more fiddly for you. But I don't know I went to indexed after leaving 6 and 7 speed freewheels.
Width difference of a 8 speed cassette and 10 speed cassette might be the same to a couple mm depending on what exactly you have. A bigger concern for the cassettes might be if the large cog on the 10 speed is larger than the large cog of the 8 speed. Some DR's might not clear that gear as they travel to the low gear side.
If you adjust your limit screws out all the way then you can see what the full swing is on your DR by disconnecting the cable and simply pushing on it and measuring.
Iride01 is offline
Old 12-22-22, 11:32 AM
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 335 Post(s)
Thanks Bill,
SpedFast is offline
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 335 Post(s)
Yeah, but I still wanted to follow the thread and the edit was quick and easy.
SpedFast is offline
Old 12-22-22, 02:00 PM
Lombard
Sock Puppet
Lombard's Avatar
The other possible issue here is total chain capacity of the RD cage.
Lombard is offline
Old 12-22-22, 02:24 PM
HTupolev
GRX400 also fits the bill.
HTupolev is offline
Likes For HTupolev:
Old 12-22-22, 02:25 PM
Lombard
Sock Puppet
Lombard's Avatar
I didn't know GRX400 was only 10-speed. Noted.
Lombard is offline
