1950s? Atala ID
1950s? Atala ID
picked this up local today, 1950s? atala. I don't remember seeing these lugs, then again I don't know much about atala. it has internal cable routing, campy sport derail, not gran sport, the cool suicide shift. can anyone shed any light on year or model....thanks. I'll post some better pics if there's any interest
Likes For konakai:
Quoted: 3813 Post(s)
Liked 3,345 Times
lug pattern is Agrati "BRIANZA"
head is bulge-formed and is item N. 000.8056
seat lug is item N. 000.8039
fork crown item N. 026.8058
bottom bracket shell N. 005.8057
dropouts item N. 000.8002
fork ends item N. 000.8010
metal knob on Simplex Competition front mech indicates it cannot be later than 1959
first two characters of serial on upper right side of seat tube will indicate year
cycle's wheel size is not mentioned. if 27" that would indicate it was produced for export to anglophone lands. if so, one would expect nominal frame size in inches, 21, to be marked in two places on the underside of the shell.
pedals appear to be Way-Assauto Sprint
pump holder cup is REG (Rampinelli)
Oldairhead
Oldairhead
Likes For juvela:
Quoted: 3015 Post(s)
Liked 3,804 Times
The 1954 Atala catalog is filled with Simplex and no Campagnolo. Also, I have only seen derailleur internal cable routing through the chain stay with Simplex derailleurs. I suspect the Campagnolo is a replacement. Also, with the internal routing was typical with Sport models. 3 speeds in the rear. But could be a lower-end corsa model too.
Love the Nanni stem, very cool.
Quoted: 566 Post(s)
Liked 1,052 Times
Not much to offer regarding provenance but no question I would have brought that home.
There are at least 2 Sport rear mechs. Is yours the bolt on or the claw type?
Quoted: 1106 Post(s)
Liked 1,328 Times
Both could use a claw - or not. A more fundamental difference is the presence/absence of a cable adjuster. This one appears to have one, so first style, early 50s.
Quoted: 3464 Post(s)
Liked 2,831 Times
Will be a rewarding project.
cannot tell if those are the original hubs or not.
I would reference as much as possible the original rims.
Liked 3,345 Times
wrt gear ensemble -
me guess would be that all three components original
appreciate it sounds odd to speak of mixing Lucien & Tullio
the Juy Competition front mech is the Simplex of Italy version, Juy operated a facility in Italy during the 1950's
note that the shift lever is Campag which would seem to make it less likely that the Sport is a replacement
reticient to disagree with iab since his knowledge so much vaster than me own
in the image below we can see that the gear block is at least 4V and may be 5V as the chain is stretched over two cogs. the cog in the number two position appears to be either loose or bent as it almost touches the cog in the number one position at one point in its circumference.
wrt gear ensemble -
thanks juvela, here's a few more pics if anyone's interested. I'd still like to I'd the year of this bike, the serial numbers don't seem to make sense, first two year as was posted earlier..., is the campagnolo sport desirable,, I know it's early but is it of any note....thanks
Liked 3,804 Times
The 7H4055(?) serial indicates a 1957 frame build. Sport RDs factory spec was 3 or 4 cogs with a 6-tooth gap, not a 5-speed. I think the 5-speed there now is a replacement. Also, the "C" on the shift lever is closed, pointing to a later replacement. I replaced the coiled-spring Huret (much like the Simplex this bike may have had) on my 58-60 Cinelli because it shifts like crap (again, like the Simplex) when compared to a Sport or Gran Sport.
But again, to the best of my knowledge and certainly not knowing the last 60 years of this bike's life.
Likes For iab:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I agree that the derailer has been replaced, and that it was probably packaged with the single shifter. I see what look like witness marks from a change of band clamp on the downtube, and the Simplex lever as well had too large of a spool diameter to work well with that derailer.
Only today did I learn of the metal FD knob surviving through 1959!
Rims possibly may have been laced to the original hubs after bike left factory. Common to find such and 27" in steel would be the normal size/type for non-racers to choose.
This is a really cool bike find! If no frame damage then wow!
Check the back side of the crank spider to verify it's forged and not perhaps welded (this would indicate a higher-tier model).
The big chainring's integral 3-to-6 arm "adapters" would suggest a mid-range model, no?
aged to perfection
Quoted: 838 Post(s)
Liked 1,258 Times
that's a really special bike. whatever you do, don't "wax" it. you're just rubbing the dirt in. find somebody who knows how to restore the original paint.
I good wash might brighten it up a lot. Use Dawn Ultra and a splash of kerosene in the wash water
/markp
/markp
