Flat bar commuting bike
What is the length of your handlebars ? Please discuss differences between short ( < 55 cm ) and long ( > 60 cm) handlebars !
I cut a couple of inches off each side. Longer bars have more control but narrow bars enable you to squeeze through narrow gaps better, like passing cars stopped at red lights. Can be easier to park too as protrudes less into passing people.
Likes For bluehills3149:
Thanks for the answer. I want control, but also something I can use better in narrow gaps, what would be the best compromise ? Also,what handlebars length do you have now ?
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
My flat bar bike has Surly Moloko bars and I believe they 717
Quoted: 7652 Post(s)
Liked 3,473 Times
Sorry to be a downer, but handlebar length is personal. Unless you and I have exactly the same shoulder width, arm, shoulder, and torso strength, ride the same bike with the same tires ant the same pressure on the same routes at the same time of day and ride in the same style (how aggressive are you in passing cars, how tight d you corner, howl late do you brake, how much risk do you take) then the width of my bars have no bearing on the width of yours. One of us might be a foot taller, six inches wider, 100 pounds heavier .....
For fun try taking a ride with your hands inside your current grips. Try riding with your hands two inches from the stem. See how the bike feels.
Other than that I cannot help.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
A lot of what bar width works best depends on what the rest of the bike looks like. An aggressively sporty bike with a long, low cockpit would typically run a narrower bar, while a more upright, relaxed bike does better with a wider bar. High, narrow bars feel weird, and low wide bars can be unwieldy to maneuver.
I don't consider a 630 mm bar to be "wide," unless you're going for the messenger-fixie esthetics, or a period-correct early 90's XC bike.
Unless you're riding through groups of pedestrians, 2" of bar isn't going to matter much for clearance, but you'll feel the difference at your hands, for better or worse.
I used to cut through traffic all the time on a bike with 680 cm bar all the time; it was a 650 cc Suzuki, but your mileage may vary.
Bikes: Way too many
Quoted: 900 Post(s)
Liked 606 Times
Just start with the bars the bike comes with, and if you feel you can go a bit narrower, cut 5mm off each end. Rinse and repeat until you are happy.
What I fit has no bearing on what you'd be comfortable with.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
My urban flat-bar is a singlespeed, so I like the bars wide -- like 76 cm or more. I use long grips so I can place my hands narrower if I want to, or all the way out at the ends for sawing away on stiff climbs.There's plenty of room for a bell, lights, handlebar bag, etc., and since I use Ritchey Kyotes, I get an additional "hoods" hand position where the bar curves. I think the notion that you need narrow bars to slice in between cars is mostly a hangover from fixie messenger fashion of the early 2000s. I generally don't split the lane much, and narrow bars feel twitchy to me.
Likes For Rolla:
Quoted: 1277 Post(s)
Liked 1,392 Times
whatever you choose, don’t be one of those people who ride a bike with meter wide handlebars and their arms spread wide on congested/narrow urban cycling infrastructure. i don’t know where you’re commuting but i’d suggest the narrowest bay which is comfortable for and gives you good control.
Liked 3,473 Times
As for all the other advice besides "use the width you find most comfortable," I'd ignore it. If you want meter-wide bars, and you feel they work best for you, do it. I you want your grips touching your brakes touching your stem, do that. Whatever fits your body, your riding ability, and your taste ....
I often ride with loaded panniers so I can be pretty wide .... I don't saw off half my panniers to fit in tight spaces, I just ride carefully.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Familiar thesis: you can ride any bike to work. Trivial corollary: It can have any width handle bar. Including zero, if it’s a unicycle
Genesis 49:16-17
Genesis 49:16-17
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 405 Times
My flat-bar (converted road bike to hybrid) bars are 22 inches wide.
Guest
Liked 3,270 Times
Whatever you choose, don't be one of those people who tell other people what width of a bar to use. In general, we're talking about a few inches of difference, which is hardly enough to matter in terms of manuevering around people or objects.
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
If I recall correctly, my 700c hybrids have 780mm handlebars and my 20-inch folding bikes have 580mm handlebars. The ones on the hybrids never felt too wide and the ones on the folders never felt too narrow. It's one of those things that the less you think about, the better. Which is why I hadn't bothered to get off my favorite couch and go measure them for this post.
As for the passing between things notion, as you ride more, you'll eventually start to get a feel for how much clearance between objects you have to work with. As you switch bikes more and more often, you'll eventually learn to subconsciously adjust your judgment of clearances according to different handlebar widths and it becomes second nature. The key thing you need to remember here is to not allow yourself to grow overconfident to the point where you start taking unnecessary risks, no matter how good it makes you feel about yourself for having dodged bullet after hairy bullet. If the gap between that city bus piloted by the underpaid single mom and the black minivan driven by the exhausted, half-asleep 50-something looks like it might be too narrow, it probably is. There's no shame in stopping and waiting, but there's plenty of pain, guilt and shame the injury and embarrassment that result when a speeding elbow meets an immovable side view mirror.
Likes For sjanzeir:
Anyway, after I tried today several bikes from my friends, I realized I don't like narrow handlebars at all (poor control), so I ordered a 640 mm Zoom. Thank you all !
Quoted: 383 Post(s)
Liked 690 Times
I'm with Maelochs. I sawed mine down because I felt they were too wide to be comfortable that spread out. Weaving through traffic is a separate issue than general riding comfort.
Quoted: 383 Post(s)
Liked 690 Times
I'm with Maelochs. I sawed mine down because they were too wide and I felt too spread out on the grips. Weaving through traffic is a separate issue.
Liked 3,473 Times
Likes For Maelochs:
Disco Infiltrator
Liked 2,105 Times
If the cops can lane split at high speed on their R1200GS that is three feet wide at the mirrors, you can manage whatever on a bike.
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Quoted: 4227 Post(s)
Liked 2,488 Times
My main commuter bike is a fixed gear bike. I have flat bars with ergon grips and bar ends. My flat bars measure 53 cm wide.
Quoted: 4560 Post(s)
Liked 2,802 Times
Wide for technical trails if you prefer, other than tight single tracks between trees. Narrow for most other riding. I'd prefer 50cm wide if I can get 'em, or trim to that width, but usually settle for the 55cm.
Wide bars are vulnerable to being clipped by mirrors on brush-by passing trucks and cars (and they will), and clipping other riders on narrow MUPs or group rides. Seen all those scenarios the past few years as some cycling acquaintances installed those ultra-wide bars on their fixies because it looks way cool. I've been clipped a couple of times on our stupidly narrow MUP -- it's just a standard suburban sidewalk, 4' or 5' wide, paved over the former gravel utility easement. Neither of us fell but that unexpected wobble adds to the cardio workout.
Liked 1,392 Times
the OP may not have such situations on their commute or other venues, in which case the issue is moot.
Just for commuting. I go with my shoulder width: 54 cm.
Remember that most drop bars are narrower than that
