Gravel clipless pedals - Looking for recommendations?
Quoted: 446 Post(s)
Liked 1,045 Times
I'm looking for a decent pair of clipless pedals for gravel. I prefer a 1 sided SPD pedal with the other side flat for those times I need to be unclipped like on narrow single track. Most the pedals I've found are a bit too wide for my taste (seems optimized for MTB riding) and I've had my pedals scrape the ground on road curves. Also many SPD pedals seem quite heavy, so I wouldn't mind something that's at least sub 300g for the pair if possible. Thanks for any recommendations!
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
I prefer XTR trail pedals. These are double-sided, but if you have to unclip, they are still rideable.
On another bike (my touring bike), I have FUNN Mamba one-sided clip pedals. The other side is flat with pins. They sound like what you are asking for. I find them slightly narrow, but maybe that too might suit you. There are two sizes. Getting below 300g isn't going to be easy.
https://www.funnmtb.com/products/mamba-s/
Likes For Polaris OBark:
Quoted: 446 Post(s)
Liked 1,045 Times
I prefer XTR trail pedals. These are double-sided, but if you have to unclip, they are still rideable. On another bike (my touring bike), I have FUNN Mamba one-sided clip pedals. The other side is flat with pins. They sound like what you are asking for. I find them slightly narrow, but maybe that too might suit you. There are two sizes. Getting below 300g isn't going to be easy.
You might want to check out the Shimano PD-EH500 pedals. They are SPD on one side and Flat on the other. I have a set on my Stages smart bike in case someone without bike shoes want to ride.
Quoted: 6972 Post(s)
Liked 10,968 Times
Likes For Koyote:
Quoted: 446 Post(s)
Liked 1,045 Times
https://www.aliexpress.us/item/2251832688682928.html?
I'm currently using the Xpedo magnesium alloy Look Keo pedals on my road bike and they work great. They come with a sealed bearing axles and the overall quality is quite nice. The build on the SPD pedals looks to be similar to my road pedals. I believe the Xpedo line is Wellgo's more premium set of pedals. I'll probably order a set, though I'll still check to see if there are any local sellers.
Pedalin' Erry Day
PD-ES600 is what you're looking for if you want light, tough, clipless pedals with great ground clearance that aren't pure road pedals. I use mine for gravel riding that often goes into singletrack and they're great, have held up just fine in spite of many rock strikes and scrapes. They don't have a platform, but in my opinion if you don't have the skills to be comfortably clipped in on rough terrain, you're not a rider who needs to care about saving a relatively small amount of weight at your pedals - get pedals that suit your riding needs as your top priority, there are much better places to look for weight savings.
Quoted: 446 Post(s)
Liked 1,045 Times
Thread Killer
Quoted: 3148 Post(s)
Liked 1,713 Times
I’ve had them for many years, used them for winter gravel riding, and like them, although they’re not really suited for pedaling on the underside, unclipped, if that’s what you want to do.
It’s almost easier, because of the pedal weighting, to just hit the topside with the shoe toe and stay out of the clip, at least that’s what I’ve found with my stud-mount equipped Northwave Celsius Arctics. I can’t recall exactly, since I don’t need to ride unclipped very often, but the unclipped grip between that shoe and pedal is pretty decent.
Randomhead
Liked 3,699 Times
I had some of the single sided pedals and pedaling on the flat side was less than ideal. Cleats hit the pedal.
I'm not sure why I got them anyway, I clip in on single track. I just make sure it's easy enough to clip out.
Sunshine
Quoted: 10965 Post(s)
Liked 7,491 Times
I have the Shimano A530 pedals on my gravel bike and also on my commuting bike because they are the two bikes I ride with my kids on in town rides and I will often wear running shoes.
They weigh 380g and are no longer made, but the EH500 model already mentioned replaced the A530 and is improved in that it offers pins.
The A530 has been great for me- I think each set is 6 years old and both were purchased used. 0 thought and 0 maintenance is how I determine if a pedal is great.
Interesting that Wellgo owns Xpedo, I didnt realize that and learned it from your ali link. Looks like you found some pedals that fit your wants.
Sunshine
Liked 7,491 Times
Agree that there are better places to look for weight savings...and if the OP wanted to stay clipped in the whole time then es600 or A600 pedals would be great since the A600 weigh 290g.
Likes For mstateglfr:
Quoted: 1461 Post(s)
Liked 1,486 Times
I'm late to this thread - but if anyone is considering XTR pedals they should google "XTR pedal seal" and read about this issue. I have a pair of XTR pedals that I got in 2020 and one of the seals is failing on them already. They still work fine and I've not noticed any bearing issues, but I'm sure it's coming.
XT's are half the price, only 32g heavier and are pretty much bomb proof. I've had a pair of XT's on another bike for at least 6 years and they still work perfectly. I will likely buy XT's for all my bikes moving forward.
Likes For msu2001la:
Probably not what you are looking for, but when I use an spd on one side pedal that has a cage or a platfom on the other it is the Shimano PD-M324 SPD. I only use the one sided spd cage on the other for bikes I might ride with non dedicated bike shoes, something I very seldom do. the 324 are heavier than you desire and have a cage rather than a platform. They are a decent pedal. I have had a set on a beater bike in the past and currently have them on my folding bike.
Likes For staehpj1:
I am not necessarily suggesting others should do as I do, but I am presenting this as food for thought.
My personal experience is that the times when folks "need to be unclipped like on narrow single track" are the very time I mosr desire the security of being clipped in. I really feel much more secure on technical stuff if clipped in. I have found that with practice it takes no longer to put a foot dow from a clipped in pedal, but it is much easier to lose footing on a non clipped in on when going over rough terrain or tough obsticles. I like single release cleats set the release up fairly tight, but if necessary to feel safe using a multi release cleat and setting the pedal release mechanism up loose might allow staying clipped in.
For me the cage side of the pedal is just for when I want to wear non bike specific shoes.
Again just food for thought.
Bikes: GR300, Grail, Live Wire, 5010
Quoted: 189 Post(s)
Liked 241 Times
I’m a big fan of Crank Brothers eggbeaters. Have them on all my bikes, road, mountain, and gravel. They’re all sub 300g too. Eggbeaters
Likes For sarhog:
Liked 3,443 Times
XTs have a higher stack height, which bothers my previously busted ankle a lot. But for most people, XT is probably the sweet spot. I have trail rather than race XTR pedals, FWIW. The cage can really help if you need to be unclipped for something sketchy.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 240 Times
i was going to mention that; several reviews point out that for both types, trail or XC, the XT range is bearly heavier than the XTR range. Xt and xtr are equally good at clipping in mud.
the difference is what they call stack, the pedal thickness. But, that’s a couple of millimeters which most people cannot notice (people get used to the garmin spd stack which is much thicker).
personnaly; I like the XT, they work well, clip well and firmly, don’t jam (unclip quickly when needed).
the M540 are good too.
on my other bike, i run old M520 from the part bin and I run 1side with the shimano platform. This has 2 advantages: i can obviously pedal with on side as flat pedal but also, thanks to gravity, the clipless side is always up so it is easy to find and clip in.
Liked 1,486 Times
I can also confirm that the M540 is a great option. They're a bit heavy, but they work just as well otherwise as XT/XTR's.
The only time I struggle with Shimano SPD's is in CX races that require running in sand. The sand gets packed in around the cleats on my shoes, and makes it difficult to clip back in. I'll sometimes have to knock my foot against the side of the crank/pedal a few times to knock the sand out, then it'll clip in. This is a super specific CX race situation though... and probably would be a factor with any pedal. (Also possible that different shoes might shed packed sand better than my SIDI's).
Quoted: 1975 Post(s)
Liked 232 Times
Likes For redlude97:
Quoted: 446 Post(s)
Liked 1,045 Times
Just reporting back. I've decided to keep my current budget nylon SPD pedals. They're not the lightest at 340g, but being nylon I've scraped them on rocks and other surfaces and they manage to stay looking decent (unlike alloy pedals when they get scruff'ed). I've opted to buy some lightweight single sided Wellgo Xpedo SPD pedals that come in at 245g for those times I'll be predominantly riding road or light gravel.
You might want to try Time pedals next time you get curious. They have the mud/sand/whatever shedding ability of cranksbothers but are also super reliable.
Likes For Canker:
