Shimano Changers Worn - Replace or Rebuild?
Bikes: 1974 Copper Raleigh International, 1975 Olive Green Raleigh Grand Prix, 1974 Raleigh Europa Custom
Quoted: 104 Post(s)
Hello all, attached are images of my brothers bike. The RHS changing is sluggish and now won't go into the high gear. Before I venture further, cassette and chain will be replaced, but are the changers servicable or do you replace the whole unit? Cheers
Quoted: 3811 Post(s)
Liked 6,717 Times
I’d start with a thorough cleaning of your whole drivetrain and a good flush of those brifters.
Likes For nlerner:
Quoted: 3464 Post(s)
Liked 2,831 Times
The imaged lever is a Microshift
make sure they are compatible with the ultegra derailleurs and the cassette.
this is on the near border of C&V, almost too young.
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Everything looks well used. The derailleurs and shifters are probably not the issue. Since you're replacing the cassette and chain, I would also replace the cables and perhaps the cable housing. If it were my bike I'd replace the chainrings and the rear derailleur pullies.
Jeff Wills
Jeff Wills
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
the large ring has some shark teeth...ie. really worn. replace that. and, if you do that, you'll need to replace the smaller ring, the chain, and cassette...if you do things "proper" like.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 104 Post(s)
Thankyou and greetings gentleman, for your prompt responses. Looking somewhat like a grifter rabbit hole. To clean or not that is the question 50/50. Thanks for picking up thee aftermarket jobbies. And please move if in the wrong section kind sir
Microsoft R9 is Shimano 9 compatible for sure with "fresh" cable and housing. Ultegra mechs can last a long time with the occasional clean.
Quoted: 4722 Post(s)
Liked 3,039 Times
Step 1: Thorough cleaning of drivetrain and alignment of rear dropout hanger. Typically, that solves about 80% of indexed shifting woes.
