23mm vs 25mm diameter for tight seat tube clearance
My old steel Trek 957 frame hardly has any clearance between the wheel and the seat tube. With 23mm tires I've only got a few mm clearance with the derailleur bracket.
I'm a bigger dude...220 lbs. I've been riding this with 23s for the last 5 years. Just blew the sidewall in a newer GP5000 so time to buy new tires anyways.
I'd go 25mm tires if I knew I still had clearance.
Anyone know or recommend a 25mm tire that only gets wider and not much taller?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Good of you to provide a massive close-up photo. Too bad it's from such an angle we can't tell a damn thing about tire clearance.
Quoted: 6196 Post(s)
Liked 4,810 Times
Why did your sidewall blow out? At 220 lbs you aren't an issue for bike tires. So perhaps you run too low a pressure or way to high a pressure. Usually low PSI will be snake bites, but damage to the tire casing can be an issue too if the tube is lucky enough to stay out of the way.
No, typically I expect bicycle tire dimensions to increase the same in over all diameter as the change in width.
Liked 4,810 Times
I assume a punctured sidewall should be replaced.
I've never had a wreck from a tire failure no matter the speed I was doing. I could always slow down and stop safely. Maybe one day....
For any puncture, including sidewall punctures, the deciding factor for me is how much does the area around the puncture pooch out when the tube is inflated to proper riding pressure. If it's much of any pooch, then the tire is getting replaced. But I certainly will ride it home like that, though I'd probably boot it. And if I didn't have a tire in stock at home, I'd continue to ride until I obtained one.
But I might not plan on doing a century ride or try to best my downhill segment times on that tire.
Depends. Lot of personal preference involved too.
This one went very quick. If I was bombing 45 mph on a downhill I would have been in trouble.
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Such a pretty bike! Have you considered a 650b conversion?
Likes For shelbyfv:
Quoted: 313 Post(s)
Liked 682 Times
If you had 23mm GP5000 tyres in there, you might be able to fit 25's from another brand. The Conti's tend to measure up wider than most.
Likes For Branko D:
Liked 4,810 Times
Did you determine why you flatted? If you don't do any forensics on your flats then you'll probably be swapping tires a lot. Few of my flats are actually from road hazards.
Likes For Iride01:
In this case, I didn't find the cause but I think I went over a sharp rock angled in a way to puncture the sidewall.
I'm not looking to move to 25mm for more flat resistance. Mainly for more comfort.
Quoted: 1529 Post(s)
Liked 718 Times
Isn't the FD clamp what will hit first? You can get a low profile clamp like this:
Might add a bit of flex that hurts the front shifting though.
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
I was going to suggest searching around the stats on BRR, they provide measured height and width numbers and their tested tires for road are typically always 25mm labelled.
eg. https://www.bicyclerollingresistance...orsa-graphene2
Quoted: 1858 Post(s)
Liked 664 Times
Might also consider having a front deraileur braze-on mount added, to eliminate the issue with the thickness of the clamp. Another thing to consider is that Trek may have intended this lightweight beauty to be set up with 20 to 22 mm tubular tires in the 240 gram or less class. That is a very tightly-built frame!
Quoted: 645 Post(s)
Liked 797 Times
The left shifter came apart on me. Bike shop (very experienced with Campagnolo) wanted to replace but couldn't find the part. I managed to get it back together even though an internal plastic part was slightly deformed. I'm not expecting it to last much longer.
Quoted: 645 Post(s)
Liked 797 Times
2016 Campagnolo Athena 11-speed. I went for the pretty silver look... probably their last year of silver. Mistake as I would not recommend after 4 years of riding (perhaps 1k miles/year)
Quoted: 5 Post(s)
Liked 19 Times
I thought that I had read on this site numerous times that Campagnolo typically offers individual replacement parts. I am not doubting you of course, just asking.
I really like the silver finish of your group-set. Very sharp looking bicycle too.
Liked 718 Times
Wasn't there a silver Potenza group not long ago?
Follow-up on Tires: turns out a 23mm GP4000 tire actually measures 25mm with my calipers. I installed a Pirelli P Zero 24mm tire and it measured exactly 24mm in width.
