How practical is it to have multiple sets of wheels for the same bike?
Bikes: Way too many
Quoted: 900 Post(s)
Liked 607 Times
Not wanting to have more bikes, I'm considering getting additional sets of wheels to cover different purposes (so the gravel bike with road and gravel tires, mountain bike with wet and dry tires). I've heard indications that I'm likely to need to have to tweak the rear derailleur when changing between wheels, is that the case?
Would I be better getting exactly the same wheels for both pairs, with the same cassette and discs, or will I be able to get away with swapping between the stock wheels and some upgraded ones?
Quoted: 2952 Post(s)
Liked 3,106 Times
It makes a lot of sense, especially if you're dealing with tubeless. My son and I share 4 sets of wheels between our 2 CX bikes. Different treads and widths for the conditions, but same cassettes makes that part simple. We've been lucky that we haven't had to do any futzing with the RD. As for discs, I don't know. These are rim brake wheels.
Quoted: 18378 Post(s)
Liked 4,512 Times
I've always liked to double check the derailleur adjustment when swapping wheels.
However, if you have the same brand/model of hubs and cassettes, then the changeover should be easy enough. The size of the sprockets shouldn't make a huge difference as long as your chain works with the largest cassette.
If you have tire clearance, and have DISC brakes, then you may be able to use both 650b and 700c on the same bike.
Likes For CliffordK:
Bikes: Way too many
Quoted: 900 Post(s)
Liked 607 Times
I hadn't actually considered changing down to 650b but that's actually a great idea. That means I can potentiall run 700x32c and 650x50c on the same bike
Both bikes are tubeless, which is part of why I was considering it. I don't mind changing tubed tires over since it only takes a few minutes, but I don't fancy having to deal with sealant every time I change tires.
Likes For Herzlos:
Quoted: 4227 Post(s)
Liked 2,488 Times
Personally I have 6 pairs of wheels, but all of my bikes are also singlespeed and fixed gear so it makes it a little easier to swap wheels.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
I have two sets of wheels for my touring/commuter bike. Swapping them out requires no adjustment. I am very likely to get a second set for my gravel bike.
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
This is done all the time if you race --- might have a set of wheels for different conditions plus a set of time trial wheels
TT wheels will have a tighter cassette generally but normally not much to ever have to fuss over. I used to race track - ditto there - had multiple sets of wheels. Spoked trainers, race wheels, discs, 3 spokes, 5 spokes etc etc
I have a burly set of Enduro spec wheels on my mountain bike for durability reasons , but id like to try a speedier set of XC wheels --- seems like the same principle - just have to have the same size disc rotors, rear spacing and a cassette in a similar dimension to your current one --- a chain and rear derailleur optimized to run with a 11-46 might not play nice with a 10-51 for instance
But alas , in the end it seems like a lot to futz with so i havent done it
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
I run 700x28c and 650bx47c on the same bike. The tire/wheel combo is the same circumference, so I don’t even have to make any changes to the speedo/odometer settings. For optimum performance you’ll probably be running different sized cassettes for each wheelset. I just adjusted the b screw to split the difference and have never had an issue.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
In theory, multiple wheel sets should work. In practice, not so much…especially if you want to ride the same bike over very different terrains. The wheels are of less importance than the frame and drivetrain when being used on varied terrain.
Stuart Black
Stuart Black
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
Of course it's a compromise compared to having the budget and storage space for two unique bikes, but the gearing doesn't have to be exactly the same, for example one could run an 11-34 on the 650B wheels for looser gravel and an 11-28 or 11-32 on the 700c road wheels, and since the latter are closer spaced subsets within the range of the former the chain length should still be viable with the RD capable of wrapping the bigger one.
That also seems like it could partially undo changing from a 50/34 to a compact 46/30 crankset - sure, the very highest gear would be lost, but the people missing 50:11 and finding 46:11 insufficient are probably precisely the people unwilling to do their road rides on a gravel geometry / tire capacity frame. Plus someone could presumably swap the hill-gears cassette to the road wheel for the occasional mountain climb event run on a well paved road.
Of course to really take advantage of this, I'd probably need to buy not just the 650B wheelset, but another 700c, because the rim width of what I have is more suited to mid-30's gravel tires than road tires; but that also means it's an all-around compromise that does most of what I need, though I wonder a little if I'm wearing out the tread of the gravel tires riding 90% on roads. I've considered just getting some 32mm slicks...
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Every time I’ve tried a second wheelset it ends up growing into a whole new bike.
Likes For Kapusta:
Bikes: Way too many
Quoted: 900 Post(s)
Liked 607 Times
At the top end, I'm sure. But I'm not in a position I think I'll notice. My 36/48x11-36 on the gravel bike will do me fine or gravel or road; I could maybe do with a larger front cog for the road and a smaller one for gravel but I manage both with the same bike now. Ditto for my 34x11-46 on the mountain bike, it's been fine for everything so far. I just want slicker/faster tires for when I can use them, and knobblier ones for when I need them.
It is. I want to be able to pretty quickly change the bike between modes. Currently I can do it on tubed bikes by changing the tires on the same wheel but that's a 10+ minute job instead of a 1 minute job.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
It worked ok for me with my old 26er MTB but turned out to be unnecessary. I had a set with smooth tires for warmer dryer weather and a second set with small knob tires for winter.
Turns out I like having the Race King with small knobs in front all the time and I made it through winter trail mud with the Speed King in back. So the bike is plenty fast on smooth stuff and plenty stable on muddy trails with no need to swap tires.
I still have an extra rear wheel but I gave the spare front wheel to my son when he smashed up his front wheel when he first started riding again.
Otto
Otto
Liked 2,974 Times
very practical if you are a road rider & have limited time/weather to ride in.
-Oh Hey!
-Oh Hey!
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I'm a huge fan of multiple wheel sets. I have one bike (Specialized Roubaix, endurance) and use it for road (30mm Conti GP5000 S TR, Roval CLX50), gravel (35mm Conti Terra Speed, Light Bicycle WR50), and winter studded tires (35mm Schwalbe Marathon Winter Plus, DP Swiss wheels). No the frame is not 100% perfect for gravel but it is 95% perfect.
I have the exact same disc brake and cassette setup on all three wheel sets and I generally don't need to re-align anything when I swap wheels. Its a 2-minute operation.
Likes For scottfsmith:
Quoted: 5224 Post(s)
Liked 3,582 Times
often toyed w/ the idea but never pursued it. but then, I have 3 bikes
Quoted: 2333 Post(s)
Liked 2,097 Times
I cannot imagine only having one set of wheels for a bike.
Not a big deal to change wheels.
Quoted: 426 Post(s)
Liked 274 Times
I have several wheel sets and chains for my gravel bike. My rear cassettes 30T; 34T; 40T.
Transforms bike between GP5000 28mm carbon wheels 30T; 32mm gravel kings 34T; 38mm knobby tires 40T
TBH now I mostly just ride with the 32mm gravel king slicks. It's a little slower on the road and dirt but can do both. If I riding with my road buddies I have to use the carbon wheels and GP5000. If I am ridding with mnt bike people I need all the help I can get. I still can't keep with them on descents though.
If you don't need extra speed ( to keep up with your friends, chasing strava segment times, etc..) you might just be happy with just one wheel set with 32mm gravel king slicks.
Quoted: 3952 Post(s)
Liked 7,298 Times
Likes For tomato coupe:
Quoted: 20810 Post(s)
Liked 9,456 Times
It's pretty practical if you're only talking about two wheelsets and if you tend not to flip-flop between modes frequently.
Limiting it to two wheelsets makes things nice because it's easier to get things like rotors in agreement (if the positions are slightly off, shim the inboard rotor out to the position of the other rotor; IOW, you can shim a rotor outwards, but not inwards) so that you don't have to fuss with anything when you swap out. And I may just be lucky, but I haven't had to do any RD adjustments to accommodate the cassettes of different wheelsets on a disc bike, but I'm sure that mileage will vary.
That said, I'm kind of lazy and don't want to swap out wheels multiple times per week, but that's usually not a problem.
Likes For WhyFi:
Quoted: 1083 Post(s)
Liked 687 Times
Very practical as long as you can use the same gearing. I had three sets of identical wheels built, specifically for that purpose. Since the rims are the same (Sun CR18) and so is the rear cassette, I don't even have to adjust the brakes.
Nothing makes a bigger difference in the way a bike handles and performs than wheels and tires, so having multiple wheelsets is almost like having completely different bikes only cheaper and doesn't take up as much room. I can switch from smooth pavement (Panaracers) to dirt and gravel (Maxxis Ikon) with a quick wheel change, and for something "in between" I can throw on the Continental Contacts when road conditions permit. It truly is like having three different bikes and it literally takes under 5 minutes to switch.
It's definitely the way to go if you can make it work for you, specifically using the same gearing for all road conditions.
Likes For Jeff Neese:
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,437 Times
Advanced Slacker
Liked 2,537 Times
In the end, second wheelsets just don’t work out for me. If different use-cases are different enough to warrant extra wheels, rotors, and a cassette just to have different tires, then there are always other things that I want to change as well (e.g., gearing, cockpit setup, suspension, fenders, racks, or just how tempting it is to thieves).
The only tire swapping I do is putting studs on the commuter in the winter, and some years I swap out the rear tire on my FS mtb for a particularly wet or dry season.
On my Pavement/Gravel bike I just run 38mm Rene Herse EL slicks for everything from pavement to gravel/dirt roads.
