I think a LBS just broke my Future Shock 2.0
Just purchased a 2021 Roubaix Expert about 3 weeks ago.
I went for a bike fitting last week and it was recommended that I swap out for a smaller hover bar and different stem - all good so far - got the parts and took the bike in yesterday, picked it up today. Should have been a simple job, swap out the handlebar and stem.
Got home and looked a little closer and noticed the Future Shock adjustment knob seemed loose - then I noticed the entire knob now comes off - the plastic knob along with the metal part that fits inside the plastic knob now lifts off. Further it turns out when I put it back on and turn to loosen the tension, the long pin that fits down inside keeps turning and now will also come apart.
I would post pix, but the site won't let me since I'm new
So what the heck did they do? Is this repairable or am I now going to have to replace the entire FS 2.0 cylinder? I'm going to take it in to a Specialized dealer tomorrow, but thought I'd see if you guys have any thoughts.
Help!
Help!
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Swapping stems on the FS2.0 requires removal of the knob, you've described. Are you sure it is broken, and simply not re-installed properly? When it is installed, there is a set screw that must be turned with a 1.5mm Allen key and tightened to 2Nm (18in-lbf). Check that first, you may be fine, they simply didn't tighten it correctly.
It will likely have to be replaced - I'm most upset that they basically broke my less than one month old bike.
Quoted: 532 Post(s)
Liked 621 Times
Yeah, it's certainly broken. I know about the set screw - it's still there, but the metal piece that the plastic knob and set screw attach to comes off and it's inside the plastic knob. From what I can tell it looks like the guy basically just unscrewed the whole knob (counterclockwise) like it was a normal stem cap, which then broke the clip that held it together. It now just spins freely and comes off - it's supposed to have clicks or notches as you turn and adjust. I still can't post links, but i you add "https" in front of this, maybe you can see what I mean - //imgur.com/a/PKvZio5
Based on your post, it would appear that the fitting work was done at a shop that is not a Specialized dealer. Is that correct? I'd notify them Monday morning that it appears that their mechanic and/or fitter may have damaged the FS cartridge when they swapped the stems. They'll likely hem, haw, and deny....whatever. Then take the bike to a Specialized dealer, get it diagnosed. If there are costs to you associated with the repair/replacement of the cartridge, I hope the shop that did this will stand behind their work and reimburse any costs they've caused you.
I'm sorry for you, man, this sucks. The upside is that this is fixable...but, now it's a potential ball ache to get it rideable again.
I've got bad news for you...when the set screw is loosened, the cap slips right off, and there is no metal piece inside the cap. I haven't done any disassembly beyond taking the cap off (in preparation for also charing my stem and bars this week). What I'm wondering is what the top of your FS cartridge looks like? Because that piece inside the rotary knob appears to be the top of the FS Cartridge.
Quoted: 532 Post(s)
Liked 621 Times
Yep, that metal knob is the top of the FS Cartridge - totally what that piece is - and it should be attached to the cartridge, not coming apart like it does now. The shop that did the work seems pretty up and up and high end, so we'll see how they handle this. At the end of the day as long as I can get it fixed, even if I'm out some cash, it shouldn't be too costly. I just hope they can get the parts fairly quick - everything seems to be in such short supply!
Again, seems pretty fragile in the end.
Liked 3,022 Times
I'd have to get a lot of miles in before the bicycle is perm retired at the time it reaches 500 hours. How fast would the average mph need to be to achieve 30,000 miles in 5 years when only riding 3 days a week? lol
-Oh Hey!
-Oh Hey!
Quoted: 4224 Post(s)
Liked 3,917 Times
Back in the day of dawning suspension manufactures had maintenance schedules based on hours of use, often only 50 to 100. Ride your bike three days a week for a couple of hours each time and that's 8 to 17 weeks of use, a short part of a season in many locals. Of course most every buyer didn't read this part of the manual and never did this maintenance until it became a repair lever job. (and by then with the rapid pace of suspension development often replaced the fork anyway).
If the current fork has a 500 hour maintenance interval I consider that really good. 500 hours divided by that same 6 hours a week and you have what is reasonably 2 years of use, in mots locals, between service. Andy
AndrewRStewart
AndrewRStewart
Liked 3,022 Times
-Oh Hey!
-Oh Hey!
Dirty Heathen
Quoted: 889 Post(s)
Liked 928 Times
imagine if vehicles never improved upon the suspension design from the 50s & 60s. Ball joint life would be about an oil change internal nowadays. I still think bicycle suspension forks should not be so craptastic nor cost so much for the "upgrade". Especially the split suspension forks. They way as much as a 1950s Buick.
You obviously don’t mess around with high performance equipment much. There’s a whole spectrum of cost/ durability/ performance to pick from.
Stuff designed to be low cost, and durable isn’t really high performance.
On the flip side, really high performance (ie; “Race” level) typically is both expensive, and requires regular service to keep operating at that level.
The FutureShock is more on the performance end of things. If you want super low maintenance, get a Redshift.
You want high performance, and extreme durability? It’s going to be really, really expensive;
Liked 3,022 Times
My ref is IAW OEM provided products. If I had to immediately go out & upgrade to an aftermarket product, knowingly the OEM item is majorly flawed before riding it, I'd go to a different OEM entirely.
-Oh Hey!
-Oh Hey!
Liked 3,917 Times
Low cost, light weight, strong. Pick two. Or, maybe, for suspension- affordable, light weight and maintenance "free". Andy
AndrewRStewart
AndrewRStewart
Liked 3,022 Times
Light weight & maintenance - "free" is my pick for an OEM suspension fork.
-Oh Hey!
-Oh Hey!
Dirty Heathen
Quoted: 889 Post(s)
Liked 928 Times
If you want it to be ‘eternally maintenance-free’ it’s either going to be super-basic, or super-expensive.
I would posit that, if you want light weight, high performance, then increased maintenance is going to be the cost.
If you want to compare industries, I’m in deepwater oil production. The equipment out here is massively strong, massively expensive, and absolutely cannot fail. Each campaign requires hundreds of hours of testing and preventative maintenance before any asset goes in the water. The main seals on the docking collar are $10k, 100 lb Inconel rings that are good for exactly one use.
So, a once-a-year service on your bikes’ suspension doesn’t seem too unreasonable
Liked 3,022 Times
How is it ‘majorly flawed?’ Because it has a service interval? Making a sophisticated lightweight, responsive bike suspension system *for a reasonable cost* is going to require giving up something somewhere.
-Oh Hey!
-Oh Hey!
Quoted: 1250 Post(s)
Liked 1,336 Times
so I went to the local Specialized shop, as expected the whole cartridge needs to be replaced. They’re sort of freaking me out, said they’ll have to call tomorrow to see if they have it and the one tech said oh that’s going to be very expensive! I said it shouldn’t be over a few hundred max, I believe Specialized recommends having it replaced every 500 hours, so l’ll be hacked if that’s expected to be a $500+ repair every year.
Dirty Heathen
Quoted: 889 Post(s)
Liked 928 Times
Agreed. It looks like the FS is coil-sprung w/ an oil damper. Rolling on needle bearings (like the old Headshok) it doesn’t have the friction of wiper seals like a telescopic fork, do there doesn’t appear to be much to wear out.
Dirty Heathen
Quoted: 889 Post(s)
Liked 928 Times
Not likely to be the case for the average suspension fork equipped bicycle. I couldn't even buy my exact color fork 1 year after a new bicycle purchase, nor could I obtain the OEM parts to refurb the old one. Much rather have paid more upfront to not need to service nor deal with those headaches.
A lot of budget hybrid forks are actually less expensive to swap out than to rebuild. The rebuild parts can be found, but there’s not much performance in rebuilding a basic fork like that.
Frankly, with 1-1/8 threadless being pretty much standard, changing a fork is a lot easier than it used to be when cutting and threading was required.
If you are going to select an integrated system, like FS, or Headshok, then the possibility of limited support in the future is the cost of doing business.
Likes For Ironfish653:
Future Shock Fixable: Retaining Clip and Hex Coupler
Likes For jimsforest:
Quoted: 532 Post(s)
Liked 621 Times
I know this was a few months ago, but this is fixable without a replacement cartridge. Check out the "the bike sauce" video on youtube (search for future shock repair 2.0, I am unable to post the link). Assuming this is the issue, as long as you retained parts you are good. Basically the top is held on by a retaining internal c-clip, then then hex adjustment knob connects to the coupler. In my case this worked, but much like the video I cannot locate the adjustment ball (must look like BB's, assuming there are two) and Specialized doesn't sell them. Still looking, but in the meantime it turns w/o the "click".
Hahahaha - thanks - I had to reply So the bike shop ended up paying for the repair on my bike and that left me with the broken parts - I had reached out to the guy at The Bike Sauce originally to see if he knew anything about how to possibly repair the 2.0 (I think he had a tear down of the 1.5 version or something) - in any case he asked for my broken parts, which I sent to him and he figured out how to "repair" it although without the clicks.
So long story short - the cartridge you see in the video is actually my broken cartridge! Small world and all.....
Likes For julric01:
