Power Screwdriver Fit for a Bike
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Most people avoid using power screwdrivers/bit drivers on bikes due to the ease with which damage can occur. However, now there is a tool that opens a new way of operation for power tools, completely intuitive, DeWalt gyroscopic screwdriver. Does it read your mind? No, but it reacts to the way in which your hand acts when using a regular screwdriver, so you become capable of using a power tool in subtle ways, without really thinking. It is an absolute revelation. For a small power screwdriver price is quite high - mine is an inline version - but once you start using it, the tool becomes practically integrated with yourself. It is my primary tool now on the bike and elsewhere.
No connection to DeWalt or its distributors on my part. I ran into it just by looking for a small in size but effective power screwdriver.
Quoted: 4210 Post(s)
Liked 3,879 Times
About the only non factory application a powered screwdriver has, as I see it, is for spinning nipples down during the initial build up of a wheel. Repeated process with little need for torque control. But this tool does sound cool, if bulky for the small screws bikes use with their fairly short threaded engagements. Andy
AndrewRStewart
AndrewRStewart
Quoted: 840 Post(s)
Liked 336 Times
It is obviously on the bulky side, so not for every bolt. Yet the way it reacts to the hand, ability to tread very slowly, stop when you feel unease, ability to use without the power, and so on, make its operation really quite secure, at least in my mind. I am in the process of fitting an accessory meant for a full size bike to a folding bike. Besides trimming the size, I need to deform shape - there are repeated adjustments moving between a vise and the bike, each time removing and putting back several mounting bolts. This screwdriver turns mountings and dismounting into nonevents.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Maybe for rotor screws too. Looks cool. I use a drill with a nipple driver when building wheels as Andrew posted, could work for that.
Quoted: 581 Post(s)
Liked 921 Times
In my experience, to work on one or a few bikes, as opposed to some sort of mass assembly process, a powered screwdriver is not necessary. Most bolts only need to be turned 5 or maybe 10 times at most, from initial assembly to tightened down. Maybe if one has mobility issues or joint pain then it could be helpful, but a foldable allen key set is likely almost as fast, and more reliable, than a powered tool in many situations.
Quoted: 2338 Post(s)
Liked 2,827 Times
I don't see this for my self, but have learned to never say never....starting to get some arthritis in the hands......not getting older, but am getting less young
Likes For squirtdad:
Quoted: 2604 Post(s)
Liked 1,933 Times
Oh, well.
Quoted: 6196 Post(s)
Liked 4,812 Times
My son bought that a year or so ago and thought it was the greatest thing. When he first got it, he wouldn't use a normal screwdriver for anything, always had to go get the DeWalt even when I had a regular screwdriver right there.. I seldom see him use the Dewalt power driver anymore for just the simple needs a bicycle has.
I think constantly changing the driver bits would drive me nutz. Actually I know for a fact that it would drive me nutz.
I've got one of the Y shaped hex key tools with the common bicycle sizes. It works for my way of working wonderfully.
The issue is how we each prefer to work. For you the driver tool is a good fit. For me I know it would not be due to the almost constant bit swapping. I want to be able to reach down and grab what I need with one hand.
I watched a YT video on the tool. There's no doubt it's a trick item. Just not the right trick for me.
One place where it would be a total game changer is for folks with carpal tunnel or other wrist or hand concerns.
Likes For ClydeClydeson:
Quoted: 1438 Post(s)
Liked 1,092 Times
I have a similar Dewalt model which converts between inline and pistol grip. Best thing since sliced bread. I used it to remove a kitchen's worth of cabinet hinge hardware and reinstall it after painting and it was still 2/3 charged afterward. Good torque and you can turn it manually to snug up a fastener. Simple torque setting mechanism.
It is one of the most ergonomic and intuitive tools I have used. I have two.
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,001 Times
A lot of folks at the shop have a Bosch tool like that we mainly use it for rotor bolts it makes that job quick and easy.
Me personally I am happy with my Snap-On 1/4 Bit Ratchet at least at home as I rarely need to replace rotors.
They are not particularly robust, I've killed 2 at the day job, the gyro seems to stop responding.
Pretty good at winding long screws in and out and give you enough control to make stripping or snapping a screw unlikely.
