GoPro stabilization settings
Quoted: 5224 Post(s)
Liked 3,584 Times
anyone want to share their GoPro specific model & go-to stability setting?
been looking at these cameras online. at some point I may switch to that brand. right now my cams are simple & durable & I like that. I also have all my mounts worked out. also make .mov files which are easy to import into my MAC iMovie program. I dislike fussing w/ menus, options & having to deal w/ a whole new set of mounts & converting file formats would be a deal breaker
however, I am attracted to digital image stabilization. right now I have zero. so any would be a step up. most of my video is acceptable to me, but some I have to just delete & that's disappointing
reading about GoPro's diff. settings & watching youtubers talk about their best practices, I see that not everyone cranks up the stabilization as high as it will go, due to compromises in exchange for the stability
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 160 Post(s)
Liked 68 Times
I've only used a GoPro Hero 9. I record at 4K, 30FPS in linear mode with horizon leveling on. My stabilization is on Hypersmooth Boost. I think I will go down to 2K, though, as these 4K movies take a long time to process.
I've tried recording on Wide but there's no horizon leveling. The video rocks back and forth without the horizon leveling and it was making me nauseated. I use the Rouvy virtual cycling platform, and some people prefer the horizon leveling off which gives a more real bike feel. However, the cyclists who record those routes from their bike are extremely strong cyclists, and can ride up hills without rocking their bikes. Not me.
Anyway, here's a sample clip from my camera using the same setting on 3 different rides. The first clip is being recorded around 5:45am so it's actually pretty dark outside. You can see the GoPro does a pretty good job of bumping up the light. However, this stretch of road isn't very smooth, and it shows the GoPro's image stabilization isn't the best in low light. In the middle clip we've slowed down to around 15mph to cross a bridge but the video stays stable going across bumps. In the final clip, we are flying down a long descent. I hit 47mph on this stretch. The road is pretty smooth and the video isn't jittery at all. The road is actually windier than it seems, but the horizon leveling takes some of that effect away. Towards the end you do see a few bumps in the video as I roll over the road reflectors as I pass my friend.
Paul
Paul
Likes For pennpaul:
I use a GoPro 10. Stabilization works well for me. I use the camera as a handheld which helps take some of the vibration out of the video. For long rides I use a Drift Ghost XL camera mounted below my outfront computer mount. The Drift has a much longer battery life. The Drift video doesn't have as much stabilization but enough.
The GoPro out of the package settings work well for my usage. This link shows my last ride with the GoPro.
I use the GoPro Media Mod housing mic without the foam cover. Most shots are with my arm extended. The Media Mod mic is pretty sensitive.
Likes For texbiker:
Liked 3,584 Times
thank you. I've given up on mounting my camera on the bars due to the micro vibrations, but your vids don't exhibit that
Liked 3,584 Times
Likes For texbiker:
Quoted: 160 Post(s)
Liked 68 Times
I use this Bar Fly out-front mount. It's compatible with a ton of head units and includes the GoPro mount underneath. You do need to crank down the mounting screw on the GoPro, though. On that last descent, the vibrations tipped the camera downwards (I didn't notice), and I ended up filming my front tire and road for the remaining 45min. I was not happy, but user error.
https://www.amazon.com/dp/B01GRHYT74...roduct_details
Likes For pennpaul:
Liked 3,584 Times
the weight of the camera doesn't weigh down that arm? & slowly rotate it's view? with mine I always had to stand it up w/ the weight straight down to the bars at a 90 degree angle
imagine this light is my camera
Liked 3,584 Times
oh yeah totally agree. but that means you might be riding one-handed. sometimes ok, sometimes not so much. ever try a camera stick?
I shoot short clips so not riding one handed for long. I tried a selfie stick but it makes the camera to bulky to put in my jersey pocket which I do with just the GoPro.
Likes For texbiker:
Quoted: 160 Post(s)
Liked 68 Times
I didn't have the GoPro tightened enough on my last ride, though, and the GoPro did rotate in the mount, but the mount did not rotate on the handlebar.
I bought a spare battery door for my GoPro off eBay. It keeps your GoPro battery locked inside, but has a small opening for a USB-C cable. On long rides, I run a USB-C cable from the GoPro to a battery pack in my toptube bag. Gives me hours of battery life. Of course, the GoPro isn't waterproof with this spare door.
Likes For pennpaul:
Liked 3,584 Times
I didn't have the GoPro tightened enough on my last ride, though, and the GoPro did rotate in the mount, but the mount did not rotate on the handlebar.I bought a spare battery door for my GoPro off eBay. It keeps your GoPro battery locked inside, but has a small opening for a USB-C cable. On long rides, I run a USB-C cable from the GoPro to a battery pack in my toptube bag. Gives me hours of battery life. Of course, the GoPro isn't waterproof with this spare door.
Liked 3,584 Times
ok thank you I get it. it's good to have the camera free for grabbing certain clips. I like to have 1 cam on my helmet & one in a pocket. mine are cheap enough so I can have more than one. I'm thinking I would still use mine for some things but use the GoPro as the main mounted on bars or helmet
Liked 3,584 Times
thank you for the input guys. just pulled the trigger on an older model (8) & I'm planning on super-gluing my current mount on the bottom. no problem solving required. if it's a mistake I'll rip it off & replace the little folding fingers. I'm sure this is sending me down a rabbit hole, but then I've always been a small risk taker
