The tricks I learn from this forum.
Old 04-25-22, 07:22 AM
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1955 Post(s)
Liked 3,661 Times in 1,679 Posts
Headlight mount!
52telecaster is offline
Old 04-25-22, 04:25 PM
merziac
merziac's Avatar
Quoted: 4512 Post(s)
Liked 6,386 Times in 3,671 Posts
Excellent!
And there are so many more, so many great minds and all that, willing to share, dig in on a problem and pass it along, especially to the newcomers.
I have a few that I was doing before I got here so I'll wait and see if I can remember some of the ones I did pick up here.
I think we need to put the hammer down on this and really make it a thing.
merziac is offline
Likes For merziac:
Old 04-25-22, 04:48 PM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,584 Times in 2,344 Posts
that is some old & worn chainring, eh? or did you grind down those teeth?
rumrunn6 is offline
Likes For rumrunn6:
Old 04-25-22, 04:54 PM
panzerwagon
Garage tetris expert
panzerwagon's Avatar
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 692 Times in 329 Posts
I really like that the chainring is still grimy around the teeth
panzerwagon is offline
Likes For panzerwagon:
Old 04-25-22, 05:34 PM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2647 Post(s)
Probably ground-in grunge from using Triflow chain lube.
thumpism is offline
Likes For thumpism:
Old 04-25-22, 06:56 PM
steelbikeguy
steelbikeguy's Avatar
Quoted: 1829 Post(s)
Liked 3,376 Times in 1,580 Posts
This was where I learned to tape handlebars in the "harlequin" pattern. This is the method of weaving two rolls of different color cloth tape in order to end up with a pattern of diamonds of the two colors. In the same way that lacing up a wheel seems confusing at first, this method of weaving the tape is also confusing. In both, getting started is the hard part. Once you are going, you just keep up the pattern.
Here's a shot of my first and only attempt at doing a whole handlebar, just a few years ago....
It was complicated by using bar end shifters, so I started at both the tops and bottoms of the bars, and finished under the brake hoods.
I'm pretty sure I pdf'ed the thread that discussed how to do this, but hopefully it can be found with a search.
Steve in Peoria
steelbikeguy is online now
Likes For steelbikeguy:
Old 04-25-22, 07:14 PM
mobilemail
mobilemail's Avatar
Bikes: You mean this week?
Quoted: 29 Post(s)
Liked 29 Times in 20 Posts
Using oxalyc acid (deck bleach) to remove rust from frames.
mobilemail is offline
Likes For mobilemail:
Old 04-25-22, 07:39 PM
beicster
Quoted: 360 Post(s)
Liked 328 Times in 186 Posts
Did you decide to keep it built with the 650b wheels? Looks like it was made for them.
Andy
beicster is offline
Likes For beicster:
Old 04-26-22, 02:26 AM
52telecaster
ambulatory senior
I ground them down. The dirt is kinda cool I think.
Likes For 52telecaster:
Old 04-26-22, 02:27 AM
52telecaster
ambulatory senior
I think it's going to stay with 650b.
Old 04-26-22, 02:32 AM
merziac
merziac's Avatar
It looks good, one could take it down to the ridge, round the ends to match the mounting hardware and you might not know it was once a chainring.
merziac is offline
Likes For merziac:
Old 04-26-22, 03:05 AM
52telecaster
ambulatory senior
I stopped partly because it was getting difficult to hold but also I wanted it to be recognizable. It weighs very little.
Old 04-26-22, 06:01 AM
jethin
jethin's Avatar
Quoted: 288 Post(s)
Liked 330 Times in 160 Posts
Why would he would use Triflow on a headlight mount?
jethin is offline
Likes For jethin:
Old 04-26-22, 06:26 AM
thumpism
thumpism's Avatar
Jeez, left over from the chainring days, dude.
thumpism is offline
Old 04-26-22, 06:39 AM
USAZorro
Señor Member
USAZorro's Avatar
Quoted: 1491 Post(s)
Liked 1,093 Times in 640 Posts
When to (and not to) exercise +1.
USAZorro is offline
Likes For USAZorro:
Old 04-26-22, 08:04 AM
jethin
jethin's Avatar
Quoted: 288 Post(s)
I guess given the wave-particle duality it probably doesn't make sense to grease your lighting. It's still a good song though.
jethin is offline
Old 04-26-22, 01:56 PM
JLBiker
Liked 4 Times in 3 Posts
Great looking "harlequin" pattern handlebars
JLBiker is offline
Likes For JLBiker:
Old 04-26-22, 03:55 PM
John E
feros ferio
John E's Avatar
Quoted: 1393 Post(s)
Liked 1,326 Times in 837 Posts
I guess he doesn't floss his chainring teeth.
John E is offline
Old 04-26-22, 04:07 PM
52telecaster
ambulatory senior
I wear my tartar with pride.
