Headset Expander Not Tightening
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1301 Post(s)
Liked 941 Times
I took this expander bolt and expander from my Miche Primato 1" headset out of my steerer tube, and now, when I put it back in to re-tighten, the bolt at the headset cap just keeps spinning (no resistance). What am I doing wrong?
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Likes For soyabean:
Quoted: 1614 Post(s)
Liked 2,602 Times
Can you thread it down until seated and then install and tighten?
Likes For curbtender:
Quoted: 4212 Post(s)
Liked 3,883 Times
If the threaded cone isn't contacting the expanding band with enough force to keep it from rotating, when the bolt is turned, that cone can easily just spin with the bolt and no tightening will happen. Of course the cone's threads could be stripped but that usually has a "it sort of tightens but not enough to hold in place" feeling when turning the bolt. It also should be easy to watch the bolt thread in and out of the cone as well as look inside the cone's threads to be sure of their condition.
BTW I grease the cone and band's contact surfaces. Al loves to gall and stick to itself when under pressure. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Standard Member
Liked 941 Times
I have inspected, and the threads are not stripped, but they are binding. It is taking me some force for me to turn the compression bolt on the top cap against the wedge (holding the wedge with chan-l-locs), so that when I turn it in the steerer tube, it just spins with the wedge, instead of screwing down into it (to compress the spring). I have cleaned and re-greased the bolt and threaded section of the wedge. The bolt is still not turning as freely as is required. A bike shop got this headset installed, though, so I am wondering how they got the sleeve to expand.
Quoted: 1163 Post(s)
Liked 442 Times
That is not a very substantial steerer plug. 1” threadless designs I have seen never inspire much confidence. Designs that provide grip and expansion along their entire length eliminate a lot of the uncertainty.
I’m not familiar with the Miche Primato one shown but I am curious about the middle aluminum cup shaped piece. Is there any chance it needs to be reversed to allow the threaded wedge piece at the bottom to have more purchase? Another thought about that cup shaped piece is that the groove on it is for another O-ring. Any chance it had an O-ring originally?
Also, does your 1” threadless fork have a carbon or aluminum steer tube? You might be able to get the wedge pieces to stay put while tightening by applying some grip paste to the outside surfaces.
Liked 3,883 Times
We assume the steerer is a carbon one as otherwise a star nut would have been used. Andy
AndrewRStewart
AndrewRStewart
Standard Member
Liked 941 Times
This suggests that either the bolt or the threaded cone's threads are buggered up. Given the steel bolt and Al cone I guess the cone's threads. One could chase those threads with a tap (most likely a M6) to see if that helps.
Liked 3,883 Times
Standard Member
Liked 941 Times
You know, I didn't even think of that. Choice. Thanks, Andrew.
