Sealed cartridge bb question
Bikes: 70's Nuovo Record Jeunet Franche Compte, '88 105 Trek 1200, '85 Victory Bianchi Vittoria, '89 Exage Bianchi Strada LX, '11 Shimano Masi Partenza
Quoted: 109 Post(s)
Liked 19 Times
I just installed my 2nd Shimano sealed cartridge bb tonight. The first one went perfect, but this 2nd one's a tad loose. The spindle's just a little loose inside the cartridge; is that supposed to be like that? I usually only use old school bottom brackets.
70's Nuovo Record Jeunet Franche Compte, '88 105 Trek 1200, '85 Victory Bianchi Vittoria, '89 Exage Bianchi Strada LX, & '11 Shimano Masi Partenza
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Is the spindle loose in the cartridge, or is the cartridge loose in the BB shell? I got a new cartridge once which had a plastic adjustable cup that had a very small amount of play between it and the cartridge. I solved it with a shim of metal foil chimney tape.
The spindle should definitely not be loose in the cartridge.
Quoted: 109 Post(s)
Liked 19 Times
It's loose in the cartridge. Not by much, but I can definitely feel it when I grab a crank arm.
Quoted: 4208 Post(s)
Liked 3,875 Times
Most of the "sealed cartridge type" BBs are not meant to have the bearing preload adjustable or to be taken apart and serviced. That is the glory of them, plug/play/forget/replace when worn out...
If the play is not noticed when riding I might not do anything. If the play is enough to cause problems with front chain meshing, shifting or excessive chain rub on cage then i would replace the BB with one that wasn't loose.
Have you taken this up with the outfit that you bought the BB from? Andy
AndrewRStewart
AndrewRStewart
Quoted: 109 Post(s)
Liked 19 Times
