Calibrating distance on computers - long measured courses - surveyors wheels?
Quoted: 347 Post(s)
Liked 418 Times
https://support.google.com/maps/answ...form%3DDesktop
Last edited by billridesbikes; 05-13-22 at 04:50 PM. Reason: don't let the best be the enemy of good
Quoted: 4259 Post(s)
Liked 1,362 Times
An accurate way would be to use Goggle maps distance measurement tool and trace your route using the breadcrumb method to find the distance of the route. The bike computer will probably measure something slightly longer due to errors in elevation. Elevation in Goggle maps won't be as accurate as surveyor data so the longer the distance the larger the error, but you wouldn't be wasting your life walking around with a surveyor wheel all day either. As we engineers like to say, don't let 'the best' be the enemy of 'the good'.
Quoted: 347 Post(s)
Liked 418 Times
Correct. And I think Goggle Earth assumes a perfect spherical Earth, so there will be some error for that as well. For example if you take 1 degree arcs around the equator on Goggle Earth and compare them to published values they're slightly off. A 1 degree arc at the equator should be 111.3195km but Goggle Earth will measure 111.1951km or about a .1% error.
Quoted: 2976 Post(s)
Liked 1,182 Times
When a speed sensor is paired with a Garmin Edge bike computer it it will automatically calibrate after riding for 1 mile.
