Shimano Hollowtech Crank Install - How to confirm 180 degree install
Quoted: 192 Post(s)
Liked 11 Times
I am simply replacing a left crank arm with a power meter crank arm and wondering how to confirm a perfect 180 degree install between the left and right arms. I might be over analyzing this, but after install it seems the cranks may be a few degrees off from 180 degree...it could also be an optical illusion given no part is perfectly straight anyways. Is it event possible to be this close to 180, but not spot on?
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
edit: it's been awhile since I installed mine, but I think the little "safety plate" can only hook onto the spindle if the crankarm is in the correct position.
Likes For datlas:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
You cannot install the non-drive side (left) crank arm incorrectly. The splines are keyed, meaning they are not equally sized and spaced, to ensure that the left arm can only be installed onto the spindle at 180° from the drive-side crank arm.
Likes For Badger6:
Quoted: 850 Post(s)
Liked 344 Times
Above two are right of course. Nothing more to be said about this topic specifically.
But I'd like to say that this is a FANTASTIC example of how good design improves lives with almost no drawbacks. Shimano could *easily* have chosen to design a splined interface that's radially symmetrical and thus requires careful installation to align. And then if you screwed up the install, Shimano could blame you, the user, for not following their instructions or whatever.
Remember this next time a company tries to blame the user.
Likes For smashndash:
Quoted: 192 Post(s)
Liked 11 Times
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
You guys have all read the studies that prove that crank arms 180 degrees apart delivers maximum performance from a bike? Yeah, nah. You probably still use round chainrings too.
Quoted: 1529 Post(s)
Liked 718 Times
Well actually... You can totally install it at 0 degrees if you like, and folks who pedal with their arms do. It'd be nice if Shimano would put another hole for the check pin for these peeps...
Quoted: 532 Post(s)
Liked 621 Times
Though, I admit, I've never tried to do this...but, now you've got me curious.
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
You can't install it incorrectly unless you hammer it in. The safety pin won't go in if the left arm is not slid into the spindle correctly.
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
agreed that Shimano was smart in keying the crank arm just like its cassettes/freewheels
Saved countless hours of aggravation by garage mechanics like myself.
Quoted: 532 Post(s)
Liked 621 Times
The keying isn't what ensures you can't do it wrong, it's the splines.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Besides the stopper plate and it's pin needing to in the hole in the crank axle how hard is it to just look at the damn things and know instantly?
Likes For cxwrench:
I had exactly the same thing happen
I'd hazard a guess that the OP is installing an FC-9100 era crank or later -- the way those arms are shaped makes it easy to second guess whether they are 180 degrees apart.
Likes For ljsense:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Exactly. The drive-side (right) crank arm is asymmetric on HT2 road cranks, but this is only obvious when viewed from the drive-side. When one installs the non-drive-side crank arm, the asymmetric profile of the drive-side crank arm throws off one's perception of the crank angle from the non-drive-side. It took me a while to figure this out when I installed an FC-R7000 crank set. No such issue with GRX cranks.
