chain question, probably dumb
Quoted: 137 Post(s)
Liked 51 Times
ok. here goes. don't be too tough on me. currently have a 1 x front setup. 7 speed rear cassette. if i were to just take this wheel off and put a 9 speed wheel i have sitting around, do i have to also change the chain, i'm running a friction shifter for this bike, any help is appreciated.
Quoted: 2604 Post(s)
Liked 1,933 Times
Yes, the 7 speed chain is too wide to work with a 9 speed cassette. You'll want a 9 speed chain.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
1. The biggest factor is the size of the largest cog on your cassettes - if they're both the same, chances are very good the chain will be fine.
2. The second biggest factor is the width of the chain - 7 speed chains are wider than 9-speed teeth... but you might have a 9-speed chain already.
3. Far down the list... the chain and current cassette might be worn in to each other, and won't like changes.
4. And of course, your old chain may just be worn out anyway and you need to change it.
Likes For DiabloScott:
