Handlebar just split in half on me. Expect the unexpected.
Going for an evening ride after my early morning ride and about 4 mins into it, my handlebars split in half on the right side. Never did I imagine this could be a thing. I think I'll just chill indoors for the rest of the evening...
Update: To be fair to the manufacturer of the handlebars, there were about 3 to 4 occasions where the ends of the handlebars smacked concrete pretty hard. So I guess it shouldn't have been THAT unexpected.
Actually, let me give you the whole story. I was about 4mins into my ride and I saw an oncoming speeding white compact car going about 65 in a 35mph. I decided to "swerve" them, play chicken with them, and dodged to the left. Right after this, my freaking handlebar literally just broke in half. Had it been a split second earlier, I could have been hit by that car. I don't think I'll be playing chicken with cars again...
Likes For bikelif3:
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Quoted: 4454 Post(s)
Liked 4,920 Times
Likes For PeteHski:
Liked 4,920 Times
So tell us about these bars ie make and model. Got any photos of the failure?
Their description: Handlebar Aluminum W:620MMxR:30MMx6 DEGREES, ALLOY BLACK
Cantilever believer
Quoted: 547 Post(s)
Liked 1,895 Times
Glad you're OK. An acquaintance of mine snapped a set of very experienced handlebars on a tandem - almost had a very severe crash.
I have experienced a broken handlebar on my Rans Nimbus recumbent after nearly 30 years of service - fortunately at low speed as I was coming to a stop. It snapped off where the horizontal crosspiece entered the left side - the hole for the crosspiece must have created a stress riser.
Snapped-off Rans Nimbus handlebar, 2012. No alien squeezy horns were harmed.
I was able to ride home very carefully using just one hand and one brake.
The bike was out of service for about 4 years as I searched for an appropriate replacement. Rans had discontinued that part decades earlier, and most recumbent riser bars were either too narrow or otherwise unsuitable. Finally ended up buying a set of super-tall Sunlite steel ape-hanger bars and was able to set it up acceptably, although at a greater weight.
Likes For RCMoeur:
Quoted: 6234 Post(s)
Liked 4,840 Times
Interesting how they broke like they did. Is there any evidence in the fracture that it started sometime ago and progressed? Can you get a more focused shot of both ends?
Being the thick aluminum that looks like, I think that probably means it wasn't the better aluminum alloy bars that are heat treated, annealed or any of the other things they do to make them more resistant of such things. All my aluminum bars that I've had on my bikes are/were much thinner aluminum.
You probably should send a pic of that to the bike manufacturer and the handlebar manufacturer.
Likes For Iride01:
Liked 4,920 Times
Nasty one that! Looking at where it failed, it certainly wasn't from an over-tightened or sharp-edged stem. I assume nothing else was clamped in that area. So I would presume it's made out of cheese spec alloy.
Likes For PeteHski:
Liked 3,003 Times
Oh snap!
must be laced with crabon fibre?
I'd at least report the breakage to the "OEM" to establish a paper trail..
-Oh Hey!
-Oh Hey!
More focused view. Luckily I had the same handlebars from an older bike I'm using for parts. Again, the handlebar ends did previously smack concrete pretty hard 3 or 4 times so not completely unexpected.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Likes For Schweinhund:
Quoted: 5890 Post(s)
Liked 3,475 Times
Glad the OP came out OK. This is why I buy a new stem and handlebar when I rebuild an old bike.
Quoted: 3966 Post(s)
Liked 7,383 Times
Likes For tomato coupe:
Liked 7,383 Times
Quoted: 1098 Post(s)
Liked 1,037 Times
You've just convinced me to swap the bars on my motobecane uno, absolutely love the bike but I've been riding OS bars for so long I've wondered about their general quality being 26mm. Yours make me think not good. Already destroyed the factory pedals 5 miles into the first ride.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
That being said, I saw a guy, (little Scotty) flat out snap a new pair of Answer taperlite bars doing bicycle trials. So there are no guarantees you still won't snap a pair.
Not exactly a ringing endorsement for bikesdirect eh. Notice how narrow the tubing is on one side of those bars. It's paper thin (!) Is it normal to have it molded asymmetrically like that? It's been a long time since I've bothered to look at galleries of failed components and most of the time when you see stuff like this it's carbon that's been previously wrecked.
The thickness is the same. The angle of the crack in the picture makes someone like you who is easily fooled, to make bold, incorrect statements as if they were fact. Are you Chat GPT???
I'll continue to buy my bikes from bikesdirect.com.
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,539 Times
Given the handlebar failure by your own admission is likely the result of the severe abuse they were subjected to by your rough/careless handling, why did you even post about it? Is your point that thrashing your equipment might result in mechanical failure?
I was sharing an experience that I didn't expect to happen. Is that ok with you? You know what, next time before I post something I'll private message it to you so you can approve or disapprove of it. Does that make you happy?
