Why I love tubeless
Why I love tubeless
Yes, there will be naysayers. Yes, tubes have worked for 100,000 years and should be good enough for me, yeah yeah. But yesterday I finally got to experience the reason I switched to tubeless: not getting flats!
I was riding along, minding my own business, when a pebble got stuck to my tire. Clicky click. So I stopped to brush it off and discovered that it was stuck to something sticky on my tire. What was it stuck to? Why, sealant! And so I spun my tire around and lo and behold, there were two tiny orange dots where I had run over something and never noticed. (Only one of them leaked enough sealant to make a sticky patch. the other was just a dot with a latex string hanging out.) If not for the pebble, I would never have noticed I'd gotten a puncture until I stopped and look over my tires after the ride. (Which I always do.) So little air was lost that I could barely detect it when I checked the pressure when I got home. Maybe a lb and change.
Tubeless rules! (But yeah, I still carry a tube with me and levers.)
Oh, I'm using orange seal, in case you're wondering.
Quoted: 18378 Post(s)
Liked 4,512 Times
I put a tubeless tire on my front a few days ago.
I don't think I've run over anything to cause a hole yet.
One note, however, I think I get a flat maybe once a year with my gatorskins or gator hardshells.
If you've gotten 3 punctures on the first ride, that may really be a cause for concern.
I have the Schwalbe Pro One tire on my front, and have another for the rear. Unfortunately reviews are mixed.
Quoted: 18424 Post(s)
Liked 15,579 Times
Subscribed.
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
I won't go back to tubes, tubeless all the way.
But, as with any tire they are susceptible to cuts and damage from large debris.
I always carry a plug kit and a co2 inflator. On long rides I sometimes carry a spare tube but not always.
Only 1 time in the last 3000 miles have I actually had to walk home. Hit a rock causing a large cut in the tire and then the rim cut the sidewall open since I was going pretty fast around a corner. No hope of booting tire, and no way a tube would have prevented this from happening.
The plug kit worked pretty well on my Schwalbe Pro one tubeless tires the other day. Had a hole that wouldn't seal until I used the plug. The plug is still in the tire, over 300 miles later no leaks and has worn down smooth. Well worth the $6.
https://www.jensonusa.com/genuine-in...8aAqBKEALw_wcB
Quoted: 20810 Post(s)
Liked 9,456 Times
One piece of advice, a lesson that I've learned the hard way - set a reminder to check your sealant levels every 6-8 weeks (OS comes with a dipstick). OS will keep for a long time in (the relatively small volume of) road tires... but you *will* get punctures that you don't notice and the sealant level will drop and you'll run the risk of a dry puncture and a roadside fix/call of shame. As always, the rear is far more susceptible - I've had the front still looking fresh and clean for more than 6 months while the rear seems to max out at 3 months or less.
Quoted: 1975 Post(s)
Liked 232 Times
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
In the two months I tried tubeless, I had flats on three different occasions (once in a race). One one occasion the tire sidewall was punctured enough to ruin the tire. The other two times it didn't seal until there was ~30 psi in the tire. And one of those times when I tried to put more air in the seal wouldn't hold until it dropped back down to ~30 psi.
Was probably just a bad run of 3s, but at the time (and still) I was not impressed.
Non omnino gravis
On the rare occasion that I get a tire to survive through it's whole usable life without succumbing to fatal injury, and it's nearing it's treadwear life, I can count the little "weepers" on the tread. For whatever reason, my tires don't seem to 100% seal, and a night of sitting after a ride, each puncture hole-- where something made it all the way through the tire-- will have a tiny wet dot on it from the sealant weeping out. My current pair of Hutchinson Overides has about 2,800 miles on them. The front tire has 46 weepers. The rear has 88. So even if I were extra generous and said that just 1/4 of the punctures would have resulted in a flat, I would have gotten 33 flat tires in less than 3,000 miles.
I'd much rather top off sealant in my workshop every 6 weeks than change a flat tire on the side of the road (at least) once a week. Ban glass bottles and eradicate goatheads and I'll go back to tubes without pause. Until then, tubeless everything.
Liked 9,456 Times
Quoted: 800 Post(s)
Liked 512 Times
Anyone have a good recommendation for a plug kit? I've never heard of one. Thx.
Liked 9,456 Times
Got a bad sidewall puncture. Tire sealed at about 40 PSI. Enough to get me back to my car (12 mile ride). Good thing as I doubt I could unseat the tubless in the field with my 66 year old arthritic hands! I now carry CO2 and a Dynaplug kit. Staying with tubeless.
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
Bikes: Norco search xr
Quoted: 198 Post(s)
Liked 146 Times
Liked 4,512 Times
I'm about a week out with my tubeless experiment, and so far no topping off. Schwalbe One Pros, Ultegra 6800 rim.
I may be losing air slightly faster than normal, so perhaps I'll pump it in a few days.
Thanks for the suggestion (above) on dipping sealant. I might give it a try in a month or two.
Easy to use on a road tyre?
