Campagnolo self extracting crank bolts???
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 251 Post(s)
Liked 167 Times
Hi folks,
My refurb assignment this week is a 1994 Specialized Epic road bike with Campagnolo Veloce components. The crank arm bolts appear to be "self extracting", but I haven't work with this brand before. Is this what they are and how do they work? See pix.
Thanks & regards,
Van
Thanks & regards,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Quoted: 1438 Post(s)
Liked 1,092 Times
To remove self-extracting components, turn the bolt counterclockwise; after initially breaking loose it will turn a little until it engages the crank then the effort will increase until it pulls the crank free from the taper. It might be helpful to apply a little oil between the bolt and crank to reduce the friction as you are turning it to pull the crank free.
Quoted: 2026 Post(s)
Liked 1,096 Times
They are indeed self-extracting bolts so, as dsbrantjr noted, they will get loose and then tighten again as they begin to push on the collar with the two pin hole recesses. Keep turning and the crank arms will come off. BTW, while everyone else uses an 8mm hex hey for the bolt, I believe Campy uses a 7mm so be prepared to buy one.
Likes For HillRider:
Quoted: 1303 Post(s)
Liked 1,911 Times
Senior Ryder,
I have a left arm laying here unused that has the self extracting bolt and ring intact. Yours if you want it. Cost of shipping about $5. The ring has a left hand thread so it is specific to that Campy crank. Lemme know, MH
if the OP doesnt need that left side arm, I could use it if its 170mm. Please let me know.
mike
mike
