Show Us Your 650B Conversions
#901
Quoted: 7348 Post(s)
Liked 2,470 Times
@bikemig, I spread two 120 frames to 130. I think it's OK to do this.
@gugie, your links to Park tools don't work for me.
#902
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 335 Times
#903
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Unless the stays are identical on both sides, one side will bend more than the other. Many bikes have an additional indent on the drive side chainstay to provide chainring clearance, and that makes the stays bend differently.
Likes For JohnDThompson:
#904
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
#905
I know I've shared this elsewhere, but perhaps not here.
I use a Park FFG-2 alignment tool, marked as you see here, to precisely spread and align the rear triangle as I go. Knowing the amount of hysteresis in typical Chrome Moly or 531 rear stay tubing to be around 20%, I stop adjusting the alignment at 130mm and continue spreading to about 165 - 170mm, as Andy_K suggested here. Then, just to make sure, I use the string check to verify correct centering. If that is off at all, I have an old broom handle with a 'C'-shaped notch on one end that I use with a medium sledge hammer to correct the offset. This has always worked for me.*
I was looking at the Park FFG-2 alignment tool online. $108 for a set - might be worth it if this method allows for some finesse. Using this tool set in combination with string alignment may be something I would try. The current spacing on my Trek 710 is 122mm that I spread to 130mm by hand when installing the rear wheel. It's a bit of a struggle. If I could get the spacing to 126mm + that would make it pretty easy to install the 130mm wheel.
One question. Once the Park Tool FFG-2 tools are tightened into each drop out, do you then spread the drop outs by turning the large cylindrical portions of the tools using channel locks?
#906
The FFG-2 is used to make dropouts parallel after rear end has been re-spaced and aligned. The cylinders are turned by hand, you then manipulate the handles to align the cylinders.
#907
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
The dropouts themselves are too pliable to be used as place from which to spread the frame, at least with this tool which isn’t solid all the way across. There’s the old nut threaded rod method, but you’re better off with the 2x4 strategy, or better yet the Park FFS-2.
I realize this is outside the intended scope for this tool, but it doesn't damage the dropouts or the tool itself. The results speak for themselves - every one of my modified frames is perfectly aligned.
As always, YMMV.
USMC 1981-1991 Semper Fi!
#908
I stand corrected. Sounds like it works. I’ve never liked the idea of levering off of the dropout versus the stay. Not the way I’d do it, but I also have access to more appropriate tooling.
#909
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
But in this particular case, I analyzed the strength of the tool against the resistance of the rear triangle assemblies, identified the differential resistance of the DS stays, and determined that I should use the string alignment method throughout the process. The troglodyte approach of using a sledge hammer and broomstick to sort of equalize the stresses in the assembly was my only real contribution to the existing body of knowledge.
Thank you for taking the time to question my assertions and prompt me to re-examine my methods. I appreciate the respect with which you did this, and would welcome any PM communications in the future.
#910
Yes it is...
It's an decent fork, quality is very good, finish is good, has appropriate mounts in all the right places etc. The downside is the same as most mass-market forks, in that it's sturdier* than it really needs to be, but for the amount of money it costs compared to a custom fork (with chrome finish) you can't really complain and it's one of the few options available in that offset and with a 1 inch steerer.
* The ride isn't as cushy as some of the nicer forks I own, but it's not so much of an issue with squishy 42mm tyres.
#911
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
Will do a build thread eventually as it has a story to tell. Test ride today to check out brakes/shifting etc. Ultimately need to decide whether to keep the short stem with the shorter top tube and the narrow bars compared to my normal setup. But nice riding setup so far!
Likes For AJI125:
#912
Bikes: too many old steel bikes
Quoted: 136 Post(s)
Liked 938 Times
Grand Record 650b conversion
Here is my artistic spin and build circa 1973 Moto Grand Record). @gugie did the frame modifications, braze-ons, and front rack. I built the wheels and bike. Plus, I added the painted lugs, lug lining, and box lining.
Likes For Andy Antipas:
#913
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
#915
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#916
tantum vehi
Liked 992 Times
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Likes For mountaindave:
#917
Quoted: 136 Post(s)
Liked 938 Times
Fender Lines
Thank you Dave. I think this is my forth attempt at fender lines? Practice makes perfect, but I gotta say that monsieur gugie modifications made getting reasonable fender lines much easier.
#919
Quoted: 136 Post(s)
Liked 938 Times
Radios No. 16 headlight
I have modified it with "guts" from a modern LED headlight, and there is a thread somewhere on Classic & Vintage that shows what I did.
#920
Quoted: 151 Post(s)
Liked 303 Times
Thanks Dave. But you’re mostly just excited it’s half step gearing I bet (whether consciously or subconsciously I’m not sure)! 53-49-36 though, what am I thinking with all these hills around here!
VeloLumino’s excellent guide goes a long way for fenders! And the Fender Line thread was a great inspiration. Mostly doing it for the second time and being patient does the trick. Needed the extra front stay with no rack or anything and tried to more or less ratio it positioned the same as gugie’s Vintage Peugeot he posted on there. Almost didn’t post anything yet with my crashed bar tape from my old bike haphazardly wrapped on there, but still not sure about stem/bars so figured I’d recycle it for now (and bonus it kinda matches the decals)!
#921
tantum vehi
Liked 992 Times
Anton is good at what he does and his tutorials are impressive. It may be a bit snobbish, but I feel like good fender lines help tie the entire bike together. I’m not an architect or designer, but one can sense when an object is out of proportion, or it’s lines out of balance.
Vive la conversion!
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#922
tantum vehi
Liked 992 Times
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#923
Liked 5,800 Times
Likes For gugie:
#924
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
#925
Location: 68 Nguyễn Huệ, Bến Nghé, Quận 1, Thành phố Hồ Chí Minh 70000
Could you tell me where I can get fenders like the one pictured on your bike? I have tried searching but must be looking in the wrong places.
